Old 10-03-2008, 10:19 AM   #1
Speyederjedi's Avatar
Default TEAM ORION X312T
Has anyone had much experience with the Team Orion X312T motor? I've got a couple of 1st version Wasp .12's and they're pretty fast but a pain in the butt to tune. I believe these new CRF's are being produced by O. S.??? Any feedback positive or negative would be appreciated.
Regards,
Speyederjedi
Speyederjedi is offline   Reply With Quote
Old 10-03-2008, 11:15 AM   #2
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Regards,
Speyederjedi
I am sure George will be on here soon as I believer he has run the engine. I believe it is made by Picco, not OS. I am not certain of that so I guess we will both find out soon.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-03-2008, 11:25 AM   #3
MHarrison's Avatar
Scott, I believe you are correct, ( picco based ) .
MHarrison is offline   Reply With Quote
Old 10-03-2008, 12:22 PM   #4
Scott,
Have you had experience with this motor? Do they compare to say, the Sirio Evo IV Sti or Picco IDM? Are they tough to tune like the 1st version? I know I had to go through the carb changes with the 1st version (needle, venturri) and it was a pain. I still have 2 of the WASP CRF 1st versions, one which has been modified and is extremely fast it just doesn't hold a tune very well.
Regards,
Speyederjedi
Old 10-03-2008, 12:52 PM   #5
GREGORY!'s Avatar
the x312t is the latest crf motor that made by Toki for Team orion.
it has less agressive porting for better low-middle performance than the 2006-2007 orion versions.it has also some difference in the carb.
the new crf is picco based with crf style crank.there is a thread for this motor so you can see some opinions.
what problems you have with your 1st crf's?
GREGORY! is offline   Reply With Quote
Old 10-03-2008, 01:50 PM   #6
I would say the biggest problem with the 1st version CRF's which I have are that they are tough to tune and don't hold a tune very well. They also don't have very good throttle control from bottom to top. It's almost like an on off switch. I currently am runnning a Sirio Evo IV Sti and Picco IDM. Both those motors are very fast, are easy to tune, have very good throttle control across the entire rev range and hold their tune very well. I was just wondering if this new version of the CRF is that much better than the 1st versions and how it stacks up to what I am running now?
Regards,
Speyederjedi
Old 10-03-2008, 05:09 PM   #7
Hey Mate im running the x312t and i have had a couple of them,they are fast motors when clutched and geared properly,i found them easy to tune and reliable.The only problem i ever had with one was the tune would not hold and it came down to a bad front bearing seal.
ARC R10/2015 - HOBBYWING - PROAMPS - ORCA
BRCCC
elche_83 is offline   Reply With Quote
Old 10-03-2008, 06:46 PM   #8
NiTrO BoOsTeR's Avatar
yea i got 1, easy as to tune. its way faster than the old CRF, it also holds its tune realy well, it also has awsome power even when the top end is still rich. you cant go wrong with one of these engines.
I thought they where made by Kyosho and Team Orion.
Mitchell
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 10-03-2008, 11:13 PM   #9
Scott,
Regards,
Speyederjedi
I don't have one and really haven't even seen them run so I can't answer your questions. I do have the other two engines you have (EVO4 STI and the IDM)
Old 10-03-2008, 11:20 PM   #10
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
The new ones are just a rebadged Picco with an ugly crank...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 10-04-2008, 01:54 PM   #11
GREGORY!'s Avatar
[quote=Riketsu;4903011]The new ones are just a rebadged Picco with an ugly crank... [/quo
do you know the timings for the crf one?how can be sure about that?
and something else,who cares about beauty?
Old 10-04-2008, 02:07 PM   #12
wingracer's Avatar
Trader Rating: 24 (100%+)
Scott,
Regards,
Speyederjedi
Your IDM is basically the same as the new CRF's except for the crank. If you want a CRF crank, buy one. If you prefer a more traditional style crank then stick with the Picco's.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-05-2008, 08:48 PM   #13
So the new CRF's don't have the CRF sleeve with the lines cut into the bottom??? They just have a regular sleeve like the Picco???
Regards,
Speyederjedi
Old 10-06-2008, 01:02 AM   #14
Roelof's Avatar
Send a message via ICQ to Roelof
Regards,
Speyederjedi
Yes, it is just a normal sleeve.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Team Orion CRF Wasp Rev X-Dyno results Nano Onroad Nitro Engine Zone 1531 11-07-2010 02:43 AM
Orion CRF .12 2008 JHIH Onroad Nitro Engine Zone 79 03-10-2009 02:38 AM
New Hobby shop on the Darling Downs floss Australian Racing 55 02-10-2009 06:42 PM
What motor and pipe for vone rrr evo2? staikosn1 Nitro On-Road 45 10-15-2008 10:55 AM
