Old 09-29-2008, 10:06 AM   #1
Seisick's Avatar
Default WHAT DO YOU THINK ABOUT THIS!
http://www.cochesrc.com/foros/repart...-vt160262.html
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 09-29-2008, 10:12 AM   #2
Seisick's Avatar
ON A MTX4
HobbymaniA
GoT MuGeN?
Old 09-29-2008, 10:43 AM   #3
Ron C.'s Avatar
Originally Posted by Seisick View Post
ON A MTX4
That's very interesting. Im not able to read the info from the link, would you please translate or somewhat give us an idea of what it is and how it works?
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 09-29-2008, 10:51 AM   #4
nitrodude's Avatar
He explains that it has the opposite effect of a sway bar. It evens out the forces exerted on the tires so that the tire wear is even. Apparently they had a race on which one of the rear tires would wear more than the other, like GLARCRC where the left rear wears out more than the right, and they came up with this solution. It doesn’t say weather they tried it yet, or if it works. Its interesting for sure.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 09-29-2008, 11:08 AM   #5
lil-bump's Avatar
Trader Rating: 83 (100%+)
I use babel fish to translate. It's some sort of stabilizer that keeps constant pressure on both wheels at all times. I believe it says that both wheels always wear at the same rate and the car always brakes in a straight line.
I would like to know how this handles coming on to a big sweeper.
pretty impressive.....
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 09-29-2008, 11:45 AM   #6
Ron C.'s Avatar
Thanks for the info Steve and lil-bump.
I also noticed the car having White Springs on..... they're pretty stiff.
Old 09-29-2008, 11:53 AM   #7
wingracer's Avatar
Trader Rating: 24 (100%+)
It will have no effect on tire wear. All that is going to do is remove the shocks and springs from effecting how the car rolls. So now only the sway bar will control the cars roll and in case you haven't noticed, there is no shock on the sway bar. It looks neat but it's a bad idea.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-29-2008, 02:06 PM   #8
Send a message via Yahoo to motojon
Im all for improving tire wear but you need that sway bar to exert that force onto the other side so it will stay planted.
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 09-29-2008, 03:04 PM   #9
Speyederjedi's Avatar
Seems like this would throw off the balance of the car as it was designed to use a sway bar. I would think the rear of the car would be a bit off with this attached??? Does look cool but I'm not sure that translates to improved performance. As far as tire wear it's jus a part of racing. You may have to true tires at different sizes not just from front to rear but also from right to left depending on the track. I wouldn't sacrifice performance just so I could have even tire wear.
Regards,
Daniel
Speyederjedi is offline   Reply With Quote
Old 09-29-2008, 03:07 PM   #10
Roelof's Avatar
Send a message via ICQ to Roelof
It gives the rear more like a 1/12 suspension, interesting but I do not think realy efective.
A friend is experimenting with the DAX suspension system on his 1/5 truck.
http://www.daxcars.co.uk/start.htm
Now he has more grip and less tirewear !
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 09-29-2008, 04:40 PM   #11
wingracer's Avatar
WOW Roleof, now that looks like it has some serious potential. I could see a properly designed system like that having massive advantages for offroad cars. Onroad the differences might not be so great but may still work. I'd have to plot out the roll center changes with travel to be sure it would work right but that just might be worth a try.
Team Shepherd USA
Old 09-29-2008, 05:05 PM   #12
It looks like it would effect the ride height, those links are attached to the upper pin. that could be lengthen to change the ride height.
metheny is offline   Reply With Quote
Old 09-30-2008, 12:22 AM   #13
Roelof's Avatar
The most funny thing about this system is that roll and ridehight does not affect the camber of the wheel compared to the ground.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
New MRT ESC V12 Electric On-Road 494 12-05-2008 11:48 AM
Does Kyosho candy have razor blades in it? STRINGCHEESE Electric Off-Road 100 07-07-2008 08:35 AM
Prairie Knights Classic CorallyBQuiK Minnesota and North/South Dakota Racing 337 09-19-2007 05:31 PM
OPEN LETTER TO ALL FASTLANE RACERS Fastlane racewa Kansas/Missouri Racing 75 06-11-2007 07:33 PM
2005-6 ECT Changes TSB Northwest Racers 145 06-11-2005 12:33 PM
Traxxas New Product Release!!! Traxxas Support Monster Trucks 57 05-09-2004 04:21 PM
