Best stop watch?
Suspended
Go to any sporting goods store, they have a variety of stopwatch you can choose from.
This is most likely one of the best you can get
http://www.aimsports.com/products/multichron/index.html
http://www.aimsports.com/store/produ...products_id=29
@Roelof
I have the Orion LCS and used in in electric touring. With those bodies it is easy to mount the IR transmitter and let it send through the windows.
Have you found a good way to mount the IR diode under a Lola style bodyshell?
Any explanations and/or pix would be greatly appreciated!
Thanks and have a good day
Stefan
Stefan
http://www.speedwaymotors.com/p/542,...Stopwatch.html
I use this one,You can start all three times at once and from there I use one for laps,one for pitstops and the 3rd for overall time of race.
Thx Roelof!
Great idea. Where have you ordered those parts? From crazyLED?
Have you ever crushed a diode? For a spare one, do you have the spec or part #?
Yeah, I know - Lot's of questions. Thank's a lot for lookin into this
Bye
Stefan
Bye
Stefan
(Once I made a lapcounter in this way)
I think the LED is a standard IR led costing nothing more than 20 cent. Because the original LED is easy to replace you can give it a try but be sure you connect it the rigt way. The markings are a flat spot and a shorter pin.
Ledholders comes in all kind of shapes and can be found at any local radioshack or otherwise some online electronics shop. And with a piece of aluminium or plastic you can drill a 5mm hole to glue in the LED and right beside that a 3mm hole for mounting it with a nut and a bolt
Thanks a lot Roelof! Very helpful. You are the man
check the gq watch they are what I use over here....
