Old 09-14-2003, 06:09 PM   #1
BUDRACER1's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to BUDRACER1
Default tc3 2 speed,just revs in second?????
i put a 2 speed trans.in my tc3 about 3 days ago, and it worked great until today and now when it goes to second its like the car is in nuetral it just revs up.if i stop and take off again it works normal till it catches second,then just 40,000 rpms of coasting car.
thanks in advance BUDRACER1
Team Custom Works Team BOCA Bearings
Team RC4Less
BUDRACER1 is offline   Reply With Quote
Old 09-15-2003, 12:24 AM   #2
crashed_1's Avatar
Default Re: tc3 2 speed,just revs in second?????
Your diffs are a goner man...open up the rear gearbox and see if the white gears still have teeth in them...
crashed_1 is offline   Reply With Quote
Old 09-15-2003, 12:24 AM   #3
Registered User
NTC3 Kid's Avatar
What I think is happening is when it hits 2nd the one-way bearing isn't working.
NTC3 Kid is offline   Reply With Quote
Old 09-15-2003, 05:20 AM   #4
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
I would replace the one way bearing.....If it still works in firts,the gears are probably OK...
If it worked a few days ago, and you changed nothing,the gear dind't flip itself,so the one way probably just went bad..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-15-2003, 08:07 AM   #5
treky11's Avatar
before you replace it try greasing it with one-way grease. make sure you use oneway grease not regular grease.
treky11 is offline   Reply With Quote
Old 09-15-2003, 09:55 AM   #6
BUDRACER1's Avatar
thanks guys.the two speed has less than 2 tanks run though it.im going to take it all apart and see if maybe some grease from the one way got into the clutch bell and see if that works.but like you said harry it was working great on saturday so its got to be installed the right way.
BUDRACER1
Team RC4Less
Old 09-17-2003, 09:37 AM   #7
I'm 99.99% sure it's the one-way bearing in the two-speed. I just went through the same problem ... clean and lube it properly first, if it still fails, you'll need to get a new one-way bearing.
Luckyman4 is offline   Reply With Quote
O'DONNELL SUMMER CHAMPIONSHIPS at revs. TKCastle Radio and Electronics 1 07-30-2008 03:12 PM
Differences between o.s speed .21 v-spec speed alum and magnesium. Hans_Andersson Nitro Off-Road 11 06-23-2008 06:02 PM
Novak GTB Brushless 4 cell speed spectrum speed controller. jland R/C Items: For Sale/Trade 2 10-21-2007 02:37 PM
Problem: Nitro car revs out of control! cdizzle77 Rookie Zone 2 05-02-2007 07:54 AM
Help! Nitro engine revs super high on startup! captain america Rookie Zone 6 11-21-2006 01:13 PM
