Old 09-17-2008, 08:14 AM   #16
Send a message via Yahoo to motojon
well it didnt work i dont know if i didnt fill it up all the way or pushed too much out pluging it, so im going to try and heat it up and push it out
motojon is offline   Reply With Quote
Old 09-17-2008, 09:46 AM   #17
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
Is there anything you all could recommend for the stinger?? Once and awhile I will tap the side wall when coming out of our long sweeper and the stinger will get pushed in. Up till now I have just been bending it out with a screwdriver in the hole and pulling, I would like to know if there is a way to reinforce the stinger so this doesn't happen as much.
Sean
HB/HPI Racing | Morgan Fuels | HOBBYWING | Airtronics | REDS Racing | HRP | Hobby Revolution | Team N.E.R.D.
BLKNOTCH is offline   Reply With Quote
Old 09-17-2008, 09:52 AM   #18
if your a welder or know one you can weld a support in between the stinger and the pipe or the next one you buy u can get one with a reinforced stinger
Old 09-17-2008, 10:03 AM   #19
BLKNOTCH's Avatar
Well I am using the Novarossi 9630 pipe which does not have this option but I was thinking to use JB weld to do what you are speaking of.
Sean
Old 09-17-2008, 10:11 AM   #20
nitrodude's Avatar
I know what you're talking about, but if you think about it, it will make it worse. The support will push the aluminum behind the stinger even further in. The only way to fix the stinger is to do it while the pipe is still hot, just bent the stinger back to the angle that it was before you bent it, sometimes it looks just right.
Or, you can stop hitting stuff, I know I should
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 09-17-2008, 10:21 AM   #21
BLKNOTCH's Avatar
LOL yup
Old 09-17-2008, 10:59 AM   #22
maskedrider's Avatar
Originally Posted by STRICTLYSERPENT View Post
I would not do it, after one or two times it warps the pipe.Put a pair of channel locks in a vise up side down with handles in the air and slipe the pipe onto one handle and you can work the dent out nicely.
pardon me, can u show which channel locks u refering to ?
Any picture to show ?
thanks
Kyosho- Sirio/ OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
Old 09-17-2008, 01:42 PM   #23
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Sean
don't use jb weld. the heat from the pipe will soften it up. I used it on my stinger, nice and hard at first but after the pipe got hot stinger came right off.
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
Help! - My Teamlosi LST RC truck won't start, maybe engine broken? helgso Nitro Off-Road 61 05-26-2009 06:52 AM
O'DONNELL, WERKS & PROLINE Mike T Malaysian R/C Racers 14 05-11-2009 09:11 PM
Muffler stay rod off almtx3 Nitro On-Road 17 08-28-2008 12:34 PM
repair your dent exhaust pipes fredrick5 Nitro On-Road 20 01-17-2007 11:22 PM
Cutting the header for more top/low end? shortyboy Nitro On-Road 23 03-31-2003 03:13 AM
