Old 09-11-2003, 06:32 AM   #1
Default Futaba 3PK Question (slightly off topic)
I have the above mentioned radio and am quite happy with it so far. The one minor annoyance I have found is that the rubber wheel for steering slides in on the hub and rubs against the controller. Normally the wheel has very little tension on it but when this happens it drags badly. What are you other 3PK users doing to combat this?
jcrouse is offline   Reply With Quote
Old 09-11-2003, 07:44 AM   #2
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Futaba 3PK Question (slightly off topic)
use double side tape to secure the foam ring on the wheel. this is kind of very thin double side tape which is much thinner then servo tape.
Manticore is offline   Reply With Quote
Old 09-11-2003, 08:35 AM   #3
treky11's Avatar
I put 3 drops of CA glue on mine and it hasn't budged since.
Use small drops so if the foam wheel ever gets torn/worn out its easy to remove and replace.
treky11 is offline   Reply With Quote
Old 09-11-2003, 09:08 AM   #4
dtm
dtm's Avatar
Send a message via ICQ to dtm
I use the foam from the M8.....the material is firmer than the 3PK, it has nice rounded edges.....and the original shape is a lot smaller so it fits nice n tight on the 3PK wheel with nothing else holding it!
dtm is offline   Reply With Quote
Old 09-11-2003, 09:09 AM   #5
Manticore's Avatar
i have the sanwa foam ring on it now !
Old 09-11-2003, 09:11 AM   #6
dtm
dtm's Avatar
A lot nicer "feel" than the Futaba one...right!!
Old 09-11-2003, 09:13 AM   #7
Manticore's Avatar
sure. lets go back to M8 !
j/K
3PK is an awesome radio
Old 09-11-2003, 10:45 AM   #8
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
j/K
no doubt about it! you will be amazed if you are using the 3rd channel with diffferent mixing and program mix for instance, 5th scale, you can also set up front to back brake balance, and amount of brake according to steering angle!
Ah10 is offline   Reply With Quote
Old 09-11-2003, 01:23 PM   #9
I did two things.
First and cheapest, I wrapped one layer of servo tape on the wheel and put the foam back on. This works great and also gives the wheel a little more diameter.
Second and cost about $9.00, I was in my LHS and they had a sale on the Powers replacement wheel (the one that looks like a mini Momo) so I bought one. This is a nice piece of eye candy that is also functional. It's a little thinner than the stock wheel so there's a larger gap between the wheel and radio and you can see through the spokes but it feels good. Finally after using it all season some of the paint is wearing off and the foam is beginning to crack.
At least I still have my old wheel for back up.
AreCee is offline   Reply With Quote
Old 09-11-2003, 04:19 PM   #10
speedydave's Avatar
Send a message via AIM to speedydave Send a message via Yahoo to speedydave
Isn't the tension on the wheel adjustable?
speedydave is offline   Reply With Quote
Old 09-11-2003, 04:44 PM   #11
Arun's Avatar
two words: shoe goo
http://nexusracing.com
Arun is offline   Reply With Quote
Old 09-11-2003, 05:45 PM   #12
Fire's Avatar
i ditched the foam and use the overwrap grip made by HEAD
Fire is offline   Reply With Quote
Old 09-11-2003, 06:20 PM   #13
Default 3PK Cyrstal
Hi,
Do you guys recommend changing just crystal or purchase a new FM module for different channel option?
I have the Magnum version and the Crystal access is blocked. When I looked on towerhobbies, they have 75MHz modules with different channel options.
tks.
cvccsi is offline   Reply With Quote
Old 09-11-2003, 06:30 PM   #14
Fire's Avatar
i think only modules purchased outside of north america has the option of changing the crystals
the menu of my 3pk said it is against the law the change the frequency of the module, i guess that's why we don't have that option
Old 09-11-2003, 06:56 PM   #15
speedydave's Avatar
Everyone just takes the sticker over the crystal off and changes it anyway.
Question about Futaba 3PK emulberry Radio and Electronics 1 12-10-2007 09:52 AM
futaba 2pl question parnelli97 Electric On-Road 1 08-25-2007 11:10 AM
FS futaba 9451 digital servo slightly used straightaway R/C Items: For Sale/Trade 1 12-06-2006 12:02 AM
FS: Savage ss with mach .26 and futaba radio *slightly used* mrgsr R/C Items: For Sale/Trade 0 09-05-2005 06:18 AM
Painting Question - Off R/C topic tufferwilde Painting, Designs, Graphics and Photography 2 02-27-2003 04:57 PM
