Old 08-30-2008, 06:11 AM   #1
bboy's Avatar
Default 52 vs 60 pipes
I have the OS 3 and 5 port engines and have been playing with the pipes, switching between 52 and 60 (size of the stinger). The only thing I can tell is the 60 one uses more fuel for both engines.
Is this it? I would think the compression would be different and I would get more power from the 60.
Still learning ....
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
bboy is offline   Reply With Quote
Old 08-30-2008, 09:01 AM   #2
I believe that it the inside diameter of the stinger. The 52 should be 5.2mm and the 60 should be 6mm.
If I am wrong someone will let you know.
Joe Maxey is offline   Reply With Quote
Old 08-30-2008, 01:32 PM   #3
bboy's Avatar
I believe the 60mm is suppose to give better top end but with higher fuel consumption. Is this correct?
Thanks!
XRay NT1 + Max XXL3
Old 08-30-2008, 09:27 PM   #4
Yes the bigger the hole the better the performance. You will also consume more fuel.
pipes brianhatesnitro Onroad Nitro Engine Zone 17 03-22-2007 09:04 PM
Best pipes for an OS RG Cain Electric Off-Road 2 02-24-2007 08:20 PM
.21 RB Pipes. go1d1e R/C Items: For Sale/Trade 4 06-10-2005 01:55 PM
Pipes? Robster Electric Off-Road 2 07-15-2003 01:17 AM
In-line pipes versus old style pipes for .12 engines Hammer0412 Nitro On-Road 25 07-18-2002 12:19 AM
