Old 08-28-2008, 07:47 AM   #1
almtx3's Avatar
Default Bearing Cleaning/Re-Lube
What bearing lube/grease do you guys recommend? Got all my bearings out, ready to clean and re-lube them and I'm curious to see how you guys clean them and what you use to re-lube them. Oh I'm running metal shielded bearings by the way.
almtx3 is offline   Reply With Quote
Old 08-28-2008, 08:29 AM   #2
jeff1's Avatar
I put them in the Kawada Bearing Cleaner case with gasoline. Shake it and let rest then dry with compressor air or and let them self dry. Then I use Serpent bearing oil. Works good for me and very easy to do
jeff1 is offline   Reply With Quote
Old 08-28-2008, 08:59 AM   #3
godzukihop's Avatar
Trader Rating: 31 (100%+)
Non-clorinated brake-clean and compressed air to clean and lube with a couple drops of Mobil 1 10w30.
godzukihop is offline   Reply With Quote
Old 08-28-2008, 09:20 AM   #4
almtx3's Avatar
Has anyone ever used Zubak's Speed Lube?
Good tips so far keep em coming!
Old 08-28-2008, 09:44 AM   #5
Speyederjedi's Avatar
Since these are metal shield bearings you'd be okay in letting them sit in carb cleaner and then blowing them out with compressed air. After that I'd try lubing them up with mystery oil. Been using this for a while and haven't had any problems. I also use it as after run oil for my engines, works great!!!
Regards,
Speyederjedi
Speyederjedi is offline   Reply With Quote
Old 08-28-2008, 09:54 AM   #6
Suspended
For cleaning, I use coleman white gas. It's safe for the parts and cleans the grease and dirt off very well. you can get it at big 5.
http://upload.wikimedia.org/wikipedi.../Camp_fuel.jpg
just take the seals off with an exacto knife, put the bearings in a bottle with the cleaner, and shake it around a little to remove the dirt and grease.
for lube you can use Trinity Royal oil, it works great.
http://demonpowerproducts.co.uk/imag...oyal%20Oil.jpg
Team-Shepherd // XS Power // IDM Engines // TKO Bearings // Airtronics
00VIP001 is offline   Reply With Quote
Old 08-28-2008, 10:47 AM   #7
johndayo101's Avatar
Trader Rating: 128 (100%+)
Default tko product
i clean it with wd40 until the dirt is gone and blow it with compressor and use super sonic oil.
http://tkocompetitiondev.com/shop/pr...roducts_id=254
johndayo101 is offline   Reply With Quote
Old 08-28-2008, 11:03 AM   #8
I have a RPM bearing sprayer case and use WD40 to spray things out, then let them dry. Hit it with the compressed air, and use trinity bearing lube. Also use Marvel Mystery air tool oil also (this also works great as after run oil).
Baedarlboo is offline   Reply With Quote
Old 08-28-2008, 11:07 AM   #9
dj apolaro's Avatar
I remove the seals and use "Non-clorinated brake-clean" to clean them. After that I use Remingon gun oil and relube them till they are completely wet. This makes sure they have none of the brake cleaner in them. Remington gun oil is made for reflecting grease and stuff so it really works great.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 08-28-2008, 11:13 AM   #10
almtx3's Avatar
good stuff so far. Thanks to all who have chimed in.
Anyone using Sullivan's Dry Ice Race lube? If so hows that working for you?
http://www3.towerhobbies.com/cgi-bin...?&I=LXLYX6&P=6
Old 08-28-2008, 11:29 AM   #11
Roelof's Avatar
Send a message via ICQ to Roelof
I use this one:
http://www.the-border.com/product.ph...9&cat=0&page=1
Fill it with WD40, it cleans and lubicates.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-28-2008, 02:51 PM   #12
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
I just take a plastic dixie cup and put all my bearings in there and spray them with wd 40 till they are halfway emerged let them sit in there and shake the cup every 5 minutes or so till I am done taking apart and cleaning the rest of the car/truck then pull them out and dry them with a hand rag.After that I just put them back in the car.Works good for me and is quick and easy.
sm1nts2escape is offline   Reply With Quote
Old 08-28-2008, 03:17 PM   #13
ALG
I use this one:
I also use one of the ultra sonic cleaners, I use oil or grease, depending if Im club racing or real racing. grease will also help keep out the dirt and last longer, and oil is faster.
I use Serpent bearing oil or teflone oil.
have fun, but remember to change the bearings when they feel rought or hard.!!!
ALG is offline   Reply With Quote
Old 08-28-2008, 03:47 PM   #14
freestyles's Avatar
Trader Rating: 14 (100%+)
I forget who but someone has told me that WD-40 is no good to clean bearings with. The same person told me to put my bearings in fuel to clean them (very expensive way to clean things if you ask me). Now i'm confused
Can the bearing sheild go back on after you take it off???
I have molybdenem (i think that's how you spell it) grease, made by Tamiya. Would this be ok to put in my bearings. If not what is the actual purpose for this grease????
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 08-28-2008, 05:39 PM   #15
JayL's Avatar
I buy new bearings from AVID for a buck.....My time is worth money
JayL is offline   Reply With Quote
TC3 Forum Lowrider Electric On-Road 12196 10-13-2017 09:47 PM
Xray T1 David Galdo Electric On-Road 12705 07-04-2016 02:07 AM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 08:59 PM
Help Need Bearing Cleaning Methods! rc-jockey Electric On-Road 9 12-21-2002 06:41 AM
Steel or carbide balls jenny Electric On-Road 22 12-09-2002 12:51 PM
bearing maintainence -CriMinaL- |RC Electric On-Road 21 11-25-2002 10:53 AM
Grease, which is which ?? Wolf Electric On-Road 9 09-25-2002 04:56 AM
