Old 09-16-2003, 09:39 AM   #76
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Does anyone regear as the tires wear? I do run my tires till there's almost nothing left. With my nitro, I really don't have the luxury of being able to change a gear that easily... Electric is a 30 second job as we all know...
vtl1180ny is offline   Reply With Quote
Old 09-16-2003, 09:45 AM   #77
InitialD's Avatar
We actually do... Well for long mains, we usually compensate tire wear by going up a tooth on the 2nd gear pinion.
Old 09-16-2003, 09:50 AM   #78
vtl1180ny's Avatar
I run a Nitro 4-tec, it's a b!tch to change gears on the thing...
Old 10-08-2003, 09:27 PM   #79
Blue Sky's Avatar
Send a message via Yahoo to Blue Sky
Default Trued tire finish
How smooth should the trued surface be? After truing, my foam tire is very rough and not smooth at all. My cutting blade of my truer looks like a section of a jig-saw.
And does the speed of the pass make a difference?
Thanks.
Ron
Blue Sky is offline   Reply With Quote
Old 10-08-2003, 09:36 PM   #80
InitialD's Avatar
Default Re: Trued tire finish
Thanks.
Ron
I don't have much experiences trueing tires but most of the time we true them smooth like what you get out of the box. Perhaps you're cutting it too deep or too much at one go. Slower passes should make a difference. We have to do slow passes and cut 1 or 2 mm maximum at one time.
Well, if it comes out rough initially, a few runs on the track should smoothen it out.
Old 10-10-2003, 02:43 AM   #81
theRED5's Avatar
Can I change my 12 volt truer to AC power?
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 10-10-2003, 02:52 AM   #82
Corse-R's Avatar
Better than doing surgery on your tyre truer, get a small switched power supply. I have one capable of doing 13.8 Volts and pulling 10 Amps, handy when you have mains supply and enough strong to feed the truer and still charger your Rx pack at a 1 or 1.5Amps.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 10-10-2003, 09:43 AM   #83
Send a message via Yahoo to TambokGT
Default Re: Foam Tire Truing
Originally posted by StepPins
Just wanted to know the pros and cons of truing foam tires.
Also, what kinds of effects you experience when truing tires to have different diameters in front as compared to the rear, what did it do to effect steering, and if it's the same if running a front one-way or front diff, overdriven in front or not, etc., etc., etc..
Couple of buddies and I plan to invest in a tire truer....just want to know if this would be a worth while investment
I have a brand new never opened OFNA tire truer...it's fully automatic and runs on AC/CD. No wheel adapters included.
only $180.00 shipped US only
TambokGT is offline   Reply With Quote
Old 10-11-2003, 06:58 AM   #84
Registered User
Send a message via AIM to bbntc3
Do any you guys cut camber into the foams when truing them? If so, do you still leave the same amount of camber in the car you usually run? or set it at 0 ? By cutting camber in the foams, and setting the car at 0 camber I think there would be less camber gain with suspension travel. I have never tried this, any toughts or insight? Thanks: BB
bbntc3 is offline   Reply With Quote
Old 10-11-2003, 07:41 AM   #85
sparksy's Avatar
Trader Rating: 14 (94%+)
Cutting Pre camber on your tires does not realy allow you to run a 0 deg camber on your car.
Camber change generally has nothing to do with the degree of camber set. It is a combined function of roll center and arm lengths.
sparksy is offline   Reply With Quote
Tire truing MK_Arbiter Electric On-Road 14 10-23-2006 01:55 PM
Questions on Tire Truing and the Eagle Racing Tire Truer nitro_tacklebox Electric On-Road 5 04-21-2005 03:39 PM
Truing foam tires drx Rookie Zone 16 04-21-2004 05:02 PM
Foam Tire Truing - 2 degrees ? CraigHandley Electric On-Road 1 02-05-2004 12:56 AM
Truing foam tires. lilshortyc3 Electric On-Road 9 03-11-2003 07:45 PM
