Foam Tire Truing
#16
Originally posted by fraz
If track abrasion is high, sometimes truing is not necessary and can be avoided because many manufacturer's tires have a 6-7mm split right out of the box.
#17
Talking about tire truers, I believe I read somewhere in this forum that the most economical way to go without busting the pocket is to get the OFNA truer and fit it with Hudy arbors. Can somebody confirm and enligten us on this?
#18
Originally posted by StepPins
Do you usually true the tires to be straight if coning occurs, or just adjust for camber?
#19
Usually any coning is minimal after one heat, and I would likely just alter the camber to correct the situation - how slack of me! Remember that they've also likely worn differently from side to side depending on the track, and I would probably rotate them also. Then I'd be considering how they are looking in terms of split front to rear. There is also consideration given to the hardness - do we need to go softer or harder - front, back or both.
By the time you have this sorted, a decision has to be made as to what to run in the final - probably a new/different set altogether. And this is for a normal club meet. For a bigger event I'd be changing tyres a bit more.
Having re-read the above, it all sounds rather complicated, but it really isn't.
#20
I have the integy truer. I have no complaints. It comes with like 5 hacksaw blade bits much like many other truers. I am going to buy one of the hudy carbide cutters eventually, but i am using the stock bits now.
#21
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
yep,thats true.....but heres the way I figured it...
the ofna is 230 bucks.....the arbors are 30 apiece......I need 2...
teh hudy automatic now comes with a track width limiter(saves time cutting),the $60 revised aluminum case,AND the carbide bit..
I bought mine for 390 plus the arbors....I figeured once I added the cost of the case,plus thecarbide bit,I was saving only 70 bucks on the ofna.....
and to be honest,after looking at my freinds ofna truer,I decided teh better quality of the hudy was well worth it..plus the hudy cones the tires with one simple adjustment...something the ofna does not do(as easily)...
plus,I don't believe in supporting a company that copies products..
#22
Freakah and StepPins,
I found that truing touring foams will have you going thru tires a lot more. Tires won't last as long because you'll be cutting down the tires more often. Getting smaller and smaller. Not enough foam. On the 235s and 1/8th, there is more foam on the rim to true, right Joe? If you can afford tires like God, go for it. But if you drive out of control like me.....
Just my $.02
BTW, I was using Franks Serpent truer
Just my $.02
#23
The possibility of tires chunking and rendering them half or completely useless is high. Truing the tires down makes the tires perform better. Perhaps some may disagree.
#24
If you are running on a race program that has 1/8 running with you at the same location, ask the 1/8 racers to give you there worn out tires, 90% of the time they will say no problem sence they are to small for there cars and after all there just going to toss them. sock them in acetone over night, pull the rubber of the rims, sock the rubber in HOT water to get the acetone out of the rubber, if you do not do these it will make the rubber harder,then rinse in cold wate and let dry, you are ready to mount them on some rims, you did save your worn out 1/10 foams did you not? do the same, soke them in the acetone to remove the old rubber I can get away with only having to buy on set to every 4 I make and that has saved me over five hunders dollars this year alone....
#25
drfritz, I hear that 1/8th scale foam tires are softer (more grip) for the same shore and last longer when used for 1/10 TC. Something about different compound. True in your case?
#26
Hey, thats what I have found with them,they have a much tighter cell construction than standard tc tires and I can get away with running softer tires and still get good wear out of them.
#27
Roy, sometimes more does not necessarily mean that the tires last longer. More often than not, it may mean the shorter the life of the tires and perhaps at the expense of car parts because of crash
I've come across those times, but i forget to take the measurement. Remember" the seventies" But I did it when I was racing my Impact. Truing the tires down to that magic number really works
Can't really afford foams that much. Can't even buy a new car r/c that is. Bought a brand new Tacoma
#28
Nobody races 1/8th and 235 classes here anymore
But that's a good idea about using 1/8th tires
#29
4x2 Xtracab
4x2 S-Runner
4x4 Regular Cab
4x4 Xtracab
4x4 S-Runner
PreRunner Regular Cab
PreRunner Xtracab
PreRunner S-Runner
Which one?
#30
4x2 Regular Cab
4x2 Xtracab
4x2 S-Runner
4x4 Regular Cab
4x4 Xtracab
4x4 S-Runner
PreRunner Xtracab
PreRunner S-Runner
Which one?
4x2 Regular Cab
4x2 Xtracab
4x2 S-Runner
4x4 Regular Cab
4x4 Xtracab
4x4 S-Runner
PreRunner Xtracab
PreRunner S-Runner
Which one?
Should've gotten the Limited package
