Old 09-06-2003, 03:54 AM   #46
InitialD's Avatar
Originally posted by Corse-R
Sirio carbs are crappy due to their Metal/Plastic construction, metal with the continuous heating/cooling cycles stretch the plastic molding and then the carb is junk. Sirio engine with a Nova carb is just bulletproof.
I believe the STS engine uses plastic moulding carb too.
Old 09-06-2003, 09:13 AM   #47
Taylor-Racing's Avatar
Originally posted by stefan
Well, why don't you go and find out since you seem to be very sceptic about my opinion on STS engines.
If you have your mind already made up about something, it doesn't make a lot of sense to ask further questions, or does it?
My apologies if I offended you, stefan. I am not sceptical of your opinion and can not figure out how you interpreted my question as such. Also, I have not made my mind up about anything - where did all this come from?
I merely asked a question - lots of questions get asked on these forums.
Thank you to InitialD and prawntoe for the answer.
Taylor-Racing is offline   Reply With Quote
Old 09-06-2003, 10:51 AM   #48
prawntoe's Avatar
older version yes - the part that fit into the crankcase is a 2-piece plastic/plastic (or a variant of . . ) construction whereas the newer version is metal (outside)/plastic(inside). . .
The newer version has a redesign carb (that is when you compare the two side by side you can tell the difference where the rubber rings sit).
STS carbs (old and new) are very stable and easy to tune - IMHO they have a wide performance tuning range.
prawntoe is offline   Reply With Quote
Old 09-06-2003, 11:36 AM   #49
InitialD's Avatar
Thanks for pointing it out
Ok, the new one has one o ring while the older one had two. That's a step back don't you think? Wonder why STS did that while the newer NS12 and V12 engines are equipped with double o rings...
I was not having any problems using the original carb. Yes, it was easy to tune. However, I changed it halfway to a Nova carb that I had as I had done some things to the Nova carb and wanted to test it out on the STS engine.
Old 09-06-2003, 02:42 PM   #50
me43's Avatar
The new HPI is an STS engine, which is a copy of the Nova Rossi RS12
could someone hook me up to a place where i can get this engine cheap(not CRC)
me43 is offline   Reply With Quote
Old 09-06-2003, 04:36 PM   #51
stefan's Avatar
Send a message via AIM to stefan
usually there are always a few on Ebay.
today only this one:
STS RS3
stefan is offline   Reply With Quote
Old 09-06-2003, 10:24 PM   #52
Conrod, yes. Sleeve, partly yes as the groove for the pin on the crankcase is different. A small job with the dremel should do it. Front bearings yes but not the internal one. Therefore, the crankshaft is also different.
Thanks InitialD.
Does this mean I could resurect a S1-JP and a Novarossi S3 using a P/S from a STS-RS3?
Alternatively, could I resurect the above engines using a Sirio 3-port AAC P/S?
Old 09-06-2003, 10:38 PM   #53
InitialD's Avatar
I don't know about Sirio piston / sleeve but it should fit nicely on any Nova based engine. Like I mentioned earlier, you need to cut an extra slot / groove for the STS piston sleeve to fit onto a Nova based crankcase. I believe the Nova one is somewhere 90 degree offset from the STS one (can't remember CW or CCW). The pic I have attached shows a STS crankcase with a STS piston sleeve.
I believe the Sirio sleeve will have different timings as the rod length on the Sirio is slightly longer than a Nova based engine.
Old 09-06-2003, 10:39 PM   #54
EVOLUTION's Avatar
Thanks InitialD.
You want to put the sirio internals into a nova,what's up with that?
EVOLUTION is offline   Reply With Quote
Old 09-06-2003, 10:46 PM   #55
EVOLUTION's Avatar
Any info on the Richey/RD logics engines???
InitialD,a rubber band on the carb,ahhh ooooooooo!
Old 09-06-2003, 10:46 PM   #56
InitialD's Avatar
Probably either the Nova P/S set is damn bloody expensive or they aren't readily available...
Old 09-06-2003, 10:48 PM   #57
InitialD's Avatar
InitialD,a rubber band on the carb,oh ooooooooo!
Wife would not want to part with hers. Besides, I'm poor
Old 09-06-2003, 10:52 PM   #58
EVOLUTION's Avatar
What,i thought Dr Mahathir created good economic opportunities in Malaysia,woops this is the wrong thread. J/K
Old 09-06-2003, 11:38 PM   #59
Thanks and yes, the Nova based engines have the locating pin 180 opposite to the STS. This is why we have a Dremel, of course.
Old 09-06-2003, 11:43 PM   #60
Yes, expensive. . . . . and the JP's are just rediculous.
I like the idea of AAC - uniform materials expansion and all that.
Apparently the aircraft boys swear by it.
Engine Tuning (Picco based vs Nova based) Riketsu Onroad Nitro Engine Zone 6 12-25-2007 05:56 AM
Who makes the fastest 10.5 right now??? John Malin Electric On-Road 6 07-20-2007 07:24 AM
piston nova based engine dotmatrix R/C Items: Wanted to Buy 6 07-17-2007 10:01 AM
Who makes the fastest servo out there? donoman Electric On-Road 14 10-23-2005 06:26 PM
RB Concepts vs. other Nova based .12s Jon Carlson Nitro On-Road 5 06-23-2002 11:10 AM
