Old 09-04-2003, 07:12 PM   #1
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Default Any tricks to removing a siezed carb?..
My RB,bless its PIA heart,has the carb stuck...I simply can only turn it about 2 mm...thats it...I tried heating it,no good...
Soaking it..nope..
I need to get it out of its bore..any ideas on how?...
also,how to prevent again?...
Thanks..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-04-2003, 08:00 PM   #2
AMGRacer's Avatar
You could tie a piece of string to it and to a door handle and slam the door................................
Nah just joking.
Whack it in the oven at 400, use oven mits, yank it out and twist away at it till it comes loose. Make sure the cinch bolt is not digging in to the carb sleeve.
AMGRacer is offline   Reply With Quote
Old 09-04-2003, 08:08 PM   #3
fastharry™'s Avatar
belive it or not,I just tested all of them(2 3 ports and a 5 port)...
Each one has a seized carb...as soon as yoiu twist it,it locks up...
all the cinch bolts are loose in their settings..
I tried heating the motors with a heat gun...how would the oven be differnt?...
And wouldn't that melt the orings in the carb?..
Old 09-04-2003, 08:12 PM   #4
AMGRacer's Avatar
It has happened to a number of my RB motors too.
The oven gets it hella hot, probably more than the heat gun. I disassembled my carb as much as possible first. But yes the carb o rings in the case itself got hard and ruined. I had to replace them.
Old 09-04-2003, 08:24 PM   #5
fastharry™'s Avatar
has it happened to anybody you know with a Nova style engine also?.....
I wonder what causes it..maybe some anti sieze compound would help before we start them..
Old 09-04-2003, 08:35 PM   #6
fastharry™'s Avatar
well,its been in the oven now for 15 minutes..the carb doesn't move any more than before..
Old 09-04-2003, 08:41 PM   #7
AMGRacer's Avatar
Man that badboy is sure stuck in there. That trick worked for me.
You might have to go for more violent (and damaging) methods of extraction.
Old 09-04-2003, 08:44 PM   #8
fastharry™'s Avatar
hwta do you think causes it?....I mean..they all rotated 2 months ago..now,none of them do....
Ever seen it on other nova based engines?..
Old 09-04-2003, 08:45 PM   #9
nitrodude's Avatar
It happened to my friends RB the other day. I took it home, put it on the oven for 25 minutes at 350dgs, and out it came. I just had to put a little musle into it, but not much.
Thanks,
Steven Muller
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 09-04-2003, 08:48 PM   #10
nitrodude's Avatar
I forgot to say, one thing I do when I take my carbs off the block is I sand or file the part that goes into the block. The capturing pin leaves marks on it, and IMO thats why it stucks in there
Thanks,
Steven Muller
MPP
Steven Muller
Ronin Speed Parts
Old 09-04-2003, 08:50 PM   #11
AMGRacer's Avatar
Thanks,
Steven Muller
MPP
Yep if you cinch down too hard on the retaining bolt it scores the case and causes a "ridge" in the metal of the carb tongue. This makes them hard to get out. Get the 6mm HUDY driver and you can feel when the carb is tight but not too tight.
Old 09-04-2003, 08:51 PM   #12
fastharry™'s Avatar
I'll leave it in a bit longer,but this thing is stuck...I never overtighten the nut either..
Just one more reason I'm finally going to get rid of RB;s forever and run OS motors......
Old 09-04-2003, 09:25 PM   #13
treky11's Avatar
Exclamation
vice and a sledge. or they oxy-set torch should do
treky11 is offline   Reply With Quote
Old 09-04-2003, 09:34 PM   #14
Roger's Avatar
That happened to me also, but I just man'ed it and got the sucker loose.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 09-04-2003, 11:00 PM   #15
garbage
DanielSon is offline   Reply With Quote
Siezed Diff bearing.. now what? RC Corral Rookie Zone 14 09-05-2008 07:59 PM
NEED HELP REMOVING CARB FROM HPI 25 rc_racer61 Electric Off-Road 3 12-31-2005 09:43 PM
new LST Mach .26 siezed bigsbetter Onroad Nitro Engine Zone 0 10-31-2004 01:55 PM
Siezed Xray bearings myk505 Electric On-Road 5 09-18-2004 05:26 AM
Siezed bearings Tek Nickal Electric On-Road 16 07-17-2004 01:58 AM
