Old 08-22-2008, 07:36 AM   #16
Roelof's Avatar
Send a message via ICQ to Roelof
Electrics is running already with 4 times bigger capacity than 20 years ago...
But for gas I think is is no improvement, engines will become faster and so more unreliable and so more expensive....
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-22-2008, 08:28 AM   #17
rccobra705's Avatar
Originally Posted by stefan View Post
We are already getting to a point where the 30 mm tires are having a hard time coping with the power the current engines throw at them.
If we increase tank size, the power will go up even more, run time will quickly be an issue again and the tires are wearing even faster.
IMHO, we need wider tires, like the 40 mm rears or maybe 35 mm, BUT not with Lola bodies.
And then we are back to 235 mm class and with .15 big block, which is great for me. This class also use 75 cc tank.
rccobra705 is offline   Reply With Quote
Old 08-22-2008, 08:57 AM   #18
wingracer's Avatar
Trader Rating: 24 (100%+)
Actually they increased it to 85cc.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-22-2008, 10:11 AM   #19
rccobra705's Avatar
Don't think so. Serpent 835 use same tank as Serpent 705, 710 and 720 which is 75 cc.
Old 08-22-2008, 10:24 AM   #20
wingracer's Avatar
From the roar rulebook.
9.2.8 FUEL TANK SPECIFICATIONS:
9.2.8.1 Fuel tanks must be securely mounted.
9.2.8.2 Maximum fuel system capacities are 75cc for .12 engines, 80cc for .15 engines, and
125cc for .21 engines.
So I had it wrong too, it was raised to 80cc.
Team Shepherd USA
Old 08-22-2008, 10:33 AM   #21
Suspended
Originally Posted by ~McSmooth~ View Post
If you make the fuel tanks bigger, the engine mfrs will still find a way to use up the extra fuel in under 5 minutes. Then we'll be right back where we are now.
+1
oldschoolracer is offline   Reply With Quote
Old 08-22-2008, 12:10 PM   #22
Woodlands Racer's Avatar
Another way to look at it is that a bigger fuel tank will bring "Fuel Strategy" into play just as in an F1 race. Larger tank means more weight for the car to haul around so you could choose to start with a lesser load and adjust your pit strategy. Just some thoughts.... maybe it is too much for us to digest. While I am not in favor or disfavor of the idea yet, I do not think that the hobby would benefit from an engine that goes so much faster that it drinks twice the fuel as it does now. After all, we would need to redesign many of the existing tracks to accomodate a car with that much speed potential.
Roger
Roger Bourland
The Woodlands, TX
THIRD COAST RACING
Max Power/RC America - Mike's Hobby Shop - SRC Tires/RC America
Getting Faster With Age, Hope to see many more birthdays!
Woodlands Racer is offline   Reply With Quote
Old 08-22-2008, 12:56 PM   #23
rccobra705's Avatar
Ok no problem, but these are the ROAR rules. IFMAR don't have the class, so no rules and the EFRA rules is:
1/10 th I.C. Track cars
5.3 Fuel Tank
The fuel tank incl. filter and fuel pipes up to the carburettor may hold a maximum of 75 ccm. No loose inserts allowed
If you are a good engine tuner then it does'nt matter if it is a big or a small tank, but if you are a bad or not so good engine tuner, then it is better with a big tank.
You are right, I am right depend in which part of the world so let go racing.
Have a nice weekend
Ways to increase the fuel volume to 125ml vti-chris Nitro Off-Road 12 08-08-2008 02:22 PM
Nitro Fuel Pric Increase ? fastrcracer Nitro On-Road 58 07-17-2008 07:56 AM
V One R Fuel tank Helix70 Australia Wanted to Buy 0 05-28-2006 08:14 AM
IFMAR goes to controlled fuel Craig1 Australian Racing 13 11-30-2004 03:05 AM
Fuel tank. tkhoo R/C Items: Wanted to Buy 0 07-14-2003 09:15 PM
