Old 08-18-2008, 07:40 PM   #1
fastrcracer's Avatar
Default Kyosho RRR Setup Questions
Just a few generic questions:
1. To get more on power steering, where would you start making changes. Most affective to least affective.
2. The same with off power steering.
3. How does the optional front hubs in 1 degree and 2 degree affect the steering.
fastrcracer is offline   Reply With Quote
Old 08-18-2008, 08:28 PM   #2
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Setups
It depends on the track,how much traction,for one i run out of the box setup,execpt i run the solid axel in the frt,with the 2degree knuckles with #12 servo saver.You can play round with the droop also,softer tires in the frt.like 38 frt 40 rear,or 40frt,42rear.I like the 2degree knuckles, good turn in real aggressive exit.You can try different shock oils also,for example 500wt frt,600wt rear,or 600frt,800wt rear that,s what i run, with dark blue springs frt,an rear.But just do 1 change at a time not all at once.hope this helps.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 08-18-2008, 08:34 PM   #3
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Well, I dont know how to get steering for different on/off throttle. I just know that in my case, if I need more steering, I give more camber in the front, soften the front sway bar and harden the rear sway bar... Like they said, one at a time.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-19-2008, 06:01 AM   #4
Default Try this 1st
Try droop settings if you hve locked frt, -1 frt ,3.5 rear droop ,2nd agian for tires depending on traction, an what tire brand you run practice with 37 frt 40rear or 40frt 42rear.
RoninRc.com
Basher BT-4
Old 08-19-2008, 04:05 PM   #5
Thanks for the replies.
Most of the time I use 40 frt, 42 rear Jaco Tires.
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 04:59 PM
Gulf Coast RC Track Racers, Porter Texas (Houston) John Stranahan Texas Racing 2692 04-18-2013 10:18 AM
Kyosho V-ONE RRR Ultimate Edition (UE) rmdhawaii Nitro On-Road 686 02-25-2007 08:42 AM
Help With GP kmaheartless Rookie Zone 13 01-20-2007 12:19 AM
