Old 08-18-2008, 06:23 AM   #1
Trader Rating: 244 (99%+)
Default Overheating problem....
Ok so I have been racing for a long time but, I have run into a problem that i cannot figure out. I have a HPI R40 (and have had other nitro on-road cars) and have had 3 different motors in it. A borrowed Nova Rossi ( ran perfect for the owner ), a brand new Orion Wasp CRV, and a borrowed Mugen Sikei ( ran perfect for the owner ). My problem is no matter how I tune the them seem to bog on the bottom ( rich ) and lean on the top ( over heat 300 + deg ). If I try tuning them so they stay under 300 they run out of fuel after 3.5 to 4 min and if I try tuning the so they run right ( most power ) they over heat and seem to be rich on the bottom. Now if I try to lean the bottom out to get snap back the motors wont start or dont run right. What am I doing wrong?
Fred Perkins is offline   Reply With Quote
Old 08-18-2008, 06:52 AM   #2
s10dude's Avatar
you will also get bog at bottom due to clutch setting..
i set my bottom by letting it idle and count ot 10 and punch the throttle , if rev's up quickly it's OK.it it hesitates or bog's lean a 1/4 turn and repeat (clear out engine ..REV...between idle's ) till it rev's quickly...
this is my opinion ....
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 08-18-2008, 07:52 AM   #3
intimidator's Avatar
You left out tons of variables?I would start by putting the carbs back to factory settings,check for leaks-loose head-bad o/rings-header gaskets-etc.,are you using right plugs for the fuel you are using?It could also be mechanical problems as well.A bad one way first gear and worn shaft,bad second gear mechanisn,binding in drivetrain,is the clutch ok?You said you tried three motors so to me I would think its the car.Post some pics,are you in Fl.??
intimidator is offline   Reply With Quote
Old 08-18-2008, 08:09 AM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
What kind of fuel are you using ?
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-18-2008, 12:06 PM   #5
Thanks guys I think I figured it out.
I think I have been setting my Centax wrong.
Motor now runs great!
Temps about 230 and will run for 6 min!
Old 08-19-2008, 10:34 AM   #6
Send a message via Yahoo to motojon
You know what I think that might be my problem to ive been having the same concern bogs on the bottom overheats on top. what did you do to your centax was it to loose?
motojon is offline   Reply With Quote
Old 08-19-2008, 04:16 PM   #7
The clutch was set to loose plus I had to heavy of weights.
If you get X-rc check out the Feb 2007 issue. It has a great article on setting a centax.
Old 08-19-2008, 06:01 PM   #8
you know what I really think thats my problem i'll gp through my clutch tonight
"Ask" Jilles Groskamp Tamiya 416 & 417, Team Orion Motors JGH Electric On-Road 1996 05-27-2014 07:28 AM
B.R.C.C.C (Tingalpa) hooked_on Australian Racing 6962 11-07-2011 02:58 AM
Ask Steve "The Evicerator" Weiss TeamButter Electric On-Road 7088 07-16-2011 06:01 PM
sc10 overheating after 5min robbieharris66 Electric Off-Road 10 08-12-2009 04:52 AM
Engine Tech x_man Malaysian R/C Racers 745 11-28-2007 12:05 AM
Danga Bay - Hobby Hub R/C Challenge 2003 Series 2 Hobby Hub Malaysian R/C Racers 313 01-12-2004 09:59 AM
