Old 08-29-2003, 07:37 AM   #31
KMac's Avatar
If they are that good they would'nt need a 2 year warranty!
Obviously, you know nothing about warranties, either. Companies only provide longer warranties when you either pay for it, or there's a very high confidence level in their product, NOT to cover themselves because they think their product is bad. They would lose their ass in a hurry.
Your logic is entirely flawed.
KMac is offline   Reply With Quote
Old 08-29-2003, 09:47 AM   #32
I have been using all digital hitec servos since they came out. The origional ones had a programming problem. Did they cover it up? No. They came out and said if you have one of the affected servos then send it back and it will be replaced for free.
Our shop has been selling hitec for the past 5 years. Not one servo that has ever been sent back has come back with a bill, no matter if it was out of warrenty or not. The total that we have had to send back since we started carrying them could be counted on you hands and feet.
JPHRacer is offline   Reply With Quote
Old 08-30-2003, 07:09 AM   #33
Tee
Default One More Possibility...
Maybe the venom failsafe sent out the "crazy signal" that appears like the digital servo programmer signal(s) and you ended up reprogramming your digital servo. I totally fail to see how cutting off a side tab or not (?) would ruin anything besides deforming the connector socket. Does the connector socket qualify as an internal circuit? Either Venom is way stupid or I am, pick one.
You should see if the servo can be reset with the "servo programmer"
Tee is offline   Reply With Quote
Old 08-30-2003, 07:23 AM   #34
snoopy's Avatar
Nothing wrong with Hitec servos these days.
But i still see higher failure rates in all the digital servos than i think is acceptable.
snoopy is offline   Reply With Quote
Old 08-30-2003, 10:58 PM   #35
Default Re: One More Possibility...
Because a retard designed the fail-safe. There is a small wire that gets connected to the circut board under the plug socket, right were the futaba tab would slide in. If you dont cut the tab it will break the small wire out of the circut board.
Old 08-31-2003, 02:47 AM   #36
Old Skool's Avatar
Default My take on the Hitec digital servo issue...
I had (notice that that's in the past tense, natch!) two Hitec high-speed digital servos, and two of their high-torque versions. Three of them failed in the course of normal use within two months of the purchase date. I sent them all in to the company's repair center. They returned them with an invoice stating that two had been repaired; the third one they claimed had no problem. Okay, great. I charged up the rx batteries and installed them in my MRX-3 and the third went into the throttle position in my XR buggy. Can you guess what happened next, boys and girls?
Not one of them worked a damn. Just for a test I plugged in an old Futaba S3003 in the same positions and it worked. Wtf is up with that? I even sent two back and Hitec swore they found no problem. Yeah, right.
This was a little over a year ago. Needless to say that are long gone, and I now run Airtronics and KO's. In all fairness I have been using a non-digital high-speed Hitec in the steering position of my NTC3 and it works fine. It's just their digital servos that I stay away from, and around here a lot of other drivers have had a similar story. I cannot recommend Hitec digital servos to anyone, sorry.
Old Skool is offline   Reply With Quote
Old 08-31-2003, 09:15 AM   #37
EVOLUTION's Avatar
I remember a whileeeeeeeeeeee back a friend of mine who worked at a store told me they had a huge recall of the digitals so someone must know something about them.
The 925s are the only half decent ones i know of,pretty good bang for the buck if you "have" to get hitecs.
EVOLUTION is offline   Reply With Quote
Old 08-31-2003, 10:20 AM   #38
Registered User
Send a message via AIM to bbntc3
Kmac: Yea my lodgic is flawed, with Hitec broken servo's!! To me, the 2 year warranty, and the lesser pricing Hitec uses, is just to lure you in, not because of their great confidence level. Gee, Let's see, I can get a servo, half the price and with a 2 year warranty. Sounds good! That's how they hooked me! but after sending them back a few times, I then understood. You get what you pay for! Airtronics and JR the only way to go!
Just my .02 worth!
bbntc3 is offline   Reply With Quote
Old 08-31-2003, 10:33 AM   #39
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
yes, some servos were recalled due to a software problem.
http://www.hitecrcd.com/Support/servostatement.htm for the information on the recall
...and just for the record. I have 6 Hitec servos, one digital, and have not had a single problem with any of them.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 09-03-2003, 09:50 PM   #40
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
ok..heres a diffrent take on the subject..
Eveyone hates using Digitals on throttle,right?.....
How about all the new high responce recievers that need all digital servos????????
now whatcha think?........
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-03-2003, 10:05 PM   #41
AMGRacer's Avatar
Actually warranties are offered as a product differentiator (like Hitec does) based on a risk assesment of product lifespan to failure rate to consumer return rate.
AMGRacer is offline   Reply With Quote
Old 09-03-2003, 10:17 PM   #42
Registered User
Buy Airtronic, Futaba, or JR, then you don't have to worry about a 2 year warranty! I wonder why these companys don't offer 2 year warranty? ( they don't have too!)
Old 09-03-2003, 10:21 PM   #43
AMGRacer's Avatar
You got it. If it was costing them sales as a product differentiator they would give you one.
Look at the "Stresstech" guarantee from Duratrax. You think they offer this cause their product is the bomb?
Spektrum and Venom Fail Safe Takt Electric Off-Road 3 02-10-2007 01:46 PM
venom and ko propo fail safe ralliartlanevov R/C Items: For Sale/Trade 2 12-14-2004 08:07 AM
Venom Fail Safe F/S F/T DOMOisCOOL R/C Items: For Sale/Trade 14 05-16-2004 10:50 PM
Venom Fail Safe RC Oval Racer R/C Items: For Sale/Trade 0 10-08-2003 02:30 PM
