Old 07-31-2008, 07:38 AM   #1
rias5037's Avatar
Default Max Power .12 MF
Anyone know what the engine above is shimmed for, i assume 25-30%, i will be using 16% fuel, so how many shimms should i retain.
thanks
rias
rias5037 is offline   Reply With Quote
Old 07-31-2008, 07:51 AM   #2
What is your question. All .12 engines come pre-set for 16% when they are new. If you are at sea level you can run .30 16% which is one of the thick aluminum shims. If you run more nitro you need more shims. Most people use 25%-30% hee in the USA so we generally run .50 shims..... That is a guess seeing how you gave me no info on the engine it self...
rangulo is offline   Reply With Quote
Old 07-31-2008, 09:08 AM   #3
rias5037's Avatar
unfortunately not ALL .12's comes shimmed to run 16% fuel, as far as know, some .12's are shimmed to run 25-30% fuel, and when you use 16% fuel on these engines, you just dont get the performance out the engine.
i have a JLR.12, which come preshimmed for 25-30% fuel. sam from team kamakazie helped me out with regards to what shimms to retain on that engine, but i know want to run my Maxpower .12 MF.
so heres my question again, is the Max Power MF .12 shimmed for 30% fuel, if so, how many shims do i retain or remove to run 16% fuel.
Old 07-31-2008, 10:25 AM   #4
mtveten's Avatar
Trader Rating: 27 (100%+)
its comes preset for 16-20% with a .3mm shim, depending on your altitude & weather you should be good to go.
Mark
mtveten is offline   Reply With Quote
Old 07-31-2008, 10:56 AM   #5
NitroWD's Avatar
usually nova-based engines are shimmed for 16-20%...while picco-based are shimmed for 25-30%.
NitroWD is offline   Reply With Quote
Old 07-31-2008, 11:39 AM   #6
rias5037's Avatar
thats cool, so im ready to use this engine as is, awesome, cant wait to fire it up, any suggestions on what pipe suits this engine, we run a short technical track, not many open strights, so the skyline pipe with the JLR.12 work well, but can i use the same skyline pipe on my maxpower, what do you guys suggest.
Old 07-31-2008, 11:49 AM   #7
Team Kamikaze's Avatar
Skyline VR 12 plus, should be fine, but the MAX 2602 will be the best, just like the JL engine you got, skyline works but the PICCO 2607 is way better.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 07-31-2008, 12:14 PM   #8
mtveten's Avatar
For short tracks you'll have more than enough power with just about any pipe set. The nova 2630 with the long conical header would be best for short tracks, but the 2602 would be better on regularly sized circuits.
Mark
Old 07-31-2008, 01:57 PM   #9
His question is about .12 MF.. Why would you even talk about JLR.. Those are Piccos and are totally different.
Old 08-01-2008, 02:23 AM   #10
rias5037's Avatar
the reference to picco was just made to show that picco's are generally shimmed for 25-30% nitro use and nova based engines are normally shimmed for 16% nitro use
anyways, ive got my answer, so thanks all for the help, appreciate it.
Old 08-01-2008, 03:33 AM   #11
rias5037's Avatar
sam, ive also got a 2607 mega pipeset, is this the same as the picco 2607 pipeset you mentioned.
Old 08-01-2008, 08:40 AM   #12
Yes.
Only the JL's are shimmed for 30%, most Picco based engines are shimmed for 16% just like the Nova Rossi .12 engines.
Old 08-01-2008, 09:40 AM   #13
rias5037's Avatar
sam, one more question, would the mega 2607 pipe be better than the skyline pipe on the Maxpower .12 MF?
Old 08-01-2008, 10:43 AM   #14
No, 2607 will not work with the Max .12 engine, skyline will be better.
Old 08-03-2008, 12:42 AM   #15
the best for max .12 it`s 2602 or 2601 by novarossi
ciao
gianni
serpentmaster is offline   Reply With Quote
RC BLOW OUT !!!! Ice chargers,novak discharger,power supply,power bridge,integy setup shrum1340 R/C Items: For Sale/Trade 20 07-23-2007 05:37 AM
Novak N-Power power supply, original box, like new condition!! Scottrik R/C Items: For Sale/Trade 7 05-28-2007 05:04 PM
Novak N-Power 14Volt/10AMP DC Power Supply Guo Chean R/C Items: For Sale/Trade 6 04-23-2007 05:32 PM
>>> TEAM NOVAK N-POWER POWER SUPPLY GREAT CONDITION $50 <<<< mach51 R/C Items: For Sale/Trade 3 02-06-2007 10:53 PM
Novak Millenium Pro charger ans N- Power power supply RobertF R/C Items: For Sale/Trade 11 11-27-2005 08:59 PM
