Old 07-20-2008, 04:53 PM   #1
Default Mugen mrx3
Whats a good setup for a mrx3? Have a buddy that just got one and needs a starting point thanks
Mugen USA-FX Hobbies-Airtronics
TONY CLARK
STRICTLYSERPENT is offline   Reply With Quote
Old 07-20-2008, 05:06 PM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
For high bite, start with the stock set-up if he still has the manual.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-20-2008, 05:13 PM   #3
he has no paperwork with it thats why he does not know where to start from
TONY CLARK
Old 07-20-2008, 05:32 PM   #4
wingracer's Avatar
Well, let me see if I can remember everything.
Start with white springs all the way around. He will want some red rears as well if he needs more steering.
Mugen 600 oil all the way around. One hole pistons front, 2 hole in rear.
+2mm droop front, +8 or 9 rear.
Front shocks in the lowest hole, rears one hole up from bottom.
Between 2-3 degrees rear toe in, 1/2 to 1 toe out in front.
I can't remember stock track width, probably around 253 front.
If he can find it (or if the car came with it) it really likes the blade style rear sway bar.
Stock tire sizes were 70f 76 rear but start out a couple mm smaller.
Make sure it has the 26 tooth pulley instead of the 25 unless you run on a REALLY slick track.
If I think of anything else I will post it later.
Team Shepherd USA
Old 07-20-2008, 05:34 PM   #5
wingracer's Avatar
Oh yeah, if I remember right you can put the MRX-4 steering blocks on the car for a bit more steering. That's the 4 or 4r, not the 4X blocks. You would have to get the spacers to use the 4X blocks.
Team Shepherd USA
Old 07-20-2008, 05:41 PM   #6
Thank you very much
TONY CLARK
Old 01-17-2009, 09:36 PM   #7
How much play should there be in the front belt?
Tim
got2bqik is offline   Reply With Quote
Old 01-17-2009, 09:37 PM   #8
Also Sean do you think the set up you posted would be good at VORRA? What shore tires would you recomend with that set up on that surface?
Tim
Mugen MRX3 Nexus R/C Items: For Sale/Trade 2 04-09-2006 09:49 PM
Mugen MRX3 1/8 rtr GMartinez R/C Items: For Sale/Trade 22 02-19-2005 12:30 AM
Mugen MRX3 FS/FT nitro_tacklebox R/C Items: For Sale/Trade 15 04-10-2004 10:34 AM
Mugen MRX3 Macky R/C Items: For Sale/Trade 1 10-13-2003 03:35 AM
Mugen MRX3 - NEW Ron C. R/C Items: For Sale/Trade 10 04-01-2003 09:10 AM
