Old 07-15-2008, 10:14 PM   #1
shokyo's Avatar
Default kyosho FW-06
any one use this model...
any review...???
shokyo is offline   Reply With Quote
Old 07-16-2008, 02:23 AM   #2
Hey
I have one, but first car and first meet last weekend so still all new to me..
Steve
stevelc is offline   Reply With Quote
Old 07-16-2008, 08:20 AM   #3
nObRaIn's Avatar
You can find plenty of info in the FW05R and FW05RR threads as the FW06 is practically an FW05 series car with new electronic box, fuel tank, rear lower arms, shock mount support brackets, body shells.
It is a great car, and still the only shaft driven car that can come close to the belt driven racers.
nObRaIn is offline   Reply With Quote
Old 08-02-2008, 08:23 PM   #4
unitfox333's Avatar
Send a message via AIM to unitfox333
Default got one
yea i got one on friday.... the hobbys new to me and so is the car but i can tell the car is no joke.. every thing is customizeable stock i dont have to upgrade a thing becides the contoler cuz at a race on friday the day i got the car some one was on my frequency which sucked but... the car is nice,,,, handles perfect right out the box....
unitfox333 is offline   Reply With Quote
Old 08-03-2008, 07:26 AM   #5
victorpalad's Avatar
car looks almost (i say almost) to the 05t, which is a good thing. i just hope the carbon upper deck is compatible with the 05 because the 06 seems to be the main thing being stock as in parts. if it is similar to the 05, then it should handle pretty well.
victorpalad is offline   Reply With Quote
Old 08-05-2008, 06:11 AM   #6
Renault_Tech's Avatar
Having owned an FW-05T and now an FW-06 i can say they are both very similar. Both run the same engine and 2 speed transmission. It has similar suspension set up to the V-One RRR and the parts are transferable between FW-05T, R, RR and S aswell and V-One RRR.
I love this car. all ive done is add the Kyosho Tuned pipe and mainifold, foam tyres and a few little pieces here and there and it flies and handles great.
Renault_Tech is offline   Reply With Quote
Old 08-07-2008, 05:41 AM   #7
already doing
maple story mesos “It’s more to feel like you got a trophy for doing something special, but in no way would this increase your character power. We didn’t want to force you into weird sorts of gameplay that you wouldn’t be doing anyway; we wanted it to more be sort of a reflection of what players were already doing.”
davidmn is offline   Reply With Quote
Old 08-07-2008, 05:52 AM   #8
What on earth is this supposed to mean???
Old 05-07-2009, 07:44 PM   #9
runenetti's Avatar
Recently bought a 06 new and have now run the engine in. I notice that after i run the car there is a pool of what looks to be fuel just behind the gearbox. Does anyone else have this problem and a resolution?
runenetti is offline   Reply With Quote
Old 05-07-2009, 10:32 PM   #10
It should be oil leaking from your engine. There are three area oil is likely to leak from. Main bearing, but it is not much you can do as high grade German bearing would cause more than a brand new stock engine. The end cap and the join which the carburetor and the casing meet. You can seal it properly by using liquid gasket. Hope this help, And the fw06 is a great car for parking lot racer as it have the same suspension as the RRR and a very reliable shaft transmittion.
gpm-parts.com is offline   Reply With Quote
Old 05-08-2009, 08:37 AM   #11
V_28's Avatar
could it be that its still running rich from your break in period. lean it out a bit and that should minimise some of the oil your finding from the exhaust. hope that helps a bit.
V_28 is offline   Reply With Quote
Old 05-08-2009, 06:40 PM   #12
where doesnt the GXR leak from? Carby, pullstart housing, front bearing, manifold etc. get rid of the GXR and get a decent rear exhaust engine. I have swapped the GXR for a Novarossi N12TS1/RT to run in the pullstart class.
[KYOSHO] [NOVAROSSI] [TEAM MAGIC G4RS] [O.S SPEED T.Z SPEC II] [SPEKTRUM DX3R]
Old 05-14-2009, 05:39 AM   #13
how did you fit the rear exhaust in the fw06 as im also gettin major engine leaks. My 3rd rear servo died yesturday.
Can you post picks and what exhaust you have used?
and what is the performance upgrade you get from the novarossi engine compared to the gxr?
thanks.
Christopherp is offline   Reply With Quote
Old 05-14-2009, 05:49 AM   #14
ill get the camera out now
Old 05-14-2009, 06:35 AM   #15
thanks cant wait to see.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
