Old 05-14-2009, 06:37 AM   #16
Renault_Tech's Avatar
[KYOSHO] [NOVAROSSI] [TEAM MAGIC G4RS] [O.S SPEED T.Z SPEC II] [SPEKTRUM DX3R]
Renault_Tech is offline   Reply With Quote
Old 05-14-2009, 06:40 AM   #17
What servo are you using and are you using the standard radio gear??
Throw the GXR away and get an O.S TG .12 or the Novarossi N12TS1/RT. Both are rear exhaust and you can get the O.S TG with pullstart and still use your normal clutch system. a million times better than the standard motor.
Old 05-14-2009, 06:47 AM   #18
nice upgrades you got there. i cant find the motors your talking about on any sites? yep still standard radio gear, until the 8 2.0 rtr comes out anyway. what seros would you recomend?
*EDIT*
I was thinking of rebuilding the diffs have you had any expeirence there?
Christopherp is offline   Reply With Quote
Old 05-14-2009, 09:32 AM   #19
Renault_Tech
A rear exhaust engine will always be better than a side exhaust but you should be sure to tell them the added cost they will incure (Pipe, rear exhaust manifold and bump box, and battery) before telling them to throw away their standard motor. They Put the side exhaust engine in most Ready-to-Run cars to make it cheaper and so the car is ready to run out the box, ala pullstart. With that said most of the Kyosho motors are crap but he should keep it at least until he gett the hang of tunning and troubleshooting it. Then upgrade when hes ready to race seriously.
Kyo83 is offline   Reply With Quote
Old 05-14-2009, 03:50 PM   #20
Yeah i started typing that all up when the pc froze and i couldnt be bothered starting it up again. It is more than just the engine. clutch, starter box, pipe, manifold, engine mounts all come into it. Aswell as upgrading the ring gears on the diffs as they cast items strip. Replace them with the steel ones.
Old 07-10-2009, 09:20 PM   #21
runenetti's Avatar
Default Thanks
Turns out twas rich still n now i leaned it the issue is resolved. Thanks heaps for the reply's.
What engine would be best to replace the gxr with? How much modification is involved with the novarossi being a rear exhaust? How do RB engines stack up, n do they fit the fwo6 easily
runenetti is offline   Reply With Quote
Old 07-11-2009, 02:34 AM   #22
Any .12 motor can be fitted. If you get one with an SG crank (which all decent motors are fitted with) you will need a 3D clutch such as Kyosho part number VS035. If you get a bump start motor you will also need a starter box. Engine mounts will be needed also. Here are two engines i recommend for you and what will be needed.
Novarossi N12TS1/RT
- Engine mounts
- 3D clutch
- Rear exhaust system EFRA 2601
- starter box and batteries
RB C12
- Engine mounts
- 3D clutch
- use your exhaust system as the C12 is a side exhaust pullstart motor.
Old 07-12-2009, 04:06 PM   #23
Bundy_Bear's Avatar
Renault_Tech:
Where did you get the engine mounts, centex clutch and clutchbell from? And would you have the part numbers to make it easier?
Thanks in advance!
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 07-12-2009, 06:32 PM   #24
Originally Posted by Bundy_Bear View Post
Renault_Tech:
Thanks in advance!
Hey Bundy, i got the clutch and clutchbell from one of the guys at my club but i can give you a list of part numbers to help you.
Engine mounts for bumpstart motors - VS030
Centax clutch - VS035 (comes with clutchbell and you only need pinions)
http://cgi.ebay.com.au/KYOSHO-3D-CLU...3286.m20.l1116
Thats the cheapest one i could find for you. RCHobbies has these for $200
Old 07-13-2009, 02:22 AM   #25
Bundy_Bear's Avatar
Renault_Tech:
Thanks for the info... what teeth steel gears are you using? And do you know if the 3D clutch off my V1RRR Evo WCE will work? Guess the clutchbell might be different!
MissMooRC Racing
Old 07-13-2009, 02:38 AM   #26
The clutchbell wont work. You might be able to use the RRR clutch and just replace the clutchbell. I originally bought the Sirio power clutch and the only part that didnt work out was the clutch bell. Im using 21/27t pinions,
Old 07-13-2009, 04:28 AM   #27
Bundy_Bear's Avatar
Cheers mate
What about the steel crown and pinion gears?
Thanks in advance!
MissMooRC Racing
Old 07-13-2009, 05:53 AM   #28
They are dirty drug money items. RC hobbies has them for $110 a set and you need 2 sets but i can get steel 40T sets for $75 from my LHS and mail them to you if you cant find them locally. They are a discontinued item and hard to find. RC champ didnt even have any....
Old 07-13-2009, 09:47 AM   #29
So what are the ring gears made of? They feel pretty heavy so I thought they were already made of Steel....or is it that the ring gears on the FW-06 are different from the ring gears on the FW-05RR?
Old 07-13-2009, 03:49 PM   #30
Bundy_Bear's Avatar
Hi
Thanks for that info... Why the hell would Kyosho discontinue such an important upgrade!
Ohhh well, looks like belt drive cars are the only option now!
MissMooRC Racing
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
