URGENT---->Need help with HUDY tire truer >
Old 07-14-2008, 07:56 PM
Default URGENT---->Need help with HUDY tire truer
I bought a Hudy Excellent tire truer online but I'm not sure if it's functioning correctly. I'll describe it for you all and hopefully someone can tell me if it's ok or not.
I switched it on and it appears to work fine meaning it goes from left to right and back again. Fine everything is ok with that, but when I try to switch it back to move again to the right from the farmost starting position, it didn't move and the wheel didn't spin. So I clicked the switch back to neutral and then back to move right and it moved.
Q1. Is it normal it to not move right away after completing a full cycle?
During the move right across the tire, when it was a few mm past the tire, I flicked the switch to make it move back to the left and the wheel started stuttering and didn't have the smooth rotation it normally has.
Q2. Is it possible that I switch it too fast in reverse?
Please all answer as much as possible as I only have a few days to return it. Thanks.
jigga21 is offline
Old 07-14-2008, 08:08 PM
#2 no i dont think you fliped it to soon sometimes itll doo that because of the rubber getting on the screw you shouldnt have to flip it to come back
#1 that is normal mines an older version and it does the same thing it like a reset for the system
motojon is offline
Old 07-14-2008, 08:22 PM
motojon - thanks for the answer. I didn't set up the travel length so when it passed the tire i didn't want to wait for it to go all the way to the end so I flipped the switch to reverse it and it started the stutter. I stopped it, started it again and it stuttered again. Once more I did the same and it worked normally.
jigga21 is offline
Old 07-14-2008, 09:04 PM
Trader Rating: 94 (100%+)
Check here too.
http://www.hudy.net/xhudy/products/p...7&kategoria=62
Nitro-mech is offline
Old 07-14-2008, 09:14 PM
CREWMAN's Avatar
Trader Rating: 19 (100%+)
I just got one of these truers, what power supplys do you guys recomend to use
CREWMAN is offline
Old 07-14-2008, 09:31 PM
I'm using this one - Ofna Power Supply 9-14V 18A 110AC - trying to figure out if that is the problem.
jigga21 is offline
Old 07-14-2008, 09:35 PM
Trader Rating: 28 (100%+)
Try using the battery on your car, or a larger power supply and see if that solves your problem. I have had stuttering problems when using a power supply that is too small. I would not use a supply that has less than 30 amps.
Scott Fisher is offline
Old 07-14-2008, 09:51 PM
Scott had it. I was about to reply when I saw this. I used my portable power supply and it worked like a charm. I thought the power supply put out more power but when i checked the specs the light bulb came on. Thanks guys, I can sleep easy now.
At least people know later if someone new has this problem.
jigga21 is offline
Old 07-15-2008, 04:07 AM
cdelong's Avatar
ditto.... run it off a 12v car battery for best results. Most power supplies do not supply a steady enough current when the truer experiences a good load when cutting. My generator even gives my Hudy fits when running it off the 12v line because it is only rated at 15a of current.
cdelong is offline
Old 07-15-2008, 08:13 AM
CREWMAN's Avatar
yea i was reading the manual and it say at least 25 amps 14-16v!
CREWMAN is offline
Old 07-15-2008, 09:41 AM
You can run a truer from a lower amp power supply (like 15)
anyway, slow down the speed of the side to side motion if you are on less than a car battery and you will still get a good cut. The fastest speed puts quite a bit of strain if you're cutting 2-3mm of tire off.
Brian Bosley is offline
