Old 09-19-2002, 08:10 AM   #1471
NTC3NUT's Avatar
Wasn't me. Not yet.
NTC3NUT is offline   Reply With Quote
Old 09-19-2002, 08:15 AM   #1472
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I had that happen to my KO Mars.... I guess that is a weak point.
mike_Webb is offline   Reply With Quote
Old 09-19-2002, 09:41 AM   #1473
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Originally posted by ME-student
Boomer: can you explain "the exhaust tube is way too big and in the wrong place. . ." i want to know the rule before i try it
thanks.
there is a sound rule (6-13)- 85db at 33' distance.
I was mistaken about what I was thinking. I thought there was a rule about the size of the exhaust outlet pipe, but I can't find it. The outlet pipe on that thing is HUGE.
There is a rule, however, that the outlet pipe must be "a round, constant diameter tube, with the end cut at 90 degrees to its centerline" (6-14). I don't think that they would interpret this to allow that pipe. The "outlet" pipe goes from the front of the main chamber and then is welded, making it not constant size.
I only wonder one thing - does it work?
After that - who cares! I don't really run many sanctioned races, and if I did, I would just put on a pipe that fit the rules. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 09-19-2002, 10:02 AM   #1474
EngenZerO's Avatar
heh...got my new avatar working
r2-d2 0wz j00
"My impressions of the event are that in the 200mm class, Michael Salven and Barry Baker are just about tied in a dead heat. Michael has a tremendous amount of experience at gas racing, but either all these electric guys are also quite talented (and quickly learning) gas racing, or they’ve somehow found a way to run with the best of the best in on-road fuel racing."
heh...even serpent has to admit that the NTC3 is one sweet machine for speed...
EngenZerO is offline   Reply With Quote
Old 09-19-2002, 06:54 PM   #1475
InitialD's Avatar
Ummm, lesson learnt is never use a KO Tx/Rx... especially if you're a leftie
Old 09-19-2002, 06:55 PM   #1476
InitialD's Avatar
It is indeed a fast car... Basically because the car is very much lighter compared to the snake.
Fast, yes... For longevity, questionable...
Old 09-19-2002, 06:56 PM   #1477
mike_Webb's Avatar
I actually put it in my big hauler bag and when I picked it up with the shoulder strap I heard a crack and figured it was my car body...... got home and grabbed the radio by the wheel to pull it out of the bag and out came just the wheel . Opps....and unfortunatly the wife was there to see that and knew that I was going to have to get a new radio .
Old 09-19-2002, 06:57 PM   #1478
mike_Webb's Avatar
We will see in the final... I think that the AE Team went back and made some changes so that they will not have the same thing happen to them as they did at the nationals.
That 705 is looking good though..... it is going to be tough next season choosing
Old 09-19-2002, 07:40 PM   #1479
EngenZerO's Avatar
indeed...I am intrested to see mugens machine in action...and see what yokomo and koyosho also have lined up...
Old 09-19-2002, 08:22 PM   #1480
Registered User
Send a message via AIM to bbntc3
Hey guys I spoke with James Hook at ACE Racing about that funny looking pipe on ebay, its a replacement pipe for side exhaust engines of course. He is going to send me a pipe design to try and work with, for a replacement pipe for the rear exhaust engines, he's also going to help me with a modified pipe for rear exhaust to go down the center and exit out the rear of the car like I use now. But of course it will be outlaw class pipes only, I'll keep you guys informed! BB
bbntc3 is offline   Reply With Quote
Old 09-19-2002, 09:27 PM   #1481
InitialD's Avatar
Woow Mike, good tip on the radio I'll see if I can polish my act together and get a new 705 by Christmas
Old 09-19-2002, 09:34 PM   #1482
InitialD's Avatar
I don't see any changes from the stock out of the box NTC3 that they have used going by NTC3NUT's pics... Perhaps only the rear toe links and the mods on the exhaust pipe and maybe longer screws here and there...
I'm afraid the car is still fragile...
I'm having some reservations with the 705 as well. Although I don't use front gear diffs on my existing setup (running one ways), I find that the 705 not being compatible with front gear diffs is a little alarming... Second reservation, price
Old 09-22-2002, 01:36 PM   #1483
NTC3NUT's Avatar
Default Worlds
Hi guys. Spent the whole day at the Worlds Saturday. I've got 100+ pictures, and 2 hrs. of tape. I should have most of the photos posted by tomorrow. I'm sure you all know by now:
235mm- 1st-Brian Berry- Serpent
2nd-Josh Cyrul- Mad Dog(?)
200mm- 1st-Mark Pavidas-ASSOCIATED!
2nd- Josh Cyrul-Trinity
Barry Baker hooked me up with lots of photos of his car, and the other team guys where just as helpfull. Who rules the World?
ASSOCIATED DOES!
Old 09-22-2002, 03:42 PM   #1484
NTC3NUT's Avatar
Default Worlds
Here's the man, 200mm World Champ.
Old 09-22-2002, 10:37 PM   #1485
NTC3NUT's Avatar
Default Worlds
Can anyone tell me where to go to post all my Worlds pictures at once? I have about 100. Getting them to fit these website threads is a MAJOR pain, not to mention posting them one at a time. Any help would be appreciated. Thanks in advance
