Old 09-18-2002, 07:40 AM   #1441
mike_Webb's Avatar
Send a message via AIM to mike_Webb
NTC3NUT.. any info you can give us for the rear toe mod? Take more pics of Bakers car and get his setup if you can
mike_Webb is offline   Reply With Quote
Old 09-18-2002, 09:56 AM   #1442
Trader Rating: 16 (100%+)
NTC3NUT............where can I find out more info about the Team Associated (NTC3) time slip for the qualifier or practice...?
Thanks......
Rookie Solara
Old 09-18-2002, 09:57 AM   #1443
Originally posted by EngenZerO
heh...this is how I did mine...$1.75 fix...
oz
I knew you said that 100 times before......but can you tell me one more time about the size of the brass tube and the screw that you are using......? Are they standard or Metric..? 3mm by...?
Thanks....
Rookie Solara
Old 09-18-2002, 10:23 AM   #1444
InitialD's Avatar
Thanks......
Rookie Solara
You can get them on mytsn or more detailed as posted by Jason;
http://www.jlapracemanager.com/PC/Tr...%20Listing.HTM
Old 09-18-2002, 11:14 AM   #1445
EngenZerO's Avatar
Rookie...
brass tube (5/32 get this from LHS) ... but here is a pic at towers...
http://www2.towerhobbies.com/cgi-bin...1&I=LXR824&P=7
4 servo washers for top shock tower ... pic at towers ...
http://www2.towerhobbies.com/cgi-bin...1&I=LX2767&P=7
4 dubro 1 1/4 screws std ... pic at towers ...
http://www2.towerhobbies.com/cgi-bin...1&I=LXD999&P=0
now my pics....
EngenZerO is offline   Reply With Quote
Old 09-18-2002, 12:07 PM   #1446
mike_Webb's Avatar
New Rear Exhaust Mod
Well what do you think this will do ????
I had some spare time on my hands today.
Old 09-18-2002, 12:12 PM   #1447
EngenZerO's Avatar
fire her up
Old 09-18-2002, 12:15 PM   #1448
mike_Webb's Avatar
I just ran it down the street and back.....about 20 times
it was sooo funny... it was actually quiet... My engine got to about 230 and it was pretty fast on the low end.... but I am not sure about the top end since I can not open it up on the street (not paved yet). I have to make one mod to it tonight and it might be interesting to see it run this weekend.... If this legal by the way????
Old 09-18-2002, 12:29 PM   #1449
EngenZerO's Avatar
nice,
Legal as in roar rules? What other mod do you have to do?
Old 09-18-2002, 12:33 PM   #1450
NTC3NUT's Avatar
Default Worlds
Mike, Here's a copy of an earlier post of mine reguarding the rear toe mods:
They are running Nitro Shoes, 40 front/40 rear, 28mm front/30mm rear. Travis's car was the only one with a set-up similar to the books, the rest of the cars where set-up like they where for the Nat's. The toe-links where newly made. Bill Easton gave me this info:
-tie rods longer than stock (did not specify), with freshly cut threads, they did not roll the threads to make them smoother like the stock/factory team tie rods, more bite this way
-not lock nuts, just standard nuts, but all 4 also freshly
drilled and tapped, 2 with reverse threads of course
-drilled and tapped all 4 of the 6/32 ballends to accept
2/56 buttonhead screws, then slotted the stock ball cups
to allow proper up/down travel
I know it seems like alot of work, but if they where all using it
that must be the way to go (I guess we'll see, right?). I'll drop you a quick note tomorrow on the dual chamber mod.
I think you could easily duplicate it with a set of longer Lunsford tie rods, and a good set of captured ball ends. If the tie rods where just long enough to "bottom out" you may not even need the nuts. What do you think? I'll go out and get the different length tie rods, but my LHS is out of quality captured ends (I've already been checking into this). Anyone have a preferance for their captured ends? I've heard Serpents are good, what about Ofna or GS?
NTC3NUT is offline   Reply With Quote
Old 09-18-2002, 12:36 PM   #1451
mike_Webb's Avatar
Thanks NTC3NUT
I need to go to Home Depot and get some Copper Pipe to make the top stretch that conenctes to the Header a little longer... It fell out while driving it. Other then that I think this should work. The Race this weekend by me is ROAR Rules Apply.... I will probably have to put the other pipe on for it.
Old 09-18-2002, 01:25 PM   #1452
mike_Webb: i was about to do the same thing that you did. please let me know how it perform on a track. thanks. it should be ROAR legal too...
ME-student is offline   Reply With Quote
Old 09-18-2002, 01:40 PM   #1453
NTC3NUT's Avatar
Did you guys see the crazy pipe this guys offering on Ebay? I know were not supposed to post Ebay links, but please make an exception in this case, it's for entertainment purposes only!
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=1768211184
What do you guys think? Is it worth me wasting $20 just to see it in person?
Old 09-18-2002, 01:52 PM   #1454
EngenZerO's Avatar
isn't that for a side exhaust set up though?
Old 09-18-2002, 02:15 PM   #1455
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
It's definitely "outlaw" - it's not ROAR legal - the exhaust tube is way too big and in the wrong place. . .
I wonder what the pressure wave does with it. . .usually the shape is designed to work with the pressure waves that the motor creates.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
