Old 09-04-2002, 11:02 AM   #1291
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I have the Ti Turnbuckles on the whole car. Funny thing I did was try some Blue RPM Ball Cups ont he rear. They are the same as the Grey but for some reason when I try to adjust the Toe it just comes off the ball. With the grey cups I can adjust all I want. I guess the Blue Cups are tighter.
mike_Webb is offline   Reply With Quote
Old 09-04-2002, 02:28 PM   #1292
rayhuang's Avatar
Default Solid links revisited
Hey guys,
The solid links I was talking about before have been working great. But, they will pop off in a crash. Its good because the car is not broken and can continue with a smart marshalling. But the reason we have not started selling them is there is a lot of interest in using a captured ball end set-up. I am trying to build a set for this weekends Midwest Race in Mentor, Ohio, but have been so slammed. I hope to have them ready for Saturday morning practice.
I'll keep everyone posted on the results.
Ray
Old 09-04-2002, 03:54 PM   #1293
NTC3NUT's Avatar
Default tie rods
We were going to try locknuts also, like the little Trinity or Associated ones, but besides finding the right thread you also have to find reverse threaded nuts. The only solution we came up with was using undersized plastic nuts, from Buds or RPM, that way the thread wouldn't matter. We thought something with an ID size similar to the front turnbuckle, so that it would be really tight. (Try putting a regular size RPM ball cup on the rear tie rod, you'll see what I mean.) The only problems we could see with this was that after you set your rear toe in with the stock set-up, theres not much (if any) exposed thread left on the turnbuckle (I'm using the FT's). We thought about cutting back the stock RPM ballcups to make room, but thats kind of defeating the purpose, isn't it? I guess I should try it out and see, I already have the nuts and a few sets of extra turnbuckles. My best solution so far has been to CA the ball cups on, and keep an extra made up set in my pit box. If you use thick "slow dry" CA, you have time to put them together and set your toe-in befors it dries.
NTC3NUT is offline   Reply With Quote
Old 09-04-2002, 05:53 PM   #1294
The rear turnbuckles are 3.5mm.
Superk...did you find the details yet. I've been REAL buisy.
sqeezit is offline   Reply With Quote
Old 09-04-2002, 05:54 PM   #1295
mike_Webb's Avatar
I just went to Home Depot witht he Turnbuckle and 3.5 does the trick... to bad they didn't have any nuts in!!!!!
Old 09-05-2002, 12:17 AM   #1296
superk's Avatar
No sqeezit, I was too busy working and schooling! I run my car last week and it seem ok...still I don't like the bubble in my tank that much. Also...why do I have to put a piece of plastic in the tank??
superk is offline   Reply With Quote
Old 09-05-2002, 12:17 AM   #1297
superk's Avatar
Oh..also I bought a couple set of Ellegi foam tires
26mm 40Shore and 30mm 40 shore
and
(power line)26mm 42 shoe and 30mm 40 shore
I am going to have my friend true it but not sure what is the starting size of these tire?
I'm getting this car ready for Toronto Touring car Champianchip on Sep 15!!
Old 09-05-2002, 07:26 PM   #1298
Registered User
Send a message via AIM to bbntc3
Has anybody tried captured ballends on the rear of the NTC3 yet if so what did you use, and how? Thanks BB
bbntc3 is offline   Reply With Quote
Old 09-05-2002, 07:32 PM   #1299
Kyosho and HPI sells eyelets for ballends. Use a cone washer so that the end if popped off will not completely come off. Look at your shocks but with a big washer between the screw and the ball/plastic end.
I thought you guys were having problems with the plastic end stripping on the turnbuckle when you get a compression ht on the rear wheel?
The captured end will still do that, just the link won't fall off.
Sydewynder is offline   Reply With Quote
Old 09-05-2002, 07:46 PM   #1300
WF...exactly,it seems like in this situation one fix leads to another problem.If the captured ball end is used AND you use a nut or something else to stop the compression...what happens next?
blimey is offline   Reply With Quote
Old 09-05-2002, 08:10 PM   #1301
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
It reduces the capacity of the tank to make it legal. Why AE didn't make the tank legal to begin with . . . well, I think it's stupid anyway
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 09-05-2002, 08:13 PM   #1302
Boomer: are you still interested in the Centax clutch? i will be at revelation this sat, if it doesn't rain that is....
ME-student is offline   Reply With Quote
Old 09-05-2002, 08:16 PM   #1303
stefan's Avatar
Send a message via AIM to stefan
It'll fall apart.......
stefan is offline   Reply With Quote
Old 09-05-2002, 08:29 PM   #1304
you obviously don't own one
Old 09-05-2002, 08:30 PM   #1305
coastaltony's Avatar
AE's new tank for the NTC3 is not
legal?
It was a fix for my car, smooth as
butter
Thanks Barry
coastaltony is offline   Reply With Quote
