Old 08-14-2002, 11:08 AM   #1156
Registered User
Send a message via AIM to bbntc3
RC INfo: If you buy the nonpull kit all the parts you need come in the kit, no hidden extra parts need to be bought like the reflux, which does not come with the sg crank nut.
For the toe in problems I use the rpm long ends drilled to fit turnbucklesand the toe prob, have all but gone away, if anybody has a captured ball end deal for the rear, post it, I would like to go that route I think. solid rear links would be ok I guess and 2 degrees does seem to be the ticket, I think it would be hard on the arms though, captured probably just as hard but atleast like someone stated you could at least adjust for molding errors.
Coolrcdad: Are you sure your turning the right screws on the 2sp. Thats to many turns I think your turning the wrong screws maybe, I have seen that alot here.
bbntc3 is offline   Reply With Quote
Old 08-14-2002, 12:08 PM   #1157
rayhuang's Avatar
Default Keep feedback coming!!!
bbntc3, Captured ball ends sounds good, but again, if you keep them from popping off, then maybe you break an arm or pull the screw out with the ball end. Either way race over. Also-our design is not molded, they are solid when built, but are adjustable too!!! They just happen to come preset to 2 degrees!!!
Ray
Old 08-14-2002, 12:16 PM   #1158
rayhuang's Avatar
Like bbntc3 say-maybe the wrong screws!! If you are loosening the Silver colored set screws in the middle of the shoe, then you are definately adjsuting the wrong screws!!! You need to be adjusting the two black screws that are on the ends of the shoes.
Old 08-14-2002, 12:35 PM   #1159
Registered User
Thats cool Ray! Let me know when they will be for selll I 'll take a set add me too the list! Thanks
Old 08-14-2002, 12:41 PM   #1160
Registered User
Hey Ray I forgot to ask, are you guys working on the steering end? Theres alot of room for improvement there! Thats about the only other weak link in the car I think! I also think it would be cool if someone came up with a pivotball with a thin locknut design. It would stop the same prob. with the pivot balls being drove in to the arms, or the pivotballs backing in and out. The a-arms would just have to be trimmed alittle to compensate for the locknut. I know that would be harder on the shocktowers and the hiingepins but worth the risk!
Old 08-14-2002, 12:55 PM   #1161
does anyone have a fix for the shock tower coming loose on the ntc3? i have tried a 3mm screw in the middle of the shock tower but it simply wont stay tight very long.any tips would help, thanks.
bigbob is offline   Reply With Quote
Old 08-14-2002, 01:01 PM   #1162
Registered User
Read through the back post bigbob there a couple tower fixes in here. I use studs and lock nuts on 4 points on the towers and no more shocktower troubles.
Old 08-15-2002, 03:13 AM   #1163
thanx mate!!
RCinfo is offline   Reply With Quote
Old 08-15-2002, 05:47 AM   #1164
hooked_on's Avatar
Does anybody know what happened to all the NTC3's at the Nationals in the US last month as i would like to address this issue with my car? And not a general answer "they all failed cause AE are shit!", that i am not after i would like some in depth input please.
Cheers
H-O
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 08-15-2002, 11:56 AM   #1165
Registered User
[ FUELTANK ] was AE's troubles at the nat. At least thats what Baker bitched about all weekend. Just adapt a serpent or mugen fuel tank and the fuel troubles are gone! BB
Old 08-15-2002, 05:41 PM   #1166
Registered User
OB42TC3's Avatar
That and the gearboxes stripping. I shim the pinion in the additional shim, and I don't run the 6 tooth drop. Also use the yokomo 1-way. I also use a little white ligthning or other grease on the gears. The gear problems have been isolated to cincy only for me.
OB42TC3 is offline   Reply With Quote
Old 08-15-2002, 05:54 PM   #1167
glitch44's Avatar
MeStudent,
How's it going ? I met you last Sat at Crystal. Are you still bringing some clutches with you and do you have any 27 teeth pinions for the K clutch? I'll be at Crystal on Fri afternoon/night . I wont be able to come down on Sat. Let me know. I still want a clutch. Hopefully, I'll see you on Fri.
Dave
glitch44 is offline   Reply With Quote
Old 08-15-2002, 06:22 PM   #1168
Registered User
OB4: 6 tooth drop? Explain, Are you talking about 6 tooth drop in first and second gear spurs? Thats right Dennis Richey also stripped a pinion gear at the nats. I think Dennis is working on brass pinions for the car in the near future. BB
MEStudent: So I guess it's safe to say the K Factory clutch system will also have to use their second gear instead of the Stock Ae gears?
Old 08-15-2002, 06:36 PM   #1169
Send a message via AIM to ZER01
I would repost my front shock tower fix pics but I had to format my hard drive and forgot to keep all my pics. I used 2 Du-Bro 1-1/4" 4/40 screws with the TC3 spindle bushings and yet have had a problem.
ZER01 is offline   Reply With Quote
Old 08-15-2002, 06:38 PM   #1170
Registered User
OB42TC3's Avatar
Lots of guys fried the gears. I think its mostly fixed by shimming, and everyone in the top mains was running the 6 tooth drop if not everyone in all the mains. It seemed as though there was a good correlation between 6 tooth drop and frying gears. Even at the MWS series race there when it was much cooler. That's actually the reason I will end up with a Centax, for cincy so I can up the engagement point to where I can get away with a 24 tooth first gear.
