Old 08-06-2012, 06:20 PM   #9391
Suspended
What motor are you running texair ??? Did you try lowering your roll center by trimming your arm mounts??
bertrandsv87 is offline   Reply With Quote
Old 08-07-2012, 06:38 PM   #9392
Hyde's Avatar
Originally Posted by texair View Post
Mine will on a smaller track that I ran at. Once you get to a bigger layout your done. I wasn't getting blown away but the advantage that the new cars have was obvious.
I would've thought it was the opposite, since shift cars have torque steer and belt cars don't, but I always liked the punch shift cars have out the corners especially entering the straight. Im going to get a NTC3 soon.
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 08-08-2012, 09:37 PM   #9393
Suspended
Smile
I am currently building my ntc3, and I am putting ofna diff lock lube on the all my clutch shoes and two speed shoes and bells... Anybody ever tried that before? It makes the surfaces pretty tacky, which should stop that endless slipping that AE clutches are known for.... Can't wait to try it guys.....
Old 08-09-2012, 07:28 AM   #9394
I'm running an older Nova Rossi .12 that I got at the local track. The car handles beautifully with my current setup but you can see where newer cars handle better in faster technical areas of the track. I still have a few tweaks left but I'm not expecting to blow away the serpents xrays and the rest it just won't happen with the ntc3.
texair is offline   Reply With Quote
Old 08-09-2012, 09:16 AM   #9395
Suspended
Smile
I am running a jlr .12 AB mods, and I expect to blow by everybody else in a few short Weeks once I am done buildimg... The corners have me worried more than the straight though...
Old 08-10-2012, 11:30 PM   #9396
Hyde's Avatar
Why do the corners have you worried? You should work on a good setup..Im going to have a lot to learn about when I get mine in
Old 08-13-2012, 10:45 AM   #9397
Suspended
Cool
The corners have me worried because I trimmed my arm mounts alot, and I raised the shock towers just so I can further lower the roll center. I don't know how that is going to affect the car. I had good results with similar changes to my tc4 , and hope it will be the same with the Ntc3....
Old 08-18-2012, 01:43 PM   #9398
Hyde's Avatar
I have some questions, what's a good handling 200mm body? Also what tire shore will get me in the ball park for club racing in a parking lot?
Old 08-28-2012, 03:26 PM   #9399
Hyde's Avatar
What was weak about the version1 rear suspension? Was it just the shock tower or was it the rear toe-links? Will "the fix" make it handle a little abuse?
Old 08-28-2012, 04:00 PM   #9400
azeroth's Avatar
Trader Rating: 20 (100%+)
yes the fix will help on both ends on version 1 cars as it normally rips the shock towers off the diff housing
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 09-05-2012, 03:42 PM   #9401
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
I've got two cars and a crapload of parts for sale.
http://www.rctech.net/forum/11157247-post7266.html
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 09-05-2012, 03:42 PM   #9402
R3VoLuTiOn's Avatar
Old 04-23-2016, 11:30 PM   #9403
Suspended
Don't give up on the Ntc3 just yet !!! Ntc3.2 is fast.....
Old 04-25-2016, 01:11 AM   #9404
Aphinity's Avatar
Send a message via ICQ to Aphinity Send a message via AIM to Aphinity Send a message via Yahoo to Aphinity Send a message via Skype™ to Aphinity
Oh yeah? Do tell! I have one and could never make the thing competitive. Way too twisty through the straights with the shaft drive.
Aphinity is offline   Reply With Quote
Old 04-25-2016, 10:51 AM   #9405
Suspended
If you run diffs front and rear, then it will be difficult to keep the Ntc3 going straight... With a spool/lcd combo up front, it's fairly easy to go straight...
