Old 05-25-2009, 03:17 AM   #9286
Raced this thing against the new xrays, serpent, kyosho's last weekend. This was my first club event in years. The car was quick enough to get me to the a main. However my old nova mt12 just didnt seem to have the top end to get me in the top 3. Overall, I am very impressed with how competitive this car still is for me.
I was almost hoping to do poorly, as to have an excuse to by new equipment. Maybe soon..
Jason
thewood1987 is offline   Reply With Quote
Old 05-25-2009, 11:38 AM   #9287
bhambrent's Avatar
Jason
Thats good to here, I have a old ft ntc3. And have been thinking about getting back into racing, but did not want to buy a new car parts ect. ect..
If all I would need is a hot engine. I meet get back in.
bhambrent is offline   Reply With Quote
Old 05-25-2009, 11:14 PM   #9288
Motor's have come a long ways since I was gone. I spread the gearing out to a 6split, a bit more motor and itll probably keep up on the straights. The infield is not a problem as of yet. It still rides on rails.
Old 05-26-2009, 03:51 AM   #9289
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
i think im going back to the 4 tooth split.
the sirio chews the diff gears every 5 race days
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 05-26-2009, 06:27 AM   #9290
I assume you are using the white diff gears? If your using the black gears, switch to the whites. If you are using the whites then that sirio must have gobbs of power. I remember reading somewhere that with those real powerful motors, the most you can run is a 5tooth split without compromising diff gears. 5 split sounds wierd I know, I think they were running a 6 split on the tranny and 5 split on the pinions. It sounds goofy, but it is supposed to mesh well.
Old 05-26-2009, 01:23 PM   #9291
R3VoLuTiOn's Avatar
yeah, havent been using anything but the white gears. even when shimmed to high hell it still strips them.
and its only the 3 port sirio evo3...
i cant imagine the 5
Old 05-26-2009, 01:27 PM   #9292
I refuse to go through and look at 620 pages for an answer, so I'll just ask it. Does the Ver 2 run/handle better than the Ver 1?
"Fast is fine, but accuracy is everything" - Wyatt Earp
"Slow is smooth, smooth is fast" -Sgt Bob Lee Swagger
"I feel safer on a racetrack than I do on Houston's freeways." - A.J. Foyt
“I love this kind of racing, but these guys sure change their personalities in race mode. They’re like Doberman pinschers with a hand grenade in their mouths” -Boris Said
NitroVal is offline   Reply With Quote
Old 05-26-2009, 01:34 PM   #9293
Company Representative
SweepRacingUSA's Avatar
I bielive just stronger, car handles fine with Ver1
SweepRacingUSA is offline   Reply With Quote
Old 05-26-2009, 02:23 PM   #9294
lil-bump's Avatar
Trader Rating: 83 (100%+)
Version II is more durable. Vesion II is more in line with current production rear ends. I would make the switch. I've never ran version one but I heard the rear tow links were notorious for coming loose during crash.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 05-26-2009, 03:15 PM   #9295
Mine is a version one, and luckily I havent had any crashes with it yet. I've considered making the change but havent really had a purpose to yet
Old 05-26-2009, 04:14 PM   #9296
Hi, I use JLR, no much problems with stripping gears, I use 54/48 and 20/26 or 21/27. Good shimming and before run I allways apply PTFE lubricant spray into gear box. It helps to me. Generaly I change gears 1 time in a season - about 10-12 one day races per year - and not cause of strip but they are worn.
majk is offline   Reply With Quote
Old 05-26-2009, 11:29 PM   #9297
I just swapped ver 1 out and installed ver2. Overall, it just makes more sense. It is sturdier. If you hav'nt had the pleasure of the rear toe linkage popping of from being rear ended or hitting the wall, then keep ver 1 until you do, and you will appreciate it more.
Old 05-27-2009, 06:23 AM   #9298
..............The Ofna LD-3 has steel diffs and they will fit on a Nitro -TC3 no more stripped gears. I put a big block .28 in my TC-3 and was stripping diff gears all the time until I replaced the associated diffs with the LD-3.
nitrohead5300 is offline   Reply With Quote
Old 05-28-2009, 12:23 AM   #9299
Good to know, ,, where can one get there hands on these metal gears?
Old 05-28-2009, 09:58 AM   #9300
Ofna, Nitrohouse
