Old 06-01-2007, 08:32 AM   #9136
IOwNMkeG's Avatar
Its For Sale RTR ppl 300 SHipped its in the Rc Sale/Trade here is link
http://rctech.net/forum/showthread.php?t=165655
Buy IT!!!!!!!
Frank Harper
IOwNMkeG is offline   Reply With Quote
Old 06-01-2007, 05:55 PM   #9137
NitroMaxx3.3's Avatar
Trader Rating: 19 (100%+)
my ft threaded shock set just came in and im to the part were you but the plastic end on the shock shaft(the bottom black piece that the screw goes through) im having a hard time gettin these on ther pretty tough. i dont want to damage the shocks though. what do you guys do to get these on. thanks.
NitroMaxx3.3 is offline   Reply With Quote
Old 06-01-2007, 09:34 PM   #9138
gearhead13's Avatar
What I do is pre-thread them with the same size screw beforehand.
Then when you are going to screw them on, grip the shaftat the end of the threads with wirecutters so as not to damage the shaft.
You can also grip the shaft with 'softjaws' :
ie: pliers with aluminum pieces between the shaft and pliers
the aluminum wont mar the shaft
Serpent
Xray T2
OFNA/Picco red dot
Picco 2607 pipe
Dynamite race 20%
gearhead13 is offline   Reply With Quote
Old 06-02-2007, 06:50 AM   #9139
thanks for the info gearhead. i had a pack of hobbico foam rubber pad laying around. i cut a small square of that to hold the shock shaft with. it worked kind of like a jar gripper.
Old 06-04-2007, 08:29 PM   #9140
Send a message via AIM to empaint3
Hey guys, I have a question about tuned pipe and manifold sets. I will be getting an O.S. 12 TZ 3 port but I need a tuned pipe for it. I am leaning towards the O.S. 1040 since it is designed for the .12 engines that they make, but I need a manifold for it. I believe it is side exhaust and I'm just not sure which ones will fit and which ones won't. What are some of you guys running? Any suggestions are appreciated. Thanks.
empaint3 is offline   Reply With Quote
Old 06-07-2007, 06:57 AM   #9141
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Not to hijack the thread, but anyone looking for a NTC3, 2nd car, or parts car, please check out this link - http://www.rctech.net/forum/showthread.php?t=166995
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 06-09-2007, 04:53 AM   #9142
paul73rc's Avatar
Trader Rating: 5 (78%+)
Hi there, I have recently purchased a 18 size engine with a SG shaft for one of my NTC3's. I was thinking of putting this 18 engine into the car just to bash around on the street, however I was just wondering does anyone believe I should not be putting a 18 engine into a nitro tc3.
So, my question is. Has anyone put a 18 engine into their NTC3? If so how did it go?
Thanks, hope to get some replies soon so I can put the engine in.
paul73rc is offline   Reply With Quote
Old 06-09-2007, 05:59 AM   #9143
Danielson2's Avatar
Hi I have just started racing a basic Side Exhaust Team NTC3 again and there is a lot of slop in the steering. Most of it seems to be in the rack, my question is what's the best way to remove it. I see K-Factory do a rack but is it a good upgrade or is there an easy fix ? Also what would be the best option parts to put on the car. I know this has probably been asked but I don't know where to find it. Lastly is there any good setup info on the NTC3 I am running on a fairly bumpy med low traction surface with foam tyres. 40 shore work best and rubber also work well but are hard to get them to stay glued on the rims..
Thanks Dan
Danielson2 is offline   Reply With Quote
Old 06-09-2007, 06:33 AM   #9144
yes you can put a .18 in a ntc3. If you do you wont be able to race with it but it is great to bash with if you like speed. most people who run .18's run the O.S. 18tz. You might want to keep diff rebuild kits and gears on handy though, as you also need to do that with a racing .12.
Old 06-09-2007, 06:38 AM   #9145
Thanks Dan
If you are going for upgrade parts, Start with associated threaded shocks, and pick up the spring pack. Do the "fix" which you can find info about it in the search. A centax clutch is also a very nice upgrade if you will be racing. As far as setup sheets, go on team associated's website and you can find different setup sheets for different track condition.s
Old 06-12-2007, 07:04 PM   #9146
Here is my NTC3. I just added a few hopups.
It has a O.S. 12TZ engine
Werks Racing Tuned Pipe
K-factory low CG fuel tank
Associated Lightweight 2 speed hub
Associated Aluminum Center Bulkhead
Associated Aluminum Non Pull engine mounts
Associated Graphite Radio Tray
SMC Intellect RX 1400mah pack
Associated Steel Disk Brake Drive
Associated Aluminum Threaded Shocks
Spektrum DX2
Motor Saver Filter
Lightweight clutch assembly
Old 06-12-2007, 07:43 PM   #9147
wayne's Avatar
just thought I would post something I discovered recently about this car - we all know that the car is rear left side heavy, so I added some weight to the car to "balance it better" - my car is a ntc3 rtr + with a mars-r reciever and a nosram pack and I added a mere 60 grams to the car to shift the balance point toward the center (both forward and to the right) - oh my what a difference! TRY IT!
wayne is offline   Reply With Quote
Old 06-15-2007, 02:37 PM   #9148
twan's Avatar
i just wanted to know what springs everybody is running for a bumpy track. front & rear
twan is offline   Reply With Quote
Old 06-15-2007, 02:54 PM   #9149
i pretty much see everyone running yellow up front. red in back or red all around. im running yellow up front with 60wt and red in rear with 45 wt.
Old 06-15-2007, 06:28 PM   #9150
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally Posted by NitroMaxx3.3 View Post
i guess anyprice cause i cant even find one.
nitro,are you still looking for a tank?..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
