Old 04-30-2007, 09:27 PM   #9106
nitrodude's Avatar
Thing is i said Mcmaster because they have most of everything, but I buy them from a local harwares store, they have most any screw you need.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-30-2007, 09:30 PM   #9107
nitrodude's Avatar
Ok, I just tried it at mcmaster, you have to type SHCS, and the ones you need will come up. They're $5.06 for a box of 100.
Steven Muller
Ronin Speed Parts
Old 05-01-2007, 06:27 AM   #9108
dabro15's Avatar
I bought my NTC3 a couple weeks ago used for $100 off eBay. Its in decent shape especially considering how cheap I got it. I'm in the process of rebuilding it (a general tune-up) and I need some help on a few things. Which shock oil weight in good for the stock shocks (I need just a basic range of appropriate weights)? Also, what diff oil is good for it too?
Any other tune-up suggestions would be great.
dabro15 is offline   Reply With Quote
Old 05-01-2007, 06:49 AM   #9109
nitrodude's Avatar
50 or 60 weight works good, but depnds on track. NTC3 doesnt need diff oil, it has ball diffs.
Steven Muller
Ronin Speed Parts
Old 05-01-2007, 07:19 AM   #9110
cheesewhip's Avatar
Trader Rating: 15 (100%+)
Does it have the version 1 or version 2 rear end? Upgrade to version 2 if you have the older one and save yourself the headache.
TM G4S, AE NTC3 FT, FLM Savage, TRX REVO, Serpent Veteq, Kyosho MP777 SP2 WC, HPI Hellfire, Losi 8ight, Losi 8ight T
cheesewhip is offline   Reply With Quote
Old 05-01-2007, 07:28 AM   #9111
cheesewhip's Avatar
I typically start with trinity 60 weight all around and adjust as needed. I would try to stick with one brand of shock oil as each brand's ratings are different.
Clean the car throughly, make sure all bearings are free, check for chassis tweak... I would just get used to the car first..
Then fuel and tires...
Oh. bodies do make a difference in handling. There's a reason why people run soapbox stratus and soap bar mazda6 in races.
Old 05-01-2007, 04:37 PM   #9112
vikingen's Avatar
Trader Rating: 27 (100%+)
just picked up a half built (and obviously unused) NTC3 team kit.
I've ordered a proline nemesis shell and have an lrp .12 on the way (donation from a friend who is upgrading to an OS TZ) along with an associated rear dual chamber pipe
anything else I need ? foam tyres I am guessing ?
i've no clue.. im an offroader
vikingen is offline   Reply With Quote
Old 05-02-2007, 05:48 AM   #9113
cheesewhip's Avatar
I would start with the stock v rage tires if you have them. They are surprisingly good tires. When you get used to driving an on road car and you want more grip, then I would move on to foam tires.
Old 05-02-2007, 06:13 AM   #9114
dabro15's Avatar
To start off use rubber tires. In my opinion the stock ntc3 tires suck cause mine wore out in no time. There good for starting out cause there cheap and it doesnt matter if you screw them up. But use rubbers for parking lots and practicing then go with foams for racing.
Old 05-03-2007, 01:12 PM   #9115
Originally Posted by cheesewhip
I would buy some plastic, not graphite steering knuckles, a arms, and shock towers as you are sure to break them if you race. Plastic pieces will last longer as graphite parts will shatter even if they give you a slightly better handling.
I would get the stainless screw kit from rcscrewz.com, carbon fiber radio plate from ae, RPM front bumper, a receiver pack, good radio like a 3pk, m8, m11, or helios... upgrade later with spectrum or fasst system.. with metal gear steering servo at least. Oh.. a good, dependable .12 racing engine, not a .15, dual chamber tuned pipe... you know, the essential stuff. A good neutral body, good foam tires... I use the stratus body with k factory foams.
Like the person said before, I would look into getting some k factory parts instead of factory team parts. They are better made, practical, and useful to a degree. But ONLY if you have money left over after getting the essential stuff. Bling is not as important as performance upgrades. Also, remember that even though your local hobby shop is a good resource, they have to sell you stuff to pay their bills.... Even stuff you don't need.
There are other things you can do to your car that really doesn't cost a whole lot but makes a world of difference. Polish the pivot balls. Oil the bearings with trinity royal oil. Polish the kingpins. Change shock oils...
Cheesewhip,
Thanks for your advice. I like to buy at my LHS but here in Brazil nobody sells K-Factory.
Yokomo BD7 2016/Lrp 4.5T/Ko Propo
Yokomo BD7 2015/Lrp 10.5T/Ko Propo
Wascheck is offline   Reply With Quote
Old 05-06-2007, 05:40 AM   #9116
vikingen's Avatar
all painted.. engine and pipe to go in next
Old 05-06-2007, 06:43 AM   #9117
Send a message via ICQ to markallen Send a message via Yahoo to markallen
Nice paint..
Savage w/O.S. .30
RC10GT2 w/Orion Wasp CRF.12
NTC3 w/O.S. TZ .18
markallen is offline   Reply With Quote
Old 05-07-2007, 07:23 AM   #9118
Default One-Way
Anyone running with a one-way? How is the durability? The CYA statements that Associated has used concerning the one-way and spool make it sound like the drivetrain will wear quick? Has this been the experiance?
Viper23 is offline   Reply With Quote
Old 05-07-2007, 10:39 AM   #9119
cheesewhip's Avatar
I run the factory team one way and have not noticed any durability issues. Other than regularly maintaining it, meaning cleaning and oiling, I have no issues with it. I can see how the front spool could strain the drivetrain but the only thing I've experienced is that when running a spool it does shave down the tires fast.
Old 05-07-2007, 11:32 AM   #9120
Thanks for the reply. I run on a large 1/8th track. So, would you recommend the one-way?
