Old 01-16-2007, 10:06 PM   #8971
fathead's Avatar
I think I used the thin AE 4/40 nuts that they use on the camber link ballstuds, 2 per rack post with loctite.
Slavich Design
fathead is offline   Reply With Quote
Old 01-17-2007, 04:43 AM   #8972
Bundy_Bear's Avatar
After seeing Josh Cyruls dual inlet design on the Orion\RRR at the Worlds last year, it has had me thinking
People have always been concerned about the chassis balance with a shaft drive car with it having all the heavy items on the outside of the chassis. To try and get a little more centre weight design i used paint to create a new fuel tank for the NTC3
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 01-17-2007, 05:38 PM   #8973
Send a message via AIM to T1bobo
Hey Guys,
After not racing the NTC3 for awhile im gonna go ahead and bring it back to my track and maybe even enter some big races with it and see how it will do!
wish me luck!!
T1bobo is offline   Reply With Quote
Old 01-18-2007, 04:35 AM   #8974
Sheer29's Avatar
Can some one tell me what the Werks racing pipes for the NTC3 are like to use compered to the FT dual-chambered tuned pipe
http://werksracing.com/product.do?sku=WRX6610C
Sheer29 is offline   Reply With Quote
Old 01-18-2007, 11:33 AM   #8975
Team Kamikaze's Avatar
As far as I'm concerned the FT dual chamber pipe works great on a NTC3, you won' be disappointed, never tried the werks pipe.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 01-18-2007, 04:04 PM   #8976
jnslprd's Avatar
hey whats up
my buddies an i are going to do some parking lot racing and wanted to find out what you guys think about a new team kit,rear exaust,non pull start. will this be fine? my buddies all have factory teams. the only reason i would buy a team kit instead of the factory team is becuase ae has the team kits for 149.99.
thanks joe
jnslprd is offline   Reply With Quote
Old 01-18-2007, 05:20 PM   #8977
lil-bump's Avatar
Trader Rating: 83 (100%+)
I would go for it at 149.00. The only difference is the graphite parts and trust me; racing on a parking surface your will never feel the difference between plastic and carbon graphite
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-18-2007, 05:45 PM   #8978
wayne's Avatar
fathead thank you!
wayne is offline   Reply With Quote
Old 01-19-2007, 03:31 AM   #8979
Bundy_Bear's Avatar
Good to see some discussion in this thread after it has been dead or awhile.
No body like my fuel tank design
BB
MissMooRC Racing
Old 01-19-2007, 03:56 AM   #8980
Pattojnr's Avatar
Trader Rating: 19 (100%+)
BB
Howdy Andrew, your tank desing is a bit rough, but the concept is great in theory. i ve never owned a shaft car, but i guess when the tank is on one side and full, would make a difference to handling while the level drops. thats why your concept is good. but can i get you thinking about something else ? if you have the 2 pick up points, whats going to happen when the level drops enough and is able to pick up air on the opposite pick up while the G's are moving the fuel away from it. maybe what would be needed is some sort of valving system to prevent this. i dont know how ? but i will keep thinking
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-19-2007, 12:53 PM   #8981
BB
You could almost base this off the serpent impact tanks! where the pick up points are! am I right?
Old 01-19-2007, 12:56 PM   #8982
Its not much a diffrence between the two pipes but a better pipe to compare the werks to would probly be the ofna pipe! But dont get me wrong the FT is good but i have ran both the ofna and the werks and i would choose the ofna over both!
Old 01-19-2007, 09:57 PM   #8983
Bundy_Bear's Avatar
I thought i had the pickup points at the lowest points, so it wouldn't have been an issue. As the level came down; i thought it would have been equal on both sides, making the fuel flow equal from both points.
Maybe i am wrong...
I think most manufacturers have gone off shaft drive chassis for Pro Tourers so i don't see any of this being reality. I think the reasoning behind is to do with the more and more powerful engines that have become available and as the grip comes up it reveals the weakest point (eg crown and pinion gears).
BB
MissMooRC Racing
Old 01-19-2007, 09:58 PM   #8984
Bundy_Bear's Avatar
I haven't seen an Impact tank, only the S710 & 720 tanks
BB
MissMooRC Racing
Old 01-19-2007, 10:40 PM   #8985
BB
I had a serpent impact M2 and it was preety much the same thing as your drawing but with that serpent touch to it great idea though!
