Old 11-02-2006, 03:54 AM   #8956
Bundy_Bear's Avatar
Is anyone still running this car?
Is there any point someone buying one at the moment or has Associated pulled the pin on it?
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 11-02-2006, 06:47 AM   #8957
lil-bump's Avatar
Trader Rating: 83 (100%+)
Pretty much dead in US. One of the better cars on a small technical track. other than that can not hang with the mugen,kyosho,serpent. I believe Associated nitro team has been dissolved at the moment. Concentrating there efforts on the new BELT electric car
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 11-02-2006, 07:30 AM   #8958
Old Skool's Avatar
Bummer man.
Old Skool is offline   Reply With Quote
Old 11-02-2006, 07:05 PM   #8959
Bundy_Bear's Avatar
Thanks... not interested in something that has no after market support. Real shame cause my original NTC3 was fast
BB
MissMooRC Racing
Old 11-04-2006, 09:46 PM   #8960
revzalot's Avatar
Anyone know the exact length of the NTC3 shaft that connects the front and rear diff? In mm please. TIA
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 11-04-2006, 09:55 PM   #8961
Send a message via ICQ to markallen Send a message via Yahoo to markallen
162 mm
Savage w/O.S. .30
RC10GT2 w/Orion Wasp CRF.12
NTC3 w/O.S. TZ .18
markallen is offline   Reply With Quote
Old 11-19-2006, 04:23 PM   #8962
wayne's Avatar
WTF!
Originally Posted by Jap TC3
It's not just small to medium track... big track as well..
I'm still running my 4 yrs old NTC3 (upgraded to Version 2 rear suspension), believe me I beat our local MTX4, RRR, & 710 this morning at our local track..
I have evo-RR and RRR... but now go back to me previously shelved car NTC3..
Dude... gear ratio for long track: 20/54 and 27/48 .. you'll be fying over 710, MTX4 and RRR on the straight and cutting infornt of them in the corner..
These is odd .. the ratio is not in AE table.. try it.
I know its an ancient post - but ANYBODY tried this ratio - I am not convinced that it will mesh - correct me if I am wrong but the stock ntc3 rtr + ratios are 26/54 22/48 - and of course this meshes - he is proposing to increase one pinion and decrease the other
please correct me if I am wrong - track has changed and been made a hell of alot larger and I need more legs
wayne is offline   Reply With Quote
Old 11-19-2006, 06:20 PM   #8963
The stock RTR + gearing is 22/26 clutch and 54/50 spurs.It has a 4 tooth difference..I always ran 21/27 clutch gears and 54/48 spurs..
Savage w/O.S. .30
NTC3 w/O.S. TZ .18
Old 11-20-2006, 07:57 AM   #8964
Gearing I used (for short track) was 20/54 26/48, for longer 21/54 27/48, It was no need to change position of engine, mesh was OK for both.
majk is offline   Reply With Quote
Old 11-21-2006, 04:52 PM   #8965
wayne's Avatar
so from what i am seeing if there a 6 tooth difference pinion there needs to be a 6 tooth difference spur
example - 21/27 will mesh with 53/48 - difference of 5 teeth between both - is this true - just dreamed this ratio up - yes i know there is no 53 tooth - but if there were would it mesh
Old 11-21-2006, 04:53 PM   #8966
wayne's Avatar
accidental double post - stupid internet had a brainfart - edited it out
Old 11-21-2006, 07:14 PM   #8967
Right from what I've learned the difference MUST be the same..It might look like it meshes properly but it doesn't...
Savage w/O.S. .30
NTC3 w/O.S. TZ .18
Old 01-16-2007, 03:22 PM   #8968
wayne's Avatar
I am having steering rack slop issues, gradually gets looser as the day wears on and have to do a substantial teardown of car to tighten it back up, is there a trick to keeping this tight or is it just one of those things one must deal with
kinda wishing for some ingenuitive simple solution to the slop that creeps in, help me out plz guys
Old 01-16-2007, 03:28 PM   #8969
fathead's Avatar
Had this problem myself, easy fix, replace crappy plastic nuts with loctited metal nuts.
Slavich Design
fathead is offline   Reply With Quote
Old 01-16-2007, 07:48 PM   #8970
wayne's Avatar
forgive me, but what size nuts should I use? its metric here in Australia and afaik NZ too, they pretty small and as best I can tell for some reason bolt co's don't stock imperial nuts/bolts this small - great idea btw will set about finding some nuts to use
yes I checked the manual, it no list a size for the top thread of the rack mount pins
