Old 04-06-2006, 03:57 AM   #8866
soc123_au's Avatar
R/C Tech Charter Subscriber
The Werks pipe is legal. I used it at various sanctioned events in Australia with no problems.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 04-09-2006, 09:46 PM   #8867
hi, newbie here...1 question please.. is AE stock engine crankcase .15 fits AE .12 piston and sleeve?
limau is offline   Reply With Quote
Old 04-09-2006, 10:05 PM   #8868
limau-I don't know for sure, but I wouldn't think so?
RRacerRuss1 is offline   Reply With Quote
Old 04-10-2006, 07:48 PM   #8869
Jap TC3's Avatar
I think there are 2 versions of the pipe.. legal version and outlaw version.. depending on the stinger diameter.
Jap TC3 is offline   Reply With Quote
Old 04-10-2006, 07:50 PM   #8870
Jap TC3's Avatar
You can also look out at rd-logics pipes.. similar design..
Old 04-10-2006, 07:53 PM   #8871
Jap TC3's Avatar
check this out.. www.rdlogics.com
Old 04-11-2006, 07:42 PM   #8872
tony q's Avatar
question guys, i need to know what is the effect of having a solid rear diff and solid front spool? going to used for rubber and foam.
tony q is offline   Reply With Quote
Old 04-11-2006, 07:52 PM   #8873
Send a message via ICQ to markallen Send a message via Yahoo to markallen
I have one of those pipes.I think it's the outlaw version.So far it works pretty good..
Savage w/O.S. .30
RC10GT2 w/Orion Wasp CRF.12
NTC3 w/O.S. TZ .18
markallen is offline   Reply With Quote
Old 04-12-2006, 09:51 AM   #8874
You may run into the problem of stripping your diff gears as you get tapped or when you tap a board. With solid axles, there is no give in your drivetrain, so the only thing that will give will be your diff gears. It may run well, but I am sure that front solid with rear diff may work better, or front one way with solid rear might be a better combination to use with foam. I used a front solid with rear diff for rubber tires and had tons of grip in the rear with very little push up front. Good luck.
sook is offline   Reply With Quote
Old 04-12-2006, 10:34 PM   #8875
tony q's Avatar
thanks for the info.
Old 04-13-2006, 12:58 AM   #8876
i got that pipe too but im still not as quick as the other cars
ae_ntc3 is offline   Reply With Quote
Old 04-13-2006, 07:01 AM   #8877
soc123_au's Avatar
The werks pipe will give you a bit more legs than the RD pipe in my experience. The other thing to try is a Mugen Centax, it allows you to run 22/28 pinions which will also give more top speed. But the reason I am now in a 710 is I couldnt carry the speed of the belt cars on a big track with the AE car. I saw in another thread you are running the NSW titles this weekend, go see Barry Walker & he will hook you up with the Mugen clutch. Moorebank is a difficult track to be at the pointy end in the NTC3.
Auswide Hobbies
JPM Racing
Old 04-17-2006, 02:26 PM   #8878
Default no start
how important is it to loop the line from the muffler to the lid of the gas tank? I just ran mine in straight.....i am having trouble starting the vehicle
ed
indy_rc is offline   Reply With Quote
Old 04-17-2006, 04:51 PM   #8879
soc123_au's Avatar
That wont cause it to not start. You do need a bit of length &/or a pressure chamber to help stop the fuel foaming up.
Auswide Hobbies
JPM Racing
Old 04-20-2006, 09:56 AM   #8880
Default centax clutch
Will the stock ae pinions fit the k-factory centax clutch bell. or will I have to buy new pinion gears
Elliott hart is offline   Reply With Quote
