Old 03-27-2006, 03:30 AM   #8851
Originally Posted by indy_rc
well, iam starting to think i am in the wrong hobby. I have always been a diy'er. However, I am having more and more problems. I got the radio controller figured out. Now i am having trouble getting the steering servo to not hit the body plate. I have used the spacers and left them out....i have tried switching the servo around. It still hits the body and binds.
Also theread diff starts to pop-up when i put in the left rear hub. it is almost as if one of the gears is warped.I have rebuilt it three times and it is right.
frustrated.....i want this thing burning nitro!
adjust your epa so that you get equal travel both left and right but it doesnt hit the radio tray.
ae_ntc3 is offline   Reply With Quote
Old 03-27-2006, 06:26 AM   #8852
it is sticking straight up..so if it is hitting the right bracket i want to move the arm so it faces 9 pm
so essentially i am going to turn it the opposite way it is striking the body....wont that cause the steering to start to the left?
ed
indy_rc is offline   Reply With Quote
Old 03-28-2006, 07:51 AM   #8853
pressure's Avatar
Default First car ntc3 with K factory hop ups
thanks for help with clutch
Rc10ntc3-photo_032806_005.jpg   Rc10ntc3-photo_032806_006.jpg   Rc10ntc3-imga0026.jpg
ITS COMPLICATED......................
pressure is offline   Reply With Quote
Old 03-28-2006, 09:09 PM   #8854
soc123_au's Avatar
R/C Tech Charter Subscriber
ed
You dont want it straight up. Check your manual for the correct angle (about 15 degrees left from straight up from memory) It wont hit the radio plate if it is done correctly. Shorten your tie rod to suit.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 03-28-2006, 09:13 PM   #8855
soc123_au's Avatar
Not sure what you mean here. Try assembling all your suspension without the CVDs installed. Make sure it is all free & no binding. All arms should drop under their own weight without shocks installed. Then re install the CVDs.
Auswide Hobbies
JPM Racing
Old 03-29-2006, 07:14 AM   #8856
is the flywheel supposed to turn freely. mine seems stiff....then it loosens up...stiffand then loosens
Old 03-29-2006, 02:49 PM   #8857
soc123_au's Avatar
That is good. When it gets stiff that is the piston reaching the top of the liner. If it is loose than your engine is no good. The engines have a tapered bore & rely on the pinch for compression.
Auswide Hobbies
JPM Racing
Old 04-01-2006, 12:28 PM   #8858
T1Raycer's Avatar
hy
i have a ntc3 rtr that i buy like 2 years ago !! the basic one whit the side exhaust style! and i want to know what spring rate was the stock spring on the car??? front and back
heres a pics
Later!!
T1Raycer is offline   Reply With Quote
Old 04-01-2006, 01:03 PM   #8859
Send a message via ICQ to markallen Send a message via Yahoo to markallen
If I recall the springs are silver and gold.
Silver-14.5 lbs
Gold-19.5 lbs
Mark
Savage w/O.S. .30
RC10GT2 w/Orion Wasp CRF.12
NTC3 w/O.S. TZ .18
markallen is offline   Reply With Quote
Old 04-02-2006, 02:26 PM   #8860
Registered User
Dirtfreak15's Avatar
Does anyone know factory settings for the motor
i lost my book and cant find it anywhere.
and it wont start cuz its probably tuned way wrong.
Dirtfreak15 is offline   Reply With Quote
Old 04-02-2006, 03:33 PM   #8861
BimmerDriver's Avatar
the crystal is 75.630
the receiver in the car is a synthesized with a dial with 1-6 and 0-9
i set it at 6 and 3 and it doesent work
It probably doesn't work because 75.630 is Channel 72 not 63.
75.410 MHz --- Chan. 61
75.430 MHz --- Chan. 62
75.450 MHz --- Chan. 63
75.470 MHz --- Chan. 64
75.490 MHz --- Chan. 65
75.510 MHz --- Chan. 66
75.530 MHz --- Chan. 67
75.550 MHz --- Chan. 68
75.570 MHz --- Chan. 69
75.590 MHz --- Chan. 70
75.610 MHz --- Chan. 71
75.630 MHz --- Chan. 72
75.650 MHz --- Chan. 73
75.670 MHz --- Chan. 74
75.690 MHz --- Chan. 75
75.710 MHz --- Chan. 76
75.730 MHz --- Chan. 77
75.750 MHz --- Chan. 78
75.770 MHz --- Chan. 79
75.790 MHz --- Chan. 80
75.810 MHz --- Chan. 81
75.830 MHz --- Chan. 82
75.850 MHz --- Chan. 83
75.870 MHz --- Chan. 84
75.890 MHz --- Chan. 85
75.910 MHz --- Chan. 86
75.930 MHz --- Chan. 87
75.950 MHz --- Chan. 88
75.970 MHz --- Chan. 89
75.990 MHz --- Chan. 90
BimmerDriver is offline   Reply With Quote
Old 04-03-2006, 07:14 AM   #8862
Jap TC3's Avatar
Silver-14.5 lbs
Gold-19.5 lbs
Mark
I think the standard springs are Copper & Gold... not silver. You can confirm this at www.rc10.com
Jap TC3 is offline   Reply With Quote
Old 04-03-2006, 08:14 AM   #8863
anthony390's Avatar
Send a message via AIM to anthony390
the gold and copper = the ntc3 standard
the gold and silver = the etc3 standard
anthony390 is offline   Reply With Quote
Old 04-04-2006, 05:18 PM   #8864
pressure's Avatar
Default ntc3 exhaust......
got a few e mails reguarding exhaust on my ntc3, its a c. werks exhaust ...
Old 04-05-2006, 10:34 PM   #8865
is the pipe efra legal ???
