Old 02-07-2006, 03:40 PM   #8701
AndyT 's Avatar
Originally Posted by ae_ntc3
ohh ive never had an accident like that lol the worst ive ever done is shatter a fuel tank.
does anyone experience pitching on the rear sides of the chassis?? eg. bottoming out marks but toward the outside rear of the chassis.
Yep, I had the same thing happen to my fuel tank......i stopped for a car that had crashed in front of me, only to have the car behind slam into my pipe and force it into the fuel tank shattering it
Theres a few posts in here about chassis`s, and the main consensus is that if youve got the money, then go for one of the BMI chassis`s......apparently these make the NTC3 into an entirely different car.....no tweak.....and SERIOUSLY quick........perhaps someone using one can elaborate on how they`ve found the handling has changed after going from the standard chassis to the BMI?
www.bmiracing.com
Cheers
AndyT  is offline   Reply With Quote
Old 02-07-2006, 04:11 PM   #8702
Trader Rating: 16 (100%+)
I am no longer having my NTC3, but when I installed my 3RACING chassis a while back, my used to be way underweigh NTC3, suddenly ended up a little bit overweight (1730G ROAR legal weigh limit.....1730 or 1750, I forgot)...Yes, I think my earier message was a typo...not 200 gram heavier...may be 20 grams heavier...
About the Nurnburg Toy Fair , this guy has a gallery contained 700+ pic, may be some of those are from AE....
http://www.bb-hardware.com/modules/x...6&id=Academy_1
Old 02-08-2006, 01:34 AM   #8703
www.bmiracing.com
Cheers
on their website i cant seem to find any ntc3 products
ae_ntc3 is offline   Reply With Quote
Old 02-08-2006, 05:43 AM   #8704
Same here, No ntc3 chassis parts
Elliott hart is offline   Reply With Quote
Old 02-08-2006, 05:13 PM   #8705
AndyT 's Avatar
Hmm, maybe theyve discontinued them?....its been a while since I`ve surfed that site
AE_NTC3 try PMing SOC123_au.......I think Steve had a couple he was selling....he`d be a good one to talk to about how they affect the characteristics of the NTC3
Cheers
Old 02-08-2006, 05:48 PM   #8706
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
BMI IS DOING MORE ELECTRIC NO MORE NITRO FOR NOW
20 SMOKE is offline   Reply With Quote
Old 02-08-2006, 05:57 PM   #8707
soc123_au's Avatar
R/C Tech Charter Subscriber
The BMI Chassis made the car more stable & helped with fuel tank foaming. It was also easier to clean. I still have a V1 BMI equiped car if any one is interested. Really though there is nothing wrong with the standard AE Chassis, I would love to be able to turn back time & not buy half the hop ups I bought for the NTC3 my bank account would be a lot healthier. The factory team kit equiped with the fix, a K factory side brace, K Tank, K drive shaft cups & Yokomo shock caps & Bladders will more than enough car for most drivers. Have a spare diff for putting in the front for some tracks & you have the best short track combo on the planet.
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 02-08-2006, 06:03 PM   #8708
soc123_au's Avatar
Yes, if you are too soft or too low this will happen. Try raising the ride height & then firmer springs or oil. Colour in the chassis with texta so you can see if it is still scraping & readjust if nececerry. The car will handle much better if it is not bottoming out. The only thing that should touch the track is tyres. Also if you change ride height dont forget to adjust the droop accordingly.
The sparks look good at night though
Auswide Hobbies
JPM Racing
Old 02-09-2006, 06:03 AM   #8709
macnkitty2002's Avatar
what weight shock oil do you guys recommend for an asphalt, parking lot track with a semi-smooth surface? i was thinking 60-40.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-09-2006, 09:46 AM   #8710
also, are there any carbon fiber parts available for the NTC3?
Losi Rock Rey
Old 02-09-2006, 03:17 PM   #8711
AndyT 's Avatar
I found the 40wt was generally quite good on a low/medium traction ashphalt surface.
Old 02-09-2006, 03:18 PM   #8712
AndyT 's Avatar
Theres a carbon fibre side chassis brace, and also a few other carbon parts are available......have a surf around www.rcmart.com they used to have quite a few hop-ups for the NTC3.
Cheers
Old 02-09-2006, 04:05 PM   #8713
soc123_au's Avatar
Gotta agree with Andy T the kit oil (40wt) is fine for most tracks. K-Factory & 3 Racing do the Carbon Fibre goodies for the car, Side Brace, Radio Tray & Front Bar Brace. The K Factory ones seem a better fit in my opinion. Side brace is a good investment, the radio tray & bar brace will stiffen the car up a bit but I think it is more eye candy. It does look nice You can also get the K shock towers 2 piece, the lower is alloy & mounts to the diff case & the upper is carbon fibre. They look sexy & seem to strengthen the mounting point to the diff case. If you are after looks they are the ticket but if you want strength then the fix is a better option. I havent owned the K towers (probably the only hop up I didnt try ) but a friend has them & likes them. The fix & K Towers will not work together.
Auswide Hobbies
JPM Racing
Old 02-09-2006, 05:09 PM   #8714
thanks for the info. do you mean 40wt all around?
Losi Rock Rey
Old 02-09-2006, 05:32 PM   #8715
soc123_au's Avatar
40 wt front & rear.
Auswide Hobbies
JPM Racing
