Old 01-17-2006, 07:30 AM   #8581
tommi's Avatar
Originally Posted by ae_ntc3
what effect does that give when its slightly coning ???
Again, MORE traction, we're all here trying to give you tips on increasing rear traction. Imagine with your rear tires coning slightly on the inside edge...when your car takes a RIGHT turn, rolling happens and the tires' contact patch of the outside LEFT wheels shift from the inside to the outside of the wheels. With MORE camber(and hence slightly coned tires), when the car leans towards the outside, MORE contact patch is allowed for grips; hence giving you the traction you need in the corners. Hope I'd explained it clear enough...
tommi is offline   Reply With Quote
Old 01-17-2006, 05:35 PM   #8582
yes i understand now
thanks
ae_ntc3 is offline   Reply With Quote
Old 01-17-2006, 05:39 PM   #8583
whats the most rear toe-in anyone has ever had to run ????
Old 01-17-2006, 05:55 PM   #8584
Send a message via ICQ to markallen Send a message via Yahoo to markallen
yes the stock gearing on the ntc3 is 0.8
This says the spurs are 32 pitch.
http://www2.towerhobbies.com/cgi-bin...?&I=LXBAV9&P=0.
Savage w/O.S. .30
RC10GT2 w/Orion Wasp CRF.12
NTC3 w/O.S. TZ .18
markallen is offline   Reply With Quote
Old 01-17-2006, 05:59 PM   #8585
but then why do the ofna gears which are 0.8 mesh with the standard ntc3 gears ????
Old 01-17-2006, 06:07 PM   #8586
I know they do but I can't answer that.
Savage w/O.S. .30
NTC3 w/O.S. TZ .18
Old 01-17-2006, 06:57 PM   #8587
wayne's Avatar
the infos on finding rear traction is quite interesting as I too have had difficulties taming the rear of this car on corner exit and to distill the posts down to a few sentences here is what my take on what people suggest is :
  • increase front droop (arms drop lower -- lower number on ae guage)
  • stand rear tyres up more by reducing negative camber
  • stiffen front suspension
  • tighten front diff
if this is the case it would appear that I had worked out 2 of the four on my own -- are these correct (yes/no)
on an unrelated matter I was doing some reading on tuned pipes and it would seem that the length of the pipe is crucial in managing the exhaust pulse reaching the exhaust port at the right time - as a result and due to the fact that there is some flexibility in how long the exhaust can be somewhat (courtesy of blue rubber thing) where should the exhaust be placed? - if my research is accurate wrong placement can cause overheating, power loss and quite a few other nasty things
I am running a ntc3 rtr + with all stock engine/pipe components any advice would be appreciated
<<edit>> also I was wondering if the diffs get "looser" with running and wear?
ugh soo many questions sorry guys
wayne is offline   Reply With Quote
Old 01-17-2006, 08:40 PM   #8588
AndyT 's Avatar
On the FT NTC3 i used to get by with 2 degrees toe-in at most tracks.....occasionally i`d run 2.5degrees.
Cheers
AndyT  is offline   Reply With Quote
Old 01-17-2006, 10:59 PM   #8589
Thumbs up
I've been running this car for over 3 years and it seems like the rear would always sort of whip around sometimes. I found that out of a corner, if you sort of blip the throttle acouple of times before really getting on the pipe, it would keep the rear-end in check. Just as long as the setup is even. I just started running the Mugen MTX-4 but I still enjoy the NTC3 alot.
mgreen is offline   Reply With Quote
Old 01-18-2006, 02:40 AM   #8590
yeah it looks like i might have to start doing that when im coming out of corners although i have tried a few different things now
Old 01-18-2006, 02:41 AM   #8591
but its only this track that the car slides out.all the other tracks the car is great!!!!!!
Old 01-18-2006, 07:19 AM   #8592
Hey guys, I am looking at getting a Factiry Team NTC3 and I have some questions. Is there anything I need to take into consideration when building it, other than follow the manual exactly? Are there any upgrades or mods. that should be done? Is there anything that needs to be checked more closely and more often than others? Sorry for the noob questions. I've never raced nitro, just electric. Thanks
RobertM is offline   Reply With Quote
Old 01-18-2006, 08:14 AM   #8593
fastrcracer's Avatar
Anyone heard anything about Team Associated updating the NTC3 ?
fastrcracer is offline   Reply With Quote
Old 01-18-2006, 09:11 AM   #8594
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
RobertM, the NTC3 is really good out of the box. I would get one of the team drivers' setup on the Team Associated website and start from there. Good luck, and enjoy!
Rich Panganiban is offline   Reply With Quote
Old 01-18-2006, 10:59 AM   #8595
Default ntc3 rtr
what can u say about the rtr plus out on the shelves now
glock45067 is offline   Reply With Quote
