Old 01-13-2006, 03:41 AM   #8551
yes the stock gearing on the ntc3 is 0.8
ae_ntc3 is offline   Reply With Quote
Old 01-13-2006, 03:44 AM   #8552
and regarding the prices in australia, they will be 50% cheaper!!!!!
Old 01-13-2006, 04:05 AM   #8553
hooked_on's Avatar
ae_ntc3:
Thank you for your prompt reply.
H_O
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 01-13-2006, 04:07 AM   #8554
hooked_on's Avatar
Default Ver 2 Rear End
Does "The Fix" still work on any of the new NTC3's with the Version 2 rear end? Also does the Factory Team version come with the better plastic arms etc?
H_O
Old 01-13-2006, 04:04 PM   #8555
AndyT 's Avatar
Version 2 doesnt change the need to use "the fix".....the fix is for the front end diff case and prevents the diff case screws/shock tower stripping out of the front diff case in the event of a front end collision.........Version 2 is basically a rear suspension update/upgrade fromt he original.
The arms etc used on the FT NTC3 i found to be very good/durable
Cheers
AndyT  is offline   Reply With Quote
Old 01-13-2006, 08:31 PM   #8556
hooked_on: no probs
andyt:arnt you racing at ec today??? and do you still run your ntc3 ???
just curious because there arnt many who are currently driving the ntc3(in sydney) partly because of the insanely high prices associated parts used to cost!!!
Old 01-14-2006, 04:22 PM   #8557
AndyT 's Avatar
Wouldve loved to have raced at EC but unfortunately had to work nighthshift
I`m no longer racing the NTC3.....changed to the RRR simply because it became so hard to get parts locally.
The FT NTC3 i raced was quite good around EC....its not too large a track and i reckon it suited the NTC3 quite well.
I`ve got a couple of mates still racing them.....1 is running a Collari 7 port...its an absolute weapon along the EC straight
A mate of mine is racing his NTC3 in pullstart class at Summernats.....the Fairy Meadow track suits the NTC3 nicely.
Cheers Andy
Old 01-15-2006, 02:19 AM   #8558
yeah i raced there at fairy meadow today and made it in to the A final with the big boys.i was running the ntc3 but i couldnt find any rear traction
i was running 40f and 35r tires and im thinking of going to 32r.im using the greenspring in the rear and shocks are layed down with no swaybar. i just don't know what else to do ????
Old 01-15-2006, 02:20 AM   #8559
im using the one-way in the front.do you think i should try a ball diff in the front ????
Old 01-15-2006, 03:03 AM   #8560
Send a message via ICQ to AJC13B
Hey AE
Which engine are you running? Im andys mate thats runing the NTC3 @ Summernats with the pullstart so Im interested to get some tips of you!
AJC13B is offline   Reply With Quote
Old 01-15-2006, 03:29 AM   #8561
wayne's Avatar
amazing by the looks of this thread the ntc3 is getting into australia great -- I also struggle for rear traction and have as yet been unable to solve it <sigh> any suggestions let me know thanks guys I run rubber tyres
wayne is offline   Reply With Quote
Old 01-15-2006, 05:40 AM   #8562
ntc3freak's Avatar
wow.32 in malaysia,the lowest i use is 37 lolz.hmmm.maybe use copper springs in the rear???see if that works
ntc3freak is offline   Reply With Quote
Old 01-15-2006, 08:42 AM   #8563
waltuo's Avatar
... but i couldnt find any rear traction ...
On or off power?
011011110111010101110100011011000110000101110111
a waltuo production
http://vimeo.com/iamwaltuo - http://youtube.com/iamwaltuo
waltuo is offline   Reply With Quote
Old 01-15-2006, 08:56 AM   #8564
tommi's Avatar
To me, I find it better to work on the car setup, rather than to go to the extent of going to 35/32R for traction. I was running the NTC3 for the past 3 years on a cemented carpark track, tire wear was high, traction is not too great but OK. Traction wise, 37 is good, 35 is the best; but tire wear is a pain. We managed to found out the best combination of 37F 40R for the track (which caters more to a rubber tire track), complementing the factors of tire wear, traction and the handling with the car setup; WITHOUT any compensation on speed.
It could all be the one-way you're using. Top drivers over here tried the one-way on the car, but still they find the diff to be THE "THING" for the NTC3. You could always work on the diff tightness to gain steering up front, while not sacrificing the rear traction. But if you insisted on using the one-way, it helps to increase the rear traction by
1) Stiffening the front antiroll bar/front shocks
2) Increase rear droop
3) Lower rear roll center(more horizontal camber link)
tommi is offline   Reply With Quote
Old 01-15-2006, 09:31 AM   #8565
tommi's Avatar
He was using green springs and fighting for traction, copper springs are 13lbs. harder than the green ones my friend; he's gonna have a doughnut on the track I'm afraid.
Playing with spring rates is interesting. Going too soft does not necessarily mean you will get all the traction you want; on the other hand, going harder does not necessarily mean you will lose traction. Going too soft on the rear might cause traction roll or causing the car to break loose suddenly; harder springs could make the breaking of traction felt smoother...it all depends on the track condition. Happy experimenting!
