Old 11-22-2005, 08:42 AM   #8506
cars.cars.cars is offline   Reply With Quote
Old 12-08-2005, 09:38 PM   #8507
Looking for a centax clutch for my NTC3. Ive found the mugen, K-Factory, and OFNA ones. Any Ive missed? Do any of these accept the stock NTC3 gears, or do I need a new set of those too if I switch clutches? Also, what are 0.8 module gears? One of the sites was saying something about all the 1st and 2nd gears are the same, saving you having to fiddle with mesh, not sure if thats true.
Any help would be appreciated, thanks
RC Paperboy is offline   Reply With Quote
Old 12-09-2005, 03:10 AM   #8508
AndyT 's Avatar
Theres also the GPM and Yokomo centax clutches, although i wouldnt be too interested about using the GPM.
The Yokomo centax is supposedly quite good.....Barry Baker has used it quite a bit.
Cheers
AndyT  is offline   Reply With Quote
Old 12-14-2005, 11:02 AM   #8509
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
Does anyone have the part# for the Yokomo NTC3 centax clutch handy? Thanks.
Rich Panganiban is offline   Reply With Quote
Old 12-15-2005, 01:58 PM   #8510
Talking
I'm using the Ofna Power clutch which is a centax clutch with the .08 pinnion gears. I'm still running the stock NTC3 spur gears with it. You will not be able to use the NTC3 pinnion gears with this clutch but it all bolts right up with the stock NTC3 engine mounts. It looks like it might not work but it does. Heres a picture of it.
mgreen is offline   Reply With Quote
Old 12-24-2005, 01:52 PM   #8511
i found this picture on ebay, look at the shock tower, is modified for use with a lola body, does any body know where i can find it or how to do it?
oderem is offline   Reply With Quote
Old 12-25-2005, 04:09 PM   #8512
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Found a Kfactory clutch but don't know any one that has used it
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 12-26-2005, 07:43 AM   #8513
Actually, to make the lola bodies fit, you can do it several ways. Where the front shock tower hits the body, you can heat that area, then push up the lexan so the towers will fit. Usually what I do, but last time, I just cut out small holes and the top of the tower sticks through. I ran lolas against outlaws on free flowing tracks. Too bad I am forced to sell this year .
http://i26.photobucket.com/albums/c124/chuckmando/IMG_0468.jpg<img
CHUCKMANDO is offline   Reply With Quote
Old 12-27-2005, 10:06 AM   #8514
anthony390's Avatar
Send a message via AIM to anthony390
here on on ebay if you looking to buy one
http://cgi.ebay.com/NTC3-centax-yoko...QQcmdZViewItem
anthony390 is offline   Reply With Quote
Old 12-30-2005, 04:31 AM   #8515
what is a really good exhaust to use with the ntc3??? i currently run a sirio evo 3 and just can't seem to get the top end out of it with the stock pipe. i have the factory team kit.
g4raycer is offline   Reply With Quote
Old 12-30-2005, 09:33 AM   #8516
Send a message via ICQ to markallen Send a message via Yahoo to markallen
Try the RD Logics turbo pipe..
Savage w/O.S. .30
RC10GT2 w/Orion Wasp CRF.12
NTC3 w/O.S. TZ .18
markallen is offline   Reply With Quote
Old 12-30-2005, 04:03 PM   #8517
ive got one on order already just waiting for it to come.will this pipe let my sirio reach top end an peak out because my friend and his rrr is using an sirio evo 3 and hes using a sirio pipe and it screams.
oh and is there any higher gearing besides 27/48 ????
Old 12-30-2005, 05:34 PM   #8518
AndyT 's Avatar
The Werks Racing pipes were getting good feedback as well.
www.werksracing.com
Old 12-30-2005, 05:45 PM   #8519
20 SMOKE's Avatar
did any one change the rear to the ver 2
Jamie W
Old 12-30-2005, 08:59 PM   #8520
The only way to go higher than 27/48 is to go with 0.8 pitch gears..They up to a 29...
Savage w/O.S. .30
NTC3 w/O.S. TZ .18
