Old 08-02-2005, 11:24 AM   #8311
Originally Posted by Stusdal
Found it!!
http://www.rdlogics.com/cgi-bin/category.cgi?item=61255&type=store
Does this pipe have an "nipel" for the pressure to the tank, or is there just a hole like in my asso efra pipe? (Can't see it on the picture)
(hoping you understand what i write )
That pipe has a permanent pressure fitting attached (welded on). I had one, but the pressure fitting interfered with a carbon fiber left side chassis brace, so I sold the pipe.
i300i is offline   Reply With Quote
Old 08-02-2005, 07:07 PM   #8312
yea the RD logics pipe does have a pressure fitting but like i300i said it won't work if you have a kFactory or other side chassi brace. if you have the stock braces then it will work fine. I use the FT tuned dual chamber.. as it's quieter than the RD logics or the FT single... and quiet is a issue with me
NTC3Kitty is offline   Reply With Quote
Old 08-02-2005, 08:32 PM   #8313
ntc3freak's Avatar
hey guys,how tight should my servo saver be???
ntc3freak is offline   Reply With Quote
Old 08-03-2005, 02:21 PM   #8314
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
I gained more steering responce by putting a RC10GT diff spring in place of the weak stock servo spring. I think a lot of guys do this. Be careful the servo screw doesn't rub the frony outdrive cup. I had to dremel mine.
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is online now   Reply With Quote
Old 08-08-2005, 04:27 AM   #8315
Stusdal's Avatar
I made a permanent pressure fitting for my asso erfra pipe, and it seem that all my problems are solvd
I've never had a car working this greate...tjohoo
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 08-08-2005, 07:24 PM   #8316
im looking at this car and i was wondering if it was better than the HPI nitro RS4 3 18SS? just wanted to know before i bought it.
Whats a good racing grade engine for the NTC3?
Also slide or rotary carb.???
cars.cars.cars is offline   Reply With Quote
Old 08-08-2005, 08:26 PM   #8317
Originally Posted by Rich Panganiban
Run the camberlink as long as possible, low on the tower, no wahers under the ball stud on the hub carrier (if you're running the V2 rear end). This setup provides the most camber gain (a little more side bite upon exiting a corner).
I will try that on my V2 chassis
CTurbo is offline   Reply With Quote
Old 08-08-2005, 08:27 PM   #8318
most onroad guys use slide carbs because of the throttle responce at higher RPMS unlike the rotary carbs often used in offroad.
the NTC3 is great because it's upgradeable as any other car!
Old 08-08-2005, 08:41 PM   #8319
whats a good engine to go with it though!!??
I dont wanna spend more than 200$ on the engine though
Old 08-08-2005, 09:03 PM   #8320
Trader Rating: 16 (100%+)
OS 12 TZ 3 port turbo.........should be couple dollars less then $200 shipped thru some internet RC store....or have your LHS to match the price.
Old 08-08-2005, 09:21 PM   #8321
Is the Team Orion Wasp .12 Turbo any good??? cause from tower hobbies that one is like 240$
Old 08-09-2005, 05:16 AM   #8322
ntc3freak's Avatar
Old 08-09-2005, 09:47 AM   #8323
The NTC3 factory kit says that only non pull start engines fit. Is there any way I can adjust it so i can put a pull start in there.
Old 08-09-2005, 11:19 AM   #8324
You'd need to get different motor mounts and flywheel. The FT kit has exhaust manifold and pipe for a rear exhaust engine. I don't know if you'll find a rear exhaust pullstart engine, so you'd need a side exhaust manifold and pipe. By that time, you are close to the price of a starter box and batteries.
Old 08-09-2005, 11:24 AM   #8325
ok thanks
Just making shure.
Is the Ntc3 the best on-road car for my money or is there another one i should compair it to. (HPI, Kyosho, Tymiya, Ofna) or is this the best for my money as of now.
Thank You!
