Old 07-12-2005, 11:18 AM   #8236
Trader Rating: 16 (100%+)
Originally Posted by jasonntc3
I have been racing mt ntc3 with a sirio 15 for almost 2 yaers now, and was wondering if is should change out my MIP clutch to a centax???? If so what brand and why???? I have any problems with the MIP but was wondering if the centax would work better on my tiny 60-70foot straightaway track????
60-70 only..? No....forget about Centax, centax will only get you nuts. Stick with the 2 or 3 shoes or MIP. It is not the straight that prevented you to use CENTAX, is I don't think you can tell the different at all, in fact, I think it will not work better then regular clutch.
Old 07-12-2005, 11:21 AM   #8237
do you think the factory 2 or 3 shoe will work better that the MIP?????
jasonntc3 is offline   Reply With Quote
Old 07-12-2005, 11:22 AM   #8238
The same....but I like the simple installation of MIP....you don't need to change, period.
Old 07-12-2005, 11:27 AM   #8239
Thanks for the fast responce AND advice......
Old 07-12-2005, 08:07 PM   #8240
Bundy_Bear's Avatar
Does anyone know if the following kits come with ball diffs front an rear or a front one way like the FT kit?
#2034 & #2035
I believe these are the updated versions of the pullstart / non-pullstart kits with the Version 2 rear end etc
Also, Does the NTC3 fit onto the new Hudy complete setup station (aluminium) or do i need to make the holes bigger to fit the axles onto the Hudy?
I look forward to hearing from you all soon.
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 07-12-2005, 08:08 PM   #8241
Bundy_Bear's Avatar
Default NTC4?
When does the NTC4 come out?
BB
MissMooRC Racing
Old 07-12-2005, 08:42 PM   #8242
only the Factory Team kit #2033 comes with the front one way
and you need to make the holes larger to fit an NTC3 on a huddy setup station.
NTC3Kitty is offline   Reply With Quote
Old 07-12-2005, 08:58 PM   #8243
AndyT 's Avatar
Agreed Rookie Solara....Barry Baker made comment in an interview that "the only real advantage he could see in using a centax clutch in the NTC3, was that it could be adjusted while still being in the car"......I think from memory he was using the Yokomo centax.
AndyT  is offline   Reply With Quote
Old 07-13-2005, 02:51 AM   #8244
Bundy_Bear's Avatar
Thats what i thought you might say... What happens if i do drill it an then if the NTC4 comes out with normal size axle or i changed car for what ever reason? I need to throw away the setup station an buy a new one?
I knew this hobby was expensive, but that is just shit!
BB
MissMooRC Racing
Old 07-13-2005, 05:35 AM   #8245
BB
I had my NTC3 on a Hudy set-up station a couple of days ago. No drilling was needed. Fitted straight on!
Rody is offline   Reply With Quote
Old 07-13-2005, 06:54 AM   #8246
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
I believe the only kit to come with a front one-way is the Factory Team.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 07-13-2005, 09:46 AM   #8247
BB
Buddy....it is not NORMAL or UN-NORMAL.....US made car used STANDARD thread screws and nuts, and you must use standard size tools...... and vise versa, foreign made car used METRIC thread....both are normal....or in your case, not normal.
And about your concern using the same setup station for all cars....I don't know about the NEW HUDY one, but my $50 Integy alum setup station, does work with BOTH standard and metric thread axle.......just with 2 set of lock nuts.
For your information, NTC4 are not going to use METRIC on their axle....they are owned by Thundertigher, doesn't mean they will convert to metric, that is just plain stupid....beside, the OD between the NTC3 axle compare to 710 axle are just a hair larger, even when your setup station's holes are slikely bigger, and in the future, you are using a metric axle car, the work station will still work with a larger hole size as long as you tighen it correctly.
Old 07-13-2005, 10:12 AM   #8248
tommi's Avatar
Solara is right. I owned a NTC3 and a Hudy setup station, the fitting onto the axles are very slightly tight, all I did was-use a file to slightly file the blocks, and whoala.
tommi is offline   Reply With Quote
Old 07-13-2005, 04:04 PM   #8249
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
after servo glitches, and reciever problems
i got lent a set of crystals and guess what
the problem went away
saved me from buying a $100 servo
anyway, ive been running dual diffs in my car for the past year.. and perhaps it is time i try a one way? what does it feel like compared to diff
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 07-13-2005, 05:37 PM   #8250
AndyT 's Avatar
You`ll gain off-power steering (better turn-in) with the one way (as both front wheels can rotate thru the corner at differing speeds).... and a bit more acceleration/grip when on-power (as drive is being applied to both front wheels equally when on-power).
You`ll lose braking to the front wheels.......and the car will want to/will spin out if you apply the brakes when in a corner..........I liken it to applying only the rear brakes on a bicycle when youre on a loose surface, the rear will want to break free and spin out.
Hope this helps.
