Old 05-09-2005, 04:39 AM   #7981
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Also take off the rear sway bar.
nsxshogun is offline   Reply With Quote
Old 05-09-2005, 05:37 AM   #7982
Make sure the back tires are just a little bit bigger than the fronts. If you let the rears wear down smaller than the fronts the car gets waywaywayway loose.
jiml is offline   Reply With Quote
Old 05-09-2005, 05:41 AM   #7983
tommi's Avatar
Originally posted by owens
my problem is off power going into turns. coming out of the turns the seems to hook up pretty well, i should it is driveable out of turns, could be better.
All points raised by snackpack helps in stabilizing or giving the rear more bite/grip. Maybe you could check your front diff to see if it is a bit too loose? Too loose a front diff might caused that too.
tommi is offline   Reply With Quote
Old 05-09-2005, 12:44 PM   #7984
ttso's Avatar
Default Byebye NTC3
I'm quiting GP racing as I said yesterday. My car now on for sell:
http://www.rctech.net/forum/showthre...threadid=71796
No seperated, everything else are negotiable.
For some people who saw and like my radio plate mod. I will have the design draw publiced later (might take a while) so you can DIY your own mod.
ttso is offline   Reply With Quote
Old 05-10-2005, 02:42 AM   #7985
AndyT 's Avatar
Are you running foam tyres or rubbers? You could try going to a softer rear tyre.
AndyT  is offline   Reply With Quote
Old 05-10-2005, 04:02 AM   #7986
andy, i am running rubber tires. i tried takeoff cs27's and yokomo 138's
owens is offline   Reply With Quote
Old 05-10-2005, 04:06 AM   #7987
revzalot's Avatar
Don't run any sway bars. Increase ride height in the rear and soften shocks.
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 05-10-2005, 07:54 PM   #7988
AndyT 's Avatar
If your track/club allows it, switching to foams will greatly enhance your grip.
Old 05-11-2005, 10:17 AM   #7989
If your to loose in the rear, going into the turn, that means too much weight is being transfered to the front. You have to make adjustments that will plant the rear end down some more. You will see a big change by changing your droop settings. You want less up-travel in the rear.
mgreen is offline   Reply With Quote
Old 05-11-2005, 09:37 PM   #7990
hey guys i know that AE springs fit the ntc3 but what other springs will fit it and have the same fit as they do?
EX:yokomo,hpi, etc......
better than you is offline   Reply With Quote
Old 05-14-2005, 08:18 AM   #7991
Default better steering servo horn
Anyone know of a heavier-duty option for the steering servo horn? I'm running a Hitec metal gear servo and stripped the Associated (H) servo horn. I'd like aluminum or dubro HD, but I haven't found anything that has the shaft offset built-in like the Associated horn.
i300i is offline   Reply With Quote
Old 05-14-2005, 11:13 AM   #7992
revzalot's Avatar
Default Re: better steering servo horn
I'm currently using an OFNA aluminum servo that has can fit any servo out there with its interchangeable connector. Works great!
Old 05-14-2005, 04:54 PM   #7993
Default Re: Re: better steering servo horn
Are you using that for steering? I tried a Dubro HD horn, but the linkage ball cup interfered with the servo itself.
Old 05-14-2005, 07:28 PM   #7994
revzalot's Avatar
Default Re: Re: Re: better steering servo horn
Yup for steering.
Old 05-20-2005, 10:39 AM   #7995
Trader Rating: 16 (100%+)
I know for the last version of NTC3, first thing to change is update the bumper to the RPM bumper cause the stock one is like made in glass....
How about the FT NTC3 revised 1 piece bumper (with plate)..? Those FT NTC3 owner, do you still need to upgrade to the RPM one..? Or the revised (new) one is just as good.....thanks.
