Old 05-05-2005, 09:28 PM   #7966
oh yea mine came with the two stile nuts.. so I jsut have to cut it? sweet
NTC3Kitty is offline   Reply With Quote
Old 05-05-2005, 09:30 PM   #7967
fathead's Avatar
Talking
yep
Slavich Design
fathead is offline   Reply With Quote
Old 05-07-2005, 03:39 PM   #7968
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
hey guys, have any of you tried the Yokomo centax clutch for the NTC3? I know Kawahara has one, but I like the looks of the Yok and plus my IDOL Barry Baker ran one at the RDLogics race... hehe
Here's the link to it- http://www.yokomousa.com/options/associated_opt.htm
Feedback is appreciated
Jason
BigDogRacing is offline   Reply With Quote
Old 05-07-2005, 09:26 PM   #7969
there are a couple selling on eBay for very cheep ($25) but I have never tried one. also there is a k-factory one selling for 50 I think
Old 05-08-2005, 06:16 AM   #7970
Kitty, I searched for 20 minutes for the Yokomo NTC3 Centax clutch. Would you mind posting the link? Thanks!
Old 05-08-2005, 09:02 AM   #7971
I've been running the Ofna Power Clutch in my NTC3 for months now and it great.
mgreen is offline   Reply With Quote
Old 05-08-2005, 09:06 AM   #7972
forgot to attach pic.
Old 05-08-2005, 10:06 AM   #7973
I guess the auctions ended I can't find them either.. there is a centax cluth selling for 35$ but i'm not sure what brand
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old 05-08-2005, 10:39 AM   #7974
ttso's Avatar
Guys I have some NTC3 parts for package sell. Might selling NTC3 as well, still thinking..
Parts sell: http://www.rctech.net/forum/showthre...threadid=71676
ttso is offline   Reply With Quote
Old 05-08-2005, 03:51 PM   #7975
nsxshogun's Avatar
Send a message via AIM to nsxshogun
I want that radio tray!! I got my Ft built up now. I may get some kfactory parts next week.
nsxshogun is offline   Reply With Quote
Old 05-09-2005, 02:53 AM   #7976
Stusdal's Avatar
I raced mine fore the first time this weekend, works great.
A bit loose at the rear, any good tips?
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 05-09-2005, 03:00 AM   #7977
AndyT 's Avatar
If its a bit loose of the rear try 2 degrees toe in on the rear, and -2 degrees camber on the rear.
If its still loose add a little more toe-in.
I found this worked well on my FT NTC3.
AndyT  is offline   Reply With Quote
Old 05-09-2005, 04:08 AM   #7978
i have a ntc3 with the version 2 rear end, mine also is very loose in the rear. i have 2 degrees toe in, and -2 camber on the rear. droop is set at 4 and 40wt shock oil all 4 corners. somebody has told me to increase the shock oil in the front to reduce steering. any ideas would be helpful.
thanks
owens is offline   Reply With Quote
Old 05-09-2005, 04:24 AM   #7979
Hi Guys,
If the rear end of the car is loose, I would recommend softening the rear suspension. This can be achieved by:
Laying down the rear shocks.
Using a softer rear spring.
Adding more front droop.
Softening rear anti-roll bar.
You could also try loosening the rear diff. or running softer rear tires. It also depends on whether the car is loose on power or off power (above suggestions are to be used in an on power situation).
Hope this helps.
SNACKPACK is offline   Reply With Quote
Old 05-09-2005, 04:39 AM   #7980
my problem is off power going into turns. coming out of the turns the seems to hook up pretty well, i should it is driveable out of turns, could be better.
