Old 04-29-2005, 12:17 AM   #7951
revzalot's Avatar
Originally posted by NTC3Kitty
when I bought my NTC3 kit, the rear diff parts I got (the ATD outdrives were different than the one pictured in the setup manual - I went to the local hobby shop and looked at some ATD sets and they were all like the ones pictured in the manual.. so I decided to buy a new one to replace the one that obviously wasn't the right part.. then I bought a "Spooled" rear diff.. the solid F/R axle any comments on this?
The spool should be used in the front. It works great for tight tracks.
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 04-29-2005, 06:51 PM   #7952
Default tuned pipe choice for short track
engine:.12 os tr r spec (p)
which tuned pipe-
blue ae efra 2603 or rd logics
for short track
rene is offline   Reply With Quote
Old 04-30-2005, 05:32 AM   #7953
Registered User
Send a message via AIM to bbntc3
We race short tracks and with the lowest gearing 50/54, 20/24 and 62/63mm foams and any good modified engine or any higher HP engines the RD pipe seems to work the best. When it's tuned right the engine will get up on the pipe off the turns much faster than the AE pipe. Be sure if you decide to get the RD pipe you get the Turbo version.
bbntc3 is offline   Reply With Quote
Old 04-30-2005, 08:23 AM   #7954
Stusdal's Avatar
I hav been trying to find information on what the "fix" is, but now I am tired of that.
Can someone pleas tell me what the "fix" is? do I need new parts or can I make something my self?
thanks
Serpent || Sanwa || Hobbywing || GensACE || Sorex || Contact ||
*When you are not practicing, remember, someone somewhere is practicing, and when you meet him he will win*
Stusdal is offline   Reply With Quote
Old 04-30-2005, 12:08 PM   #7955
JosB's Avatar
The "fix"is really simple;2 screws from bottom of chassis through to the top of the shock tower(see picture).I made mine myself with a supporting plate under the shock tower.Only thing is to find the long screws to pass through it all.
JosB is offline   Reply With Quote
Old 04-30-2005, 12:15 PM   #7956
JosB's Avatar
Here's the picture,sorry
Old 04-30-2005, 12:18 PM   #7957
JosB's Avatar
Also I would like everybody's opinion on my new and improved throttle setup.It's the best I've made so far.
Old 04-30-2005, 09:31 PM   #7958
Default smooth surface setup
does anyone have a setup for a smooth suface running 35 shore nitro shoes all around foam.
better than you is offline   Reply With Quote
Old 05-01-2005, 02:01 AM   #7959
Thanks to the guys that advised me to choose the RD Logics turbo pipe for my RB V12. Awesome power after changing to this pipe. I TQ'd and won the A main on my first outing with this lethal combo!
Rody is offline   Reply With Quote
Old 05-01-2005, 03:58 AM   #7960
AndyT 's Avatar
Well done Rody ......was that at Tempe?
Cheers
AndyT  is offline   Reply With Quote
Old 05-01-2005, 04:43 AM   #7961
Cheers mate. It was at Tempe. They ran the track in reverse today and i was a bit more nitro friendly! Have you raced there?
Old 05-02-2005, 03:36 AM   #7962
AndyT 's Avatar
Unfortunately i havent had a chance to race there yet, I usually race at either Moorebank or EC.......i`ll definitely head down there one day and have a race though, sounds good
Cheers
Old 05-05-2005, 04:55 PM   #7963
what would be the out come of running yellow front 60w. and copper back 60w.
Old 05-05-2005, 08:06 PM   #7964
can I use an engine with a 'threaded' style crank?
such as this - http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true
and how good is a Picco Collari .12 better or worse than the sirio?
i was thinking about the STS D3R, can't beat the price at 145
any comments please?
NTC3Kitty is offline   Reply With Quote
Old 05-05-2005, 08:20 PM   #7965
fathead's Avatar
Yes you can you just need a different nut to hold the flywheel onto the crank, the threaded part of the crank will have to be cut to the right length but thats about it.
It is called a standard type crank
The other sort is called SG style crank
The NTC3 comes with both types of nuts as far as I know, well at least mine did.
Alot of clutchs come in the 2 different crank style types with the appropriate nut
Slavich Design
fathead is offline   Reply With Quote
