Old 04-16-2005, 08:24 AM   #7846
bigtez's Avatar
i have the camber/toe gauges from the hudy exclusive system and they fit just fine.
bigtez is offline   Reply With Quote
Old 04-16-2005, 12:56 PM   #7847
Default ntc3+
hey guys, looking for a little set-up help here. i'm running a ntc3+ rtr in our club race stock nitro class. i have take-off's 22, 27, and 32's. i also have a set of yokomos 138g's. any tips for a rubber tire set-up? i am running a mazda6 body. team asscoiated dosen't have a new ver2 rubber tire set-up sheet posted by anyone yet. thanks for the help.
owens is offline   Reply With Quote
Old 04-16-2005, 04:11 PM   #7848
You won't see a rubber tire setup because almost everyone runs foam tires. If you can find a ver1 setup use that. The ver2 rear doesn't change the car's geometry, just how you set rear toe in.
For rubber start out with the stock setup and go from there. That will bee close.
jiml is offline   Reply With Quote
Old 04-16-2005, 06:20 PM   #7849
AndyT 's Avatar
Originally posted by hooked_on
What pipes is everyone using for rear exhaust motors? What is the FT Dual chamber one like?
H-O
I found the FT pipe to be very good with my RB v12........gave very good power in the low-mid range.
AndyT  is offline   Reply With Quote
Old 04-16-2005, 06:24 PM   #7850
AndyT 's Avatar
Also,
The new Hudy setup system would need to be drilled out to accept the larger diameter axle on the NTC3?
H-O
I think from memory theres a post in here about someone having probs getting the older style Hudy setup system to fit the axles of the NTC3...........there was a follow-up post though that said the new Hudy setup system fitted the NTC3.
Old 04-16-2005, 07:04 PM   #7851
i just tried my ntc3+ on my hudy and the axles wouldn't fit throught the fixtures.
Old 04-16-2005, 09:26 PM   #7852
revzalot's Avatar
The NTC3 with rubbers tires performed well today with a front spool this time. The spool performed well on a tight and technical track. The car was on rails as the track temps went up. This is on crappy rubber tires btw. The setup was very loose and the car turned beautifully. Again my trusty NS3 wasn't the fastest out there but held up with the best of them.
revzalot is offline   Reply With Quote
Old 04-16-2005, 09:32 PM   #7853
huskerfreak's Avatar
I have the newest Hudy system ( The Ultimate Setup) and the ntc3 goes on it fine.
huskerfreak is offline   Reply With Quote
Old 04-17-2005, 05:59 AM   #7854
hooked_on's Avatar
Thank you again
It was the newer version Hudy system that i was thinking about when i asked the question?
Also,
What parts (eg part no's etc) are needed to assemble a front diff? And were is the best online place to buy AE parts?
H-O
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 04-17-2005, 10:22 AM   #7855
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Anyone want to trade a NTC3 for a Hpi r40.
Heres my origional post
Im thinking about selling my r40. Anyone want to buy one. I just want to know how much id get for it. Or maybe fast harry will trade me his ntc3 for it. It has all the hopups like both towers, lightweight tranny, both lightweight shafts. Front one way and dif, a RD logics pipe, grafite side brace and steering plate. I also have extra gears and the 1.0 tranny. Antother stock chassis is also included. I want to trade for a shaft dirven car. Like NTC3 or FW-05. If I sold it without a motor or radio how much could i get for it.
nsxshogun is offline   Reply With Quote
Old 04-17-2005, 10:24 AM   #7856
nsxshogun's Avatar
Here is some old pics.
Old 04-17-2005, 04:04 PM   #7857
Send a message via ICQ to drive4fun
Hey, I've been doing my research and have been seeing that many of you guys are running 6"-8" of fuel line from the tank to the pipe. How are you guys positioning the fuel tubing? What about from the tank to the engine?
Another question what do you guys think about having a fuel filter? As i see most people do not like them. They say it causes a lot of overheating to the engine?
Last question what fuel are you guys running? I'm running traxxas 20%. I've been told that it contains too much lubrication so what brand should i switch too?
I run a stock ntc3 rtr.
Thanks, will greatly appriciated.
drive4fun is offline   Reply With Quote
Old 04-17-2005, 04:25 PM   #7858
AndyT 's Avatar
H-O
I always found AE themselves the easiest to get parts from-
www.teamassociated.com
Old 04-17-2005, 04:26 PM   #7859
Default I give up!
Does anybody have a quick link to "the fix?" I saw it once, and now I can't find it. Just show me where I can find it.
Old 04-17-2005, 07:59 PM   #7860
Registered User
Send a message via AIM to bbntc3
www.bmiracing.com
look under bmi products
bbntc3 is offline   Reply With Quote
