Old 03-16-2005, 09:24 PM   #7726
Registered User
Send a message via AIM to bbntc3
another pic
bbntc3 is offline   Reply With Quote
Old 03-16-2005, 09:32 PM   #7727
ntc3freak's Avatar
nice car bob!!!ur front shocks is the hard anodized shock izzit???btw,the bmi chassis dun have radio tray huh????
ntc3freak is offline   Reply With Quote
Old 03-16-2005, 10:45 PM   #7728
Zootcapri's Avatar
Default Re: Dumb question
Originally posted by losispeed
Can you run 30mm foams on the ft and bk of the NTC3? Im new to foam racing and I bought 30s all around.. Do I need to go out and by MORE tyres? Thanks for the help...
Keep the 30's for the rear. I have run 26's and 28's in the front. Currently using 26's.....just seemes more balanced.
... more fun than we should be allowed.....
Zootcapri is offline   Reply With Quote
Old 03-16-2005, 10:58 PM   #7729
losispeed's Avatar
Default 30s up front
Will the car handle funny with the 30s up front? I wont be able to buy anymore foams before the next race..
losispeed is offline   Reply With Quote
Old 03-17-2005, 08:48 AM   #7730
More than likely Losispeed the Ntc3 will handle the 30mm ok, but you may have some problems turning left or right maximum due to the inside shoulder of the rims rubbing on the shock screws that attach to the lower arm. Which in turn will restrict your full right to left turns. This is the reason why most of us run 26mm or maximum 28mm fronts.
sook is offline   Reply With Quote
Old 03-17-2005, 08:58 AM   #7731
losispeed's Avatar
Thanks Sook..
Old 03-17-2005, 07:08 PM   #7732
AndyT 's Avatar
Originally posted by yodace
I was offered a new Barry Baker Ntc3 for 225.00. But he didn't tell me if was a team or factory team kit. Does associated make a Barry Baker team kit or just the factory team kit?
Heres a list of the NTC3 kits and their part #`s to help you out-
#2042- NTC3 RTR Plus
#2033- NTC3 Factory Team
#2034- NTC3 Team (side exhaust, pull start)
#2035- NTC3 Team (rear exhaust, non- pull start)
Cheers
AndyT  is offline   Reply With Quote
Old 03-18-2005, 08:15 PM   #7733
Registered User
Thanks NTC3 Freak! Yea those are the hard anodized shocks with the other shockshafts (unobtantium). The rear shocks came in today for it. They seem to be smoother than the stock shocks.
The BMI uses no upperdeck or radio tray, the chassis is stong enough without it.
Old 03-18-2005, 08:44 PM   #7734
ntc3freak's Avatar
the rear shock is different ah???seems normal enuff to me .i just got the shocks.nice shocks.easy to build.just 10 minutes for 1 shock.damn easy.i only have one complaint about the shocks.the lower spring retainer requires u to screw the collar until halfway of the shock body and make it so stiff.that is the only complaint i have.but i replaced it with rpm's lower spring retainer.is solves the problem.and it comes in blue!!! .extra style point.i may post my car's pics.but it is not as good looking as ur car bob,that is for sure
Old 03-18-2005, 08:47 PM   #7735
ntc3freak's Avatar
this pic is taken about 1 month ago.it is with stupid shocks and v1 suspension.
Old 03-18-2005, 08:48 PM   #7736
ntc3freak's Avatar
the body.nothing fancy,but good enuff for me
Old 03-18-2005, 08:56 PM   #7737
ntc3freak's Avatar
the new version
Old 03-18-2005, 08:57 PM   #7738
ntc3freak's Avatar
a look at those sweet shocks
Old 03-19-2005, 07:13 AM   #7739
Registered User
I use the HG Alum spring retainers, their no problem either.
Old 03-19-2005, 07:17 AM   #7740
Registered User
I also use the TC3 shocks and springs on our GT onroad truck. I polished the AE alum shock tops on it.
