Old 02-05-2005, 10:33 AM   #7561
ttso's Avatar
Default Re: NTC3SLCG radio plate prototype assembled
This photo shows how low the CG is with my mod...
ttso is offline   Reply With Quote
Old 02-05-2005, 02:07 PM   #7562
Registered User
Send a message via AIM to bbntc3
ttso: The deck mods look very good!! If I was'nt using the BMI chassis I would go with your setup, that's whats needed get the weight below the driveshaft. That's what makes the BMI chassis so great, the CG is very low with all the weight below the shaft.
Nostrixoxide: Maybe get your machinist buddy to go ahead with the alum diff gear project. Most people that have gear problems would diffently be interested in them.
I've kick around the idea of making brass ring gears and leave the nylon pinion and see what happens, but to lazy! especially when $5 will fix the car. ( not a cure, just a fix) Most machinist I've talked with say it would be easier to make molds and pour the gears instead of machining them.
bbntc3 is offline   Reply With Quote
Old 02-06-2005, 09:29 AM   #7563
ttso's Avatar
Test run today. First of I facing a serious radio interference problem, heavily glitch just 100m away. This problem forces me to relocate the RX to top of steering servo.
Even with RX on top of radio plate, which make the CG slightly higher than original design. My car is still noticeable more steady than before. And weight is well balanced like my predict. Now the only problem is how to move RX under the radio plate to lower the CG. Hope tomorrow weather will be good so I can test with differnt RX configuration.
Old 02-06-2005, 09:32 AM   #7564
macnkitty2002's Avatar
looks great!! that top deck is some kind of thick!
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-06-2005, 09:46 AM   #7565
ttso's Avatar
It's 3mm graphite, same thickness with AE graphite option radio tray. But without weight-saving cute, my plate does heavier than AE one, but also much secured (I think maybe too secured.. )
RX relocated to shorten the exposed radio line. Hope this will help to solve to the interference problem and still keep the CG low.
edit: Change a photo...
Old 02-06-2005, 10:42 AM   #7566
ahh, i see the throttle servo now. are the two servos close to each other? oh, and is that the low profile fuel tank? if so, whats the part #?
Losi Rock Rey
Old 02-06-2005, 11:49 AM   #7567
revzalot's Avatar
Very nice ttso. The plate also protects the stuff underneath from the nitro fuel.
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 02-06-2005, 05:08 PM   #7568
AndyT 's Avatar
Great job TTSO....it really looks good.
AndyT  is offline   Reply With Quote
Old 02-06-2005, 05:13 PM   #7569
fathead's Avatar
Thats the K-Factory fueltank
Slavich Design
fathead is offline   Reply With Quote
Old 02-07-2005, 06:53 AM   #7570
ntc3freak's Avatar
Default FISH TAIL
how to fix it??
ntc3freak is offline   Reply With Quote
Old 02-07-2005, 07:00 AM   #7571
ntc3freak's Avatar
looks nice.hey ttso,do u screw on the shocks rather than using the nut??i saw u have reversed the assembly.
Old 02-07-2005, 09:53 AM   #7572
Registered User
I see the Spectrum DSM receiver system is now shipping from Horizon for the M-8. So it looks like the other radio systems should also ship on time. It should'nt have interference with the 2.4 Ghz system.
Old 02-07-2005, 04:06 PM   #7573
AndyT 's Avatar
Default Re: FISH TAIL
Originally posted by ntc3freak
how to fix it??
I`ve found that running 2 degrees of toe-in on the rear, and -2 degrees of camber helps tame fishtailing (oversteer), but you may need to go for a little more than this dependent on your driving style.
Cheers
Old 02-07-2005, 07:35 PM   #7574
ttso's Avatar
Ya, I found nuts-in is easier to disassemble/assemble than nuts-out when you need a shock position relocate...
Old 02-07-2005, 08:00 PM   #7575
ntc3freak's Avatar
ya.i found that with the stock setup,changing shock location is heck of a job.i already done just like u .but the shocks is is touching the arms,so i installed fuel tubings .hey,when ir u radio tray going to make into production?
