Old 12-21-2004, 11:30 AM   #7396
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
Default Sirio .12 Engine Manual?
anyone know where I can download a Sirio .12 (blk top) engine manual?
badKarma is offline   Reply With Quote
Old 12-21-2004, 12:27 PM   #7397
Trader Rating: 16 (100%+)
Default Re: Sirio .12 Engine Manual?
Their manual tells you nothing....go to their site.
http://www.star-motor.com/
Then hit "EXTRAS"
Then look at the right column and choose your options.
Old 12-22-2004, 10:11 AM   #7398
badKarma's Avatar
Default Fast Tyres or Egelli Tires?
where can I buy Fast Tyres or Egelli Foams?
Old 12-22-2004, 10:23 AM   #7399
http://shopping.rcmodel.hk/index.php...page=1&sort=5a
sook is offline   Reply With Quote
Old 12-23-2004, 11:18 AM   #7400
badKarma's Avatar
Default Cleaning Up Grease
whats the best way to clean up grease and grime from an engine, chassis, and tuned pipe? Do I use denatured alchohol or will that damage the engine components?
Old 12-23-2004, 01:31 PM   #7401
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Alcohol is fine, but mix just a TOUCH of undiluted Simple-Green to the mix - just makes cleanup more effective.
Won't hurt motor and leaves a fresh clean smell!
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 12-23-2004, 04:05 PM   #7402
bhambrent's Avatar
Boomer,
Thanks for the info .
bhambrent is offline   Reply With Quote
Old 12-23-2004, 04:35 PM   #7403
revzalot's Avatar
Fast Orange is another must have cleanser. I use to clean the pipes and Blue Magic to polish other stuff. All can be found at your local auto store. Merry X-mas everyone!
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 12-24-2004, 07:57 AM   #7404
badKarma's Avatar
Default Irrgang Products?
any have any Irrgang Products on their NTC3? I was thinking about a set of Big Dawgs and maybe a graphite radio plate.
Old 12-24-2004, 09:54 PM   #7405
Registered User
Send a message via AIM to bbntc3
Would just like to say here to all fellow NTC3 drivers have a very Merry Christmas!!! Bob
bbntc3 is offline   Reply With Quote
Old 12-25-2004, 06:30 AM   #7406
Default Re: Irrgang Products?
Use the big dawgs on the front only. No need in the rear. I have had plenty of luck with them.
Merry Christmas to all.
Charlie
CHUCKMANDO is offline   Reply With Quote
Old 12-28-2004, 06:45 PM   #7407
Default Setting droop
I'm building a FT kit. I set the front and rear droop using the gauge in the kit, before attaching the front and rear hubs. The manual shows the gauge contacting the a-arms where the pillow balls thread in.
Problem is that when the hubs are attached, there doesn't seem to be a way to use the FT gauge because the hubs get in the way. Does everyone remove the hubs to measure and adjust droop, or am I missing something?
i300i is offline   Reply With Quote
Old 12-28-2004, 08:08 PM   #7408
bhambrent's Avatar
Default Re: Setting droop
[QUOTE][i]Originally posted by i300i
I measure with the hubs on.
Old 12-28-2004, 09:49 PM   #7409
Registered User
That's just a step by step procedure for AE when building the car. I've always just used the bottom of the hub to measure droop. I was taught to use the lowest point of the arm be it the arm or hub which ever is the lowest .
Big Dawgs up front nod:
Old 12-29-2004, 07:22 AM   #7410
So, do you adjust the starting droop numbers? I think the AE manual recommends 4mm front and 3mm rear, as well as a Baker setup sheet that I found on the AE site. These numbers would have to be reduced by a coupla mm when measuring at the hubs. Any idea if Baker's setups are measuring droop by the manual, or at the hubs?
I'm just hoping to get beginning settings for rubber tires on a small prepped track.
