Old 12-19-2004, 01:03 PM   #7381
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
Default Help please!
Hey guys, here is the deal. I just came up on a NTC3 w/ a Sirio .12, and has "the fix" on both ends. It has been raced at total of 10 races and is in good condition. But I am a new nitro owner and dont know anything about the Sirio .12 engine, and am not too familiar with the car. Do you guys suggest I do a full rebuild to check all the parts for wear and tear? What would you do if you were in my shoes? Keep in mind im trying to get the car ready for nitro racing this spring. Get back at me, Thanks!
badKarma is offline   Reply With Quote
Old 12-19-2004, 01:21 PM   #7382
revzalot's Avatar
Yes do a tear down while you inspect the parts. Clean them with denatured alcohol with a little concentrated simple green mixed in. Don't get the diluted one but the concetrate. Soak the bearings in WD40 overnight and replace the bad bearings. After 10 races, some bearings will probably be bad. I'd get some Ceramic Bearings from Acer Racing. As for the Sirio, they're known to have weak con rods. You may want to tear the engine down and inspect the sleeve, piston and conrod. If the pistion is still in great shape, I'd get the sleeve pinched. I'd also replace the conrod to be safe. Sirio's rev high so a conrod a great investment. If it's the old rear suspension, you may want to upgrade to version two. Check for tweaked chassis also. Good luck in spring.
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 12-19-2004, 02:05 PM   #7383
badKarma's Avatar
What is simple green? and where can I find it? with the WD-40, how do i soak? i thought it was spray only. As far as the engine inspection, i think ill take it out and bring it to my LHS for inspection. I know these questions may sound basic, but like i said, im new to nitro. Thanks
Old 12-19-2004, 02:14 PM   #7384
revzalot's Avatar
Simple Green is an awesome degreaser that should be easily located in hardware. Put the bearings in a little cup and soak it with WD40 but I would take out the shields before soaking them. I would also polish the pillow balls and hinge pins. Nitro gets a little messy but that's the fun of it.
Old 12-19-2004, 02:21 PM   #7385
badKarma's Avatar
Sounds good. Should replace the existing screws with aluminum blue team version? As far as the Sirio .12 is concerned, how long is the average engine life?
Old 12-19-2004, 02:22 PM   #7386
badKarma's Avatar
And during the rebuild, how do i assess clutch wear and damage? What are the advantages of a centax vs the one supplied with the kit? should i just use the kit version or upgrade to the sure shift?
Old 12-19-2004, 03:07 PM   #7387
revzalot's Avatar
As for screws, I'd get some stainless for high reinforce areas such as swing rack, diff cases, brake, etc. and aluminum/titanium for low reinforced areas such as fuel tank, handle, radio plate, etc. As for the engine, it depends on how much it was used and what percent nitro did the owner run it on. Change the springs in the two speed and shoes. As for the clutch, this is a toss up. I have both the Kfactory and 3 shoe clutch and both work great. I modified the 3 shoe to run on small tight tracks while I'd use the kfactory on large tracks. On large tracks, I found some to be technical while others are sweepers so the Kfactory is great for adjustablility.
Old 12-19-2004, 03:41 PM   #7388
badKarma's Avatar
where can I purchase K Factory Parts?
Old 12-19-2004, 08:20 PM   #7389
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
You can order K Factory Parts from Brooklyn Hobbies, excellent prices. Here's the link:
Powerline Racing K Factory page
Rich Panganiban is offline   Reply With Quote
Old 12-20-2004, 10:12 AM   #7390
ntc3freak's Avatar
Originally posted by ntc3freak
i think it is the shocks.it is hard to rebuild.how do u rebuild bladder shocks?i am not using ae shocks at the moment.
anyone?pleaz help me
ntc3freak is offline   Reply With Quote
Old 12-20-2004, 12:57 PM   #7391
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
fill them with oil, stick the bladder on and then put the cap on.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 12-20-2004, 01:12 PM   #7392
I did not realize the ae shocks use a bladder. Mine does not use a bladder.
sook is offline   Reply With Quote
Old 12-20-2004, 06:08 PM   #7393
AndyT 's Avatar
The AE shocks on the NTC3 dont use a bladder, he`s running different shocks
AndyT  is offline   Reply With Quote
Old 12-20-2004, 08:35 PM   #7394
Registered User
Send a message via AIM to bbntc3
If interested in the bladder caps for the NTC3 Yokomo makes them. Speed Tech did stock them.
http://64.23.108.110/speedtechrc/174.html
bbntc3 is offline   Reply With Quote
Old 12-20-2004, 09:30 PM   #7395
ntc3freak's Avatar
is it good?i knoe that i nedd to fill them,but it is not rebounding.
