Old 11-08-2004, 10:58 PM   #7201
rrgt_kid's Avatar
Default Re: Re: Re: Re: yokomo centax
Originally posted by Rookie Solara
I think TTSO pretty much sums it........the idea is, try to INCREASE the distance between the 1st gear and the 2nd gear on your 2-speed gear box (NOT your centax, centax does not need to do anything).........so basicly I did is add a big shim onto the main shaft, then add 3 little shim behind the 1st gear before mounting to the 1-way hub..........again, the idea is increase the gap so when the centax is engaged...the 2nd gear PINION will not rub against the 1st gear spur....
If you have a machine shop and have a excellent hand, I know pp does SAND DOWN the 2nd pinion gear by like 3mm (or so that you can clear the 1st gear spur), that way, you don't have to do any shimming on the gear box.
have you got photo on the shimming you done on your gear box
where about you added the big shim on the shaft
sorry for this bother i still dont quite understand!!
jeremy.
also is the kawahara centax good and can you use original ae pinions on it????
rrgt_kid is offline   Reply With Quote
Old 11-11-2004, 10:17 AM   #7202
Trader Rating: 16 (100%+)
Default Re: Re: Re: Re: Re: yokomo centax
jeremy.
I will try to open it up and take some photos for you and others...but give me some time, nitro season is over here, snow is coming and = electric indoor season = my Pro 4.
Kawahara CENTAX cannot use original AE gears, no, but kawahara does sell their own gears whcih has the same gears T # as AE (from 20-27 1st and 2nd gear).....I would not recommand buying it cause I don't even know where to get Kawahara in state.
Wait untill AE release the Yokomo one....shoudl be early next year
Old 11-11-2004, 10:56 AM   #7203
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
The Associated team has been using the Yokomo based centax for over a year know with good results. The Yokomo centax uses most of the same components as the Mugen clutch.
Rich Panganiban is offline   Reply With Quote
Old 11-11-2004, 11:50 AM   #7204
ttso's Avatar
Rookie Solara, you playing Pro4 not TC4?
At least you should try TC4 CVD on NTC3. Should be a big boast on CVD strength since TC4's CVD is thicker than TC3/NTC3 CVD.
ttso is offline   Reply With Quote
Old 11-15-2004, 07:22 AM   #7205
GaryD's Avatar
Default Ofna Centax
I just tested the Ofna Centax in my NTC3 this weekend and worked great, wicked acceleration...
Comes with 21/27 pinions. What more could you want?
GaryD is offline   Reply With Quote
Old 11-15-2004, 07:34 AM   #7206
ttso's Avatar
21/28T gear combination...
My Picco XP 5ports will reach topend way before the straight line ended. Gotta try 28T as 2nd speed next time.
Old 11-15-2004, 04:27 PM   #7207
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
Originally posted by R3VoLuTiOn
ok, so ive been trying to resolve my "torque"steer issue for a while now. ive checked the bearings, put new hinge pins, checked for chassis tweak, and camber, toe in, caster are all equal.
now what do i have to fix? its still going to the right harshly.
help please.
R3VoLuTiOn is offline   Reply With Quote
Old 11-15-2004, 05:51 PM   #7208
fathead's Avatar
R3volution
Try closely inspecting all your bottom suspension arms for hairline fractures, this happened to me on my TC3 once and took me ages of pulling my hair out to find it
Check to make sure one of your shocks isn't slightly bent, also check to make sure your shocks don't bottom out before the chassis hits the ground
You didn't say whether it has been doing it since you got it but if it has check the pistons that you have in the shocks to make sure there isn't a wrong one in there.
Also check all your steering to make sure nothing is loose or bent, and check to make sure your steering servo isn't loose or damaged. Try replacing the steering servo with a different one to test.
Thats about all I can think of hope it helps, I have never personally had any problems with torque steer on my NTC3
Slavich Design
fathead is offline   Reply With Quote
Old 11-15-2004, 07:59 PM   #7209
bhambrent's Avatar
Default Re: Ofna Centax
Nice looking car. Just want to know what kind of foams are you running?
bhambrent is offline   Reply With Quote
Old 11-15-2004, 10:12 PM   #7210
GaryD's Avatar
Default Re: Re: Ofna Centax
They're Enneti, they're really nice tires, used to run Nitro Shoes, but these are half the price. Running 35 shore front and rear, they really stick...
Old 11-15-2004, 10:31 PM   #7211
revzalot's Avatar
I'm looking for some good radial tires. Something as almost sticky as foams but lasts longer.
www.revzalotmotorsports.com
revzalot is offline   Reply With Quote
Old 11-16-2004, 12:05 AM   #7212
Send a message via AIM to ToFast2Drive
Default hi
hi all
ToFast2Drive is offline   Reply With Quote
Old 11-16-2004, 08:17 AM   #7213
What your actually looking for are capped tires from BSR. You can get it from rc4less.com They are not cheap, but works well with the right setup and last longer. Just keep in mind that these tires are not ROAR or IFMAR legal.
sook is offline   Reply With Quote
Old 11-16-2004, 09:27 AM   #7214
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
There are also belted tires. I like belted better than capped since I can still choose the inserts to change the feel and heat generated.
I'll look at who I used to use. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 11-16-2004, 12:46 PM   #7215
lmslms's Avatar
Default Nitro TC4
Any word on a Nitro TC 4?
lmslms is offline   Reply With Quote
