Old 09-14-2004, 11:48 AM   #7021
Trader Rating: 16 (100%+)
Originally posted by ntc3freak
is baker using a centax clutch?what barnd is it?is it good?
We can only guess it is good.......because Baker used it. And I think it will cost around $80 or more.
At least, you wont need to worry about your clutch is slipping when you are powered by some JP or Rody engines.
Old 09-14-2004, 08:54 PM   #7022
ntc3freak's Avatar
where is it available from?in yokomo's website,it stated that it is 150usd.where do u get the price of 80usd?
ntc3freak is offline   Reply With Quote
Old 09-15-2004, 09:55 AM   #7023
ttso's Avatar
Originally posted by bbntc3
I would think Baker does and has always had monster HP, and he gets the car to run ok on the pipe, and fuel tank. So I dunno!! Maybe they massage his engines to work with the pipe??? LOL
I'm kinda hoping Dennis will do his magic , and rework the rd pipe.
I think I will try RDLogic Turbo pipe in near future to see how it compare with AE stock pipe, in first hand.
bbntc3, I think the main benefit for RDLogic pipe is it let the engine reach the high RPM in shorter time, am I right? Did you ever try to shorten the RDLogic manifold to get the pipe even shorter?
Thanks!
ttso is offline   Reply With Quote
Old 09-15-2004, 11:01 AM   #7024
I am just guessing..........the $135 (not $150) is full RETAIL...actually price should be lower.
However, if the YOKOMO decided to sell it to LHS for full retial.......you must be CRAZY to spend $135 for just a centax.
Old 09-15-2004, 11:03 AM   #7025
Thanks!
RD pipe is a 1 piece pipe...shorten the header will take a lot of welding and custom work.
Old 09-15-2004, 04:10 PM   #7026
Registered User
Send a message via AIM to bbntc3
The RD pipe sounds better, tunes and stays tuned better, less back pressure, which means less wash board effect in the fuel tank. Revs better??? I guess you could say that. We need it to get up on the pipe fast on short tracks, the Rd does that.
Like Rookie said the RD is a 1 piece, would have to cut it and reweld it, never done that ,the pipe is short enough.
It must be pretty good. When the LD3 came out , Team guys all switched to the RD pipe and look what happened, 2 months later ofna has a RD look alike pipe in production. And now I see AE is copying it in there own way.
bbntc3 is offline   Reply With Quote
Old 09-16-2004, 05:24 PM   #7027
Default blown engine
Maybe this is a dumb question. My engine blew. I am now installing a new engine. Can I reuse the manifold and pipe previously attached to the blown engine with my new engine? Would the broken metal dust from the blown engine get into the manifold and pipe?
raceblast is offline   Reply With Quote
Old 09-16-2004, 06:40 PM   #7028
soc123_au's Avatar
R/C Tech Charter Subscriber
Yes you can reuse the pipe & manifold
Serpent Radio Control Models
Auswide Hobbies
JPM Racing
soc123_au is offline   Reply With Quote
Old 09-16-2004, 06:45 PM   #7029
Do I need to clean the pipe and manifold before installing it with the new engine? How do I clean them? spray the inside of the manifold and pipe with brake cleaner?
Old 09-16-2004, 07:35 PM   #7030
Send a message via AIM to rossiRocket
yea that will work.
rossiRocket is offline   Reply With Quote
Old 09-16-2004, 07:47 PM   #7031
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
the mugen mtx3 centax clutch is the chepaer and better clutch......
if fits the ntc3 perfectly with the module 0.8 pinion gear for mtx3.......
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 09-16-2004, 08:01 PM   #7032
What gearing does it offer? Does it go up to 29tooth like the ofna?
Tks
CHUCKMANDO is offline   Reply With Quote
Old 09-16-2004, 08:08 PM   #7033
yes......the 1st gear ranges from 20T to 22T and 2nd gear from 25T to 29T.....
it really works, I personally never tried but Darin Ishitani used this centax on his ntc3 at the preworld here in Brazil.....
Salvadori Racing
Old 09-16-2004, 09:01 PM   #7034
fordman500's Avatar
So do you use standard Mugen pinions and spurs?Do you need to do any mods?
fordman500 is offline   Reply With Quote
Old 09-17-2004, 04:58 AM   #7035
Thanks, only about a month or two left here to run before it gets to nasty out to run. Maybe I can pick up a used one somewhere to try out.
