Old 09-10-2004, 04:31 PM   #7006
They have been playing with the shorter pipes for some time now. The one you have pictures is an AE pipe that had a section cut out and the pipe was welded back up they also have been playing with cutting the header as short as possible but still allowing it to fit into the pipe. Kyle Skidmore told me that it wakes the motor up across the entire power band. His was cut at the header and his car was screaming!! with a stock Novarossi in it.
Good Luck
FFR3582 is offline   Reply With Quote
Old 09-10-2004, 05:02 PM   #7007
Looks more like the rd logics dual chamber pipe now
R1ceboy is offline   Reply With Quote
Old 09-10-2004, 09:41 PM   #7008
Z00M's Avatar
Trader Rating: 15 (100%+)
Some of the guys that used to run the NTC3's over here told me that cutting 20mm from the pipe really makes the engines scream in the top end.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 09-11-2004, 01:08 AM   #7009
hugh janus's Avatar
[QUOTE]Originally posted by bbntc3
Its twisting the cvds out from HP not from wrecks. But thanks! I'll look into them. [/QUOTE
the rtrs' are the strongest cvds available for the nitro tc3 under any type of stress...yes they eventually wear out but all things rc eventually do.
hugh janus is offline   Reply With Quote
Old 09-11-2004, 02:11 AM   #7010
Send a message via AIM to rossiRocket
Cutting 20mm from the header? Do they also modify the main chamber or leave it stock? I am interested in doing this mod to my stock factoryteam exhaust.
rossiRocket is offline   Reply With Quote
Old 09-11-2004, 02:33 AM   #7011
Trader Rating: 16 (100%+)
I cutted the header about 20mm since the first day I own the NTC3, that is not a secret, but having the AE pipe shortened by X amount of length is something I cannot do (no tools and no skill)....
But I still think the AE pipe is powerfull enough......a little slower then the TEAM DRIVER is OK for me....LOL
Old 09-11-2004, 10:24 AM   #7012
ttso's Avatar
Maybe using RDLogic pipe is an easier solution?
bbntc3, I know you using RDLogic pipe, what's different between Turbo and non-Turbo RDLogic pipe?? Can't really tell the different from outlook on RDLogic's website.
ttso is offline   Reply With Quote
Old 09-11-2004, 10:51 AM   #7013
If compare with RD Logic, so far, most of the ppl that used AE and RD Logic said the AE is the better one.....so this shortened version of dual chamber is probably better then RD Logic one, beside the looks of it....
Old 09-11-2004, 12:06 PM   #7014
sweetpea's Avatar
anyone have the address for the place that sells "THE FIX" ???
sweetpea is offline   Reply With Quote
Old 09-11-2004, 08:33 PM   #7015
wild gopher's Avatar
Trader Rating: 39 (100%+)
you can find the fix on ebay, thats where i got mine from
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 09-11-2004, 10:36 PM   #7016
Registered User
Send a message via AIM to bbntc3
The differance is exhaust pulse in the pipe chamber. The turbo pipe is for turbo plug engines and moddified engines.
I have about 8 modded engines, and race mostly only short tracks here, the turbo RD pipe is the best for my application,( it gets up on the pipe sooner). Crispier Snap! I've made pipes, bought ever pipe made for the the car.
I know alot of people have no troubles with the AE pipes but they just won't tune to my liking on short tracks. The Ae pipe is to long and has to much back pressure, to me. I'm surprised AE has'nt change before now.
bbntc3 is offline   Reply With Quote
Old 09-11-2004, 11:11 PM   #7017
ttso's Avatar
Maybe the AE stock pipe is ok for oldtime power engine, but now we have some monster power engine, it become no good anymore? similar situation with clutch?
Old 09-13-2004, 04:38 PM   #7018
Registered User
I would think Baker does and has always had monster HP, and he gets the car to run ok on the pipe, and fuel tank. So I dunno!! Maybe they massage his engines to work with the pipe??? LOL
I'm kinda hoping Dennis will do his magic , and rework the rd pipe.
Old 09-13-2004, 09:33 PM   #7019
ntc3freak's Avatar
is baker using a centax clutch?what barnd is it?is it good?
ntc3freak is offline   Reply With Quote
Old 09-13-2004, 11:31 PM   #7020
In the Touring Car magazine, it states that Baker is using the Yokomo Centax clutch.
